Old 02-15-2007, 09:34 PM   #1336
Customworksking's Avatar
Trader Rating: 73 (100%+)
Talking
Originally Posted by Guo Chean
Hey Ky,
don't waste you money on those kit because Masaaki product is not cheap some more parts support are very bad. due to they only release limited quantity.
how was your new car feel? handling good?
after 500 + bucks I love to see a car I will never get as every maker U get 1 car they "pros" get others I make the B they make the A
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-16-2007, 09:37 AM   #1337
Scrad's Avatar
Trader Rating: 15 (100%+)
Does anyone out there have a setup for the Stallion on carpet with foams. I'd like a setup just in case. Thanks.
Scrad is offline   Reply With Quote
Old 02-16-2007, 09:46 AM   #1338
Arrow foam
go back a few and Jason Swift posted 1
Old 02-16-2007, 10:05 AM   #1339
Scrad's Avatar
Maybe I'm blind, but I can't find it. What is his screen name?
Old 02-16-2007, 10:22 AM   #1340
Default here u go
Originally Posted by Jason Swift
Sorry for the delay. Been very busy this week. Ok, my setup from this weekend's Express North/South Shoout-out is as follows:
Front - Shocks: 30 pound Corally springs with 60 wt AE oil. Middle hole on tower and inner hole on the arm. Hingepin blocks flat against the chassis. A blocks and 0* of toe. Camber links mounted in the inner, no shims under the ball. 1.5 degrees of camber. Stock ackerman positions. 1.5 droop.
Rear - Shocks : 22 pound Corally springs with 40 wt AE oil. Middle hole on the tower and inner hole on the arm. Front Hingepin mount flat on chassis and .5 mm shim under the rear mount. D blocks up front and F blocks in the back to give 1 degree of toe-in. Camber links made as short as possible, inner hole on the hub and inner hole on the inner mount w/ 1 mm shim under the ball stud. 1.5 droop.
CO27 - rolling out at 28. Parma Indigo/Magenta - 55.5
Very high bite carpet.
Swifty
this is it
Old 02-16-2007, 11:05 AM   #1341
Scrad's Avatar
Thanks. Are you going to the March Madness race at Allens? If I can get someone at work to switch days with me on Saturday I think I might try to go.
Old 02-16-2007, 11:07 AM   #1342
Default race
YES!
Old 02-18-2007, 06:20 PM   #1343
RandyB's Avatar
Originally Posted by Customworksking
can someone help me get the ICE off my car I got to get to work!!!
WTF
RandyB is offline   Reply With Quote
Old 02-26-2007, 09:08 AM   #1344
Default note
wanted to let everyone know that XRAY T2 a arms C hubs and knuckle's fit the stallion
Old 02-26-2007, 09:23 AM   #1345
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
won't they change the wheelbase, or shift the wheelbase rearward quite a bit due to their sweep? the kyosho stuff is reversible (symetric), the xray stuff sweeps like 6mm rearward, no?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 02-26-2007, 09:33 AM   #1346
Default car
I ran sunday with derw ellis I did try the caster block and kunckle but not the A-arm...josh run's all xray parts on his car
Old 02-26-2007, 09:43 AM   #1347
aaron_buran's Avatar
We are running the 415 front a-arms and the cyclone rears, it doesn't effect the wheelbase or track... . I am pretty sure track is way off, as well as your wheelbase.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 02-26-2007, 09:43 AM   #1348
Josh's arm mounts aren't the same as ours....
Old 02-26-2007, 09:48 AM   #1349
seaball's Avatar
yeah, the xray arms are also something like 2mm different in length from f/r. also, aren't the xray castor blocks using a 8mm offset versus the 6mm of the kyosho variety? was your track way narrower in the front when you put the xray parts on it?
Old 02-26-2007, 09:54 AM   #1350
Default car
I must say I put then on but after I seen my spool was broke I didnt run it I will need to check ....anyway how's the car running for you guy's ?
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
