Old 12-16-2012, 10:15 AM   #1
Default Which 1s esc for 12
I'm sure there will be opinions, and sorry if this is a repeat. I purchased a new CRC XTI, and I want to run a 1s esc that doesn't require a booster or receiver pack. The footprint on the chassis is small so I would like the setup to be neat as well as functional.
Please if you do have suggestions add your why's ie adjust-ability, durability, fitment, etc...
Thank you in advance for your help.
P.S. Mostly I'll run 17.5 blinky but I want options.
Mark O'Brien is offline   Reply With Quote
Old 12-16-2012, 10:50 AM   #2
3D-Seth's Avatar
Trader Rating: 21 (100%+)
I'm running the Orion R10 in my Xti, really like this speedo. Super smooth on throttle, no need for a booster or separate receiver battery. Myself and a couple others are running this in our Xtis locally.
Photo:
3D-Seth is offline   Reply With Quote
Old 12-16-2012, 11:07 AM   #3
the 1cell specific hobbywing is also a great choice. They are admittedly a little big, but they are very inexpensive compared to most and they work at least as well if not better. Also, the 1cell version hobbywing does not require the use of a booster or receiver pack. So, considering those un-needed components, the size of the speedo is not so bad. On the CRC site, you'll find photos of team cars with hobbywing speedos fitted. As a side bar......when I removed my tekin and replaced it with a hobbywing, the car drove dramatically better. For sure the hobbywing's throttle application is way smoother and I really like that the neutral band and the motor brake effect are much more consistent.
vafactor is offline   Reply With Quote
Old 12-16-2012, 11:37 AM   #4
I believe the smallest are the Viper and the LRP. The Viper is the same size as my Tekin RS but is smoother and has a built in booster. The LRP is slightly bigger but lighter than the Viper.
Old 12-16-2012, 05:35 PM   #5
WIITA's Avatar
Trader Rating: 42 (100%+)
Hobbywing 1s is your esc IMO
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 12-16-2012, 06:07 PM   #6
Ahh a local guy adds his two cents Thanks.
Old 12-16-2012, 06:18 PM   #7
Trader Rating: 38 (100%+)
I have a couple of Speed Passion 2.1EX (no longer available), a Hobbywing 1s and the Viper. I'm very happy with all of them and would say any will serve you well. The Viper costs a bit more but is smaller so it depends on what your needs are. You are running an XTi so all will fit.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 12-16-2012, 08:01 PM   #8
NolanP's Avatar
Make sure you get the ORCA VX-1 in the convo it's a great speedo too.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 12-16-2012, 08:13 PM   #9
Trader Rating: 41 (100%+)
For our Blinky 17.5 class I am using the Hobbywing Juststock ESC. Super cheap and really nice and smooth. just need a boster (like the TQ booster) and you are good to go
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-16-2012, 10:27 PM   #10
Mark I like the Orion 1s, its smaller than the Hobbywing but it is more pricey. I don't think it performs any better but it is easier to fit everything on the chassis. Most of the local guys are running the Hobbywing in their Xti, me being the oddball running the Orion. Bub really likes his Viper... you can't really go wrong with any of them since they are all made in the same place. I think most locals ditched the LRP SXX after they had issues with the BEC failing and taking a long time to get them fixed.
avink007 is offline   Reply With Quote
Old 12-17-2012, 02:15 AM   #11
caaraa is offline   Reply With Quote
Old 12-17-2012, 09:55 AM   #12
I am loving the Viper VTX1, small footprint, easy install/setup and bloody quick!
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 12-17-2012, 10:25 AM   #13
AdrianM's Avatar
I plugged in my Tekin RS Pro backward in my WGT Car and blew it up a few weeks ago. I got a Justock so I could race the following day. I got my Tekin replaced and since then I have swapped them a couple times. I can't believe it but I can't see a bit of a difference in lap times between the two. Both have the latest software and both drive nice and smooth.
I am running them with a TP 13.5 on 1S with a new Novak Booster.
Adrian Martinez
Old 12-17-2012, 11:08 AM   #14
jsinclair's Avatar
Says Mr crc.....
I have the hobbywing 1s , with no complaints.
jsinclair is offline   Reply With Quote
Old 12-17-2012, 01:52 PM   #15
No9
No9's Avatar
I've changed from a Lrp sxx v2 to the Hobbywing 1s and it is so much better,awesome esc .
Schumacher Mi5evo/Ko Ex1v2/LRP/R1 wurks
Supported by MRJ RACING.COM.AU
No9 is offline   Reply With Quote
1/12 Scale 1s esc? SNIPR Radio and Electronics 32 11-13-2016 05:00 PM
What is the Best ESC for WGT or 1/12th mdhyams Electric On-Road 21 03-29-2015 09:46 PM
Novak Havoc 1s ESC 13.5 combo Lee_123 Electric On-Road 52 10-25-2011 07:21 AM
Which brushless esc has 1s lipo cutoff? rx7ttlm Electric On-Road 13 04-28-2009 03:54 PM
