Old 04-11-2005, 06:38 AM   #16
i did this about about 4 or 5 years ago with a kawada sv-10. the trick is YOU HAVE TO PRESS OUT THE BEARING AND TURN THEM AROUND other wise it spins on power and locks up off. the car drove find, it didn't push and the rear end didn't come around on power, this was on carpet. you'll have to correct me if i am wrong but isn't the reason for a one - to have the front wheels spin free off power to get more turn in and then lock on power to get more power to the front and pull the car harder out of corner.
Turtlemaster is offline   Reply With Quote
Old 04-11-2005, 06:39 AM   #17
Send a message via AIM to odawg315
Originally posted by TRF415boy
Ok try it and when you'll have only FWD maybe you will realise a one way only work one way...
yes, this is were creativaty and innovation come into play, i have to fit the pully on it so its facing the same direction as it would going forward, i will have to grind the pully and usie a spacer so it will fit and it will go the "one way" i want it to.
odawg315 is offline   Reply With Quote
Old 04-11-2005, 06:45 AM   #18
yes, but i may end up running a locked spool in front so i still get the pull out of the turn, and front wheel braking as well. i dont know i could be completly out of my mind trying to do something thats just stupid, but i figure unless i try ill never now and isnt that part of the fun, and what were all after...finding that perfect setup?
Old 04-11-2005, 02:18 PM   #19
polesitter61's Avatar
I'm still gonna try it too, I think you can put the one way in the back of a xxx-s with out pressing out the bearing, just turn the diff around. Also thought I would under drive the front diff to keep the car from understeering so bad on exit. We'll see
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Team Losi 8ight Front and Rear Chassis Braces and KingHeadz Rear Toe meon99 R/C Items: For Sale/Trade 14 07-23-2008 09:24 PM
Assocaited B3 Rear Rims, T3 Rear Chassis Plate, Front Chassis Brace Hawk6 R/C Items: For Sale/Trade 5 09-04-2007 07:34 AM
3 xxx-nt rear a-arms and a rear shock tower f/s xxx-ntad2 racer R/C Items: For Sale/Trade 2 11-22-2006 03:45 PM
Urgent, Need Rear MBX5 rear shock body Izze-Racing R/C Items: Wanted to Buy 0 04-16-2006 03:48 PM
japanese trend, rear body posts in front of rear wheels? floodo1 Electric On-Road 13 11-19-2005 07:20 AM
