Old 12-29-2012, 02:40 AM   #1
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Default How do I set up a HW xtreme stock for blinky??
Do I have to down load some bs to have it work in blinky mode??
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-29-2012, 02:49 AM   #2
hotrod1933's Avatar
Default blinky
you need the usb card and install software onto pc then install correct firmware to esc while connected. as you described some bs and a pita to do.
also does not seem to work till you disconnect power off and back on
XRAY T4-15 -- nbhc.com -- powerhouse performance -- sma.org
hotrod1933 is offline   Reply With Quote
Old 12-29-2012, 03:10 AM   #3
That's crap... Hopefully someone at the track will have their stuff with them tomorrow at the track.
Justin & Matt Lyons
a800s sanwa m12s
Old 12-29-2012, 07:48 AM   #4
lewis110's Avatar
If you wanted blinky installed maybe you should of got the Justock.
http://www.hobbywing.com/product_show.asp?id=218
That's the link to the pc software to switch esc firmwares. Its not hard to do at all. After you download the programs you will need to unzip it (rar file) I use www.jzip.com its really very easy.
You will also need a lcd program box and the usb link wire. And you will want to install 508_no timing firmware.
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 12-29-2012, 11:22 AM   #5
I have the program box and cable . Also only have a PC with windows 8 and I'm about ready to throw this damn thing in the road
Justin & Matt Lyons
a800s sanwa m12s
Old 12-29-2012, 07:10 PM   #6
ta04evah's Avatar
Here's a couple of well done video's that will help walk you through the process.
The software version used in the video is an older version, but the process is generally the same. They helped me to figure out how to program my esc when I first got it.
Part 1
https://www.youtube.com/watch?v=bUKMoGvRJZY
Part 2
https://www.youtube.com/watch?v=iOCFkCwBlrQ
Instead of selecting the stock software in the esc, you chose v3 508_No Timing for the blinky mode.
As I've never used Windows 8 I'm not sure if there's any issues with the hobbywing software, but if you download the latest Hobbywing software there shouldn't be any issues.
Hobbywing Software
http://www.hobbywing.com/upload/soft...tup_121204.rar
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 12-29-2012, 07:38 PM   #7
I got it earlier today . It seemed my trouble was the "rar" file. My windows 8 PC (new) didn't have anything to open this file . And for some (me being PC illiterate) reason couldn't download a program to open that file. But once I got that figured out . It only took 15 trys to figure out the process of hooking up and wiring to get the info to the ESC...
Fyi
Plug USB into PC
USB into LCD box
Box to ESC
ESC to battery.
Then load it twice ...
Justin & Matt Lyons
a800s sanwa m12s
Old 12-29-2012, 07:49 PM   #8
Ok im down an esc. So i need to use my xerun 1s. I need it in blinky would the steps above be the same? Also would this esc be ok used with 2s. ?
Huskerfan1212 is offline   Reply With Quote
Old 12-29-2012, 08:01 PM   #9
One local guy has ran his 1s HW with 2s and it worked for him with a 17.5
Justin & Matt Lyons
a800s sanwa m12s
Old 12-29-2012, 08:13 PM   #10
Kool. I just dont want to buy another esc.
Old 12-29-2012, 08:14 PM   #11
ta04evah's Avatar
Yes, the steps would be the same.
Just make sure you use the heat sink when you run it in 2s mode, also if it comes with a fan attach that too.
Cheers
Rob.
Old 12-29-2012, 08:39 PM   #12
Chaz955i's Avatar
Using a 1s in 17.5 touring right now. Works great. The software is a little cumbersome but once you figure out the process it works great.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 12-29-2012, 09:08 PM   #13
After i install the new software what more do i have to do to get it in blinki? I assume set the esc with the program box?
Old 12-29-2012, 09:56 PM   #14
AdrianM's Avatar
You have to do the same thing (use a PC to update them to Blinky) with Tekin. I think only the LRP's are blinky ready out of the box and they are not the fastest blinky speedo...Hobbywings are.
Adrian Martinez
Old 12-29-2012, 09:57 PM   #15
No it all happens wile ur hooked up to PC. My box will not control my ESC now . But I was able to userthe button on the ESC to change the brake strength and I couldn't before
Justin & Matt Lyons
a800s sanwa m12s
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 09:46 PM
