Kyosho Touring Car
#1366
I ran the stock chassis, Andy had a 4mm chassis, with the standard upper deck. We both ran harder a-arms, cyclone rears and tamyia 415 fronts. I think Andy ran the cyclone a-arms up front because he used the wide offset PN racing steering blocks.
You can download it on the following link
www.clevelandcarpetracing.com/natssetup.pdf
Josh's prototype car looked great in both classes as well in Mod and 19T....
#1367
Team EAM
Originally Posted by aaron_buran
Both of our stallion's worked well, I felt I had a good car, but lacked in the horsepower department. I also DNS in round 3 which really hurt, due to a brain fart on my part. I will post my final setup shortly.
EA
#1368
I know EA, I don't know how these guys make rip all the time!
Even Andy said he though my car looked better than his on the track, maybe the setup was too safe.... My car certainly didn't run like Hermann's did on 3 wheel's in all the 180's!
Josh ran the same car he ran at the Novak....
#1369
Aaron,
Do you have some setup on both asphalt and carpet with rubber tires?
#1370
Sorry, rubber tires on carpet is against my religion
#1371
Anyway, thanks for the answer!
#1372
Here's one i used at a recent race to win the 19T class.
Extremely high grip carpet on rubber, LRP VTEC27
http://www.home.no/bergfeldt/Stallio...feldtalun1.pdf
Use the middle hole on the front shock tower..
#1373
hey great job guys at the nats...Hopefully I can do the same. I am going to regional carpet race out here in Socal this weekend. We are running rubber tire.
#1374
where did you get 4mm chassis from?
#1375
#1376
#1377
Here is my set up from the NAT's. I ended up 7th overall in Stock.
Let me know how it works if you try it.
#1378
Anyone know any online review for the stallion?
#1379
- c -
#1380
Ok, a few posts back I showed that I was having problems with my front spools. The C clip would break and the spool would be shreaded.
I found a guy that will make Stainless steel spools for me however the smallest number he can make is 10. I will plan on getting 2 of them but that would leave 8 left.
Would anyone else be willing to purchase one of them? Before I tell him to make them, just wanted to know if there would be any interests.
