Old 12-17-2012, 11:18 AM   #1
Default Motor timing in boosted class
If a motor like D3/D3.5 comes with 30 deg built in motor timing, wouldn't it be logical to dial it to -20 or less in the endbell and add the timing in the ESC??
Is there something wrong with this reasoning??
Serpenteer is offline   Reply With Quote
Old 12-17-2012, 12:02 PM   #2
Barry_Hughes's Avatar
Nope - turning down the enbell timing and running more ESC timing helps keep the motor cooler - not sure about going down as far as -20 though
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 12-17-2012, 03:17 PM   #3
DesertRat's Avatar
Unless you have better boost know-how than most, I would just leave the motor static timing at whatever it states as being'0' on the endbell, neither advanced or retarded, (this is the motors 'natural' timing, about 30 degrees for Trinity stuff) and boost from there. I have tried retarding timing on the endbell past this 'zero' point and boosting more and all I got was more heat and a slower car, it seems that after a certain point less timing is bad for the system as well.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-17-2012, 04:08 PM   #4
Thanks for chiming in, I was ready to turn down the endbell timing and crank up the ESC timing without any guilt.
Did you turn up the timing in the ESC the same degrees you lowered it on the endbell??
Old 12-17-2012, 04:36 PM   #5
Can you go a lot higher on the ESC boost, than just the amount you reduce on the motor. On my tekin, I tried 55 degree boost and another 20 degree turbo, with the motor reduced to 20 degrees (was 48 unboosted). Even with all this timing, the motor ran cooler. I also geared down from my unboosted gearing.
The result was more torque and a lot more top speed.
jha07 is offline   Reply With Quote
Old 12-17-2012, 09:06 PM   #6
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Send a message via MSN to rangerjkb
+1 geairng down and adding timing to gain top speed works fantastic. If you get a chance, continue to practice with different mechanical timing setting to know motor limits and best performance settings.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 02-11-2013, 04:46 PM   #7
pierre johnson's Avatar
Location: im from cali but lived in texas most of my life
Default TRINITY D3.5 MAXZILLA 17.5 timing advance
I dont feel that comfortable turning down the end bells to increase power
Team Rctarget /Capricorn America/Reds Racing and Hobby Recreation Products!
pierre johnson is offline   Reply With Quote
Old 02-11-2013, 08:04 PM   #8
Mr RCTech's Avatar
No.
D 3.5 13.5 motor.
Personally, I turn my castle speedo to MAX 50 degrees of timing.
Never mess with the speedo timing.
Run -8 degrees of can timing and gear it to the track.
Temp motor and slowly add timing if under 160F
Found starting -8 to -5 degrees was more efficient as lap times did'nt fall off at the end of the race.
Mr RCTech is offline   Reply With Quote
Village Raceway in Royal Palm Beach TimPotter Florida Racing 5954 12-11-2017 05:30 AM
using boosted ESC & 17.5 motor in modified class? Eaglesrx Radio and Electronics 14 02-25-2012 10:37 AM
boosted ESC & 17.5 motor in modified class? Eaglesrx Electric Off-Road 13 02-25-2012 01:19 AM
non timing non boosted class motor and esc?? looklikeaflip Electric On-Road 11 02-15-2011 01:05 PM
