Old 02-01-2007, 11:50 PM   #1306
H4gI's Avatar
yep...
if you need setup`s send a mail.
Team NFC
LRP
CAP
Nitro-mechanic-bitch of E.D. and R.V.
H4gI is offline   Reply With Quote
Old 02-02-2007, 09:28 AM   #1307
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default car
what tamiya shock pistons u running ?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-03-2007, 11:35 PM   #1308
Trader Rating: 55 (100%+)
kyosho have a few more parts for the stallion which should be available in the next couple of weeks.
TFW109 aluminium spur gear adaptor.
TFW110 aluminium sway bar mounts.
and for people running the tf5 shaft car there will also be an aluminium spur gear adaptor part #TFW052.
tones is offline   Reply With Quote
Old 02-05-2007, 12:57 AM   #1309
Send a message via ICQ to markrichards Send a message via AIM to markrichards Send a message via MSN to markrichards
Default starter setup for rubber on carpet
I'm after an initial setup for the stallion. Running on high grip carpet, with cs-22 rubber. At the moment the car is undrivable, spinning around on the slightest steering input.
thank you
markrichards is offline   Reply With Quote
Old 02-05-2007, 01:48 AM   #1310
H4gI's Avatar
Run with CS-27 and JB Blue inserts... CS-22 are too soft...
greetz
PS: The Car are very easy to drive with HPI Springs.
Team NFC
LRP
CAP
Old 02-05-2007, 08:02 AM   #1311
Lightbulb
thank you
where is your dual rate set?
add all the uptravel u can in the rear
wheel base: set it to where u only have 1mm shim at each end of the car.
Old 02-05-2007, 10:24 AM   #1312
Send a message via AIM to R/C Anonymous
thank you
is it possible you could have some binding going on somewhere> Seized bearings,etc...
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 02-05-2007, 10:35 AM   #1313
sosidge's Avatar
I agree, sounds like something is mechanically wrong if the car is looping around with any steering input.
More droop will help tame the car though, unscrew the shock ends by a couple of mm all round. Otherwise stock setting seems pretty good to me.
Old 02-05-2007, 10:35 AM   #1314
I can't change the tyres, rules of the championship
Nothing is binding.
Will try the spacer settings and I've thought about those HPi springs as the standard kit ones seem way to hard (possabley default setting is for foam racing ?? )
Old 02-05-2007, 02:00 PM   #1315
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I have a awesome setup i use on high grip tracks, mainly with LRP VTEC27 but ive tried it with CS22's too.
Feel free to try it.
http://www.home.no/bergfeldt/Stallio...feldtalun1.pdf
I see i used some swedish jibberish on the sheet..
Use the middle hole on the front shock tower and cover 75% of front tires with the used additive...
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-05-2007, 02:37 PM   #1316
Fervidsea's Avatar
Check the rear tires rubbing on the ball cup. At the first Florida state race it took me forever, along with others looking at the car, to finnally find out that was all that was doing it.
Shaved the ball cups down and perfect ride after that.
Hope this helps.
Fervidsea is offline   Reply With Quote
Old 02-06-2007, 12:18 AM   #1317
Default further investigation
i've been looking at this car now untill i'm almost blind. I noticed the ball cups were close to the inside of the wheel so i dremmel'd a bit off. What I eventually found to be the cause of the spinning is simple in what's happening but confusing as to why it is this way. The drive shaft on the left rear is slighly coming out of the diff half, causing that wheel to lock up.
It appears that either the drive shaft or diff half is not long enough. The really confusing part is this. THe picture on the box shows the front diff set to the right, main belt running on the speedo/reciever/servo side and the rear belt/diff to the left (as seen from the front)
The instructions show to build it the other way, pictures of cars at the DHI cup show it built the same as the box, promo shots show it the way of the instructions ! Just which side are the diffs ment to be ? Would swopping them over just cause the right side shaft to come out of the diff half instead ?? All very confusing
Thanks for that setup too.
Old 02-06-2007, 08:18 AM   #1318
I tried to flip the diff and for me the 1way and U can't do it the belt rubs the servo mount so the pic's we see r must have some other chassis .... be sure you have the right dog bone in the front and rear left/right the front is 43mm and the rear is 40mm
Old 02-07-2007, 09:09 PM   #1319
KyLayfield's Avatar
Trader Rating: 86 (99%+)
Check out Cyrul's prototype at the Bird's. The bulkheads are made out of woven carbon fiber! This thing is unreal!
KyLayfield is offline   Reply With Quote
Old 02-07-2007, 10:00 PM   #1320
Lightbulb car
same car as the novak
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
