Old 01-21-2007, 04:46 PM   #1276
Customworksking's Avatar
Trader Rating: 73 (100%+)
Post
Originally Posted by aaron_buran
Oh, I thought you said they did work, my bad.
Well back to the drawing board, I am going to use some other OEM's plastic on the car.
Stay tuned.
-A
the caster block's WORK not the other parts unless u get with Tim J
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-23-2007, 10:29 AM   #1277
Talking ti rods
Originally Posted by SpeedTech
Hi Guys,
Just want to post a quick note we have more TF-5 Stallion parts listed online. Belts and pulleys and some more hop-ups back in stock
Steve Wang
can U find a Ti-tirod set for the car or Red ti-rods ?
Old 01-24-2007, 03:10 PM   #1278
Fervidsea's Avatar
Default Blades? Sleeves?
Has anyone found a replacement Blade to replace the plastic ones for the alum diff and spools? I keep breaking them and the spool follows directly behind that.
Also has anyone found metal sleeves for the plastic spools and diffs? So they dont spread open?
Fervidsea is offline   Reply With Quote
Old 01-24-2007, 06:08 PM   #1279
jw92656's Avatar
Smile
TFW001-01
C-Joint adaptor
Due in stock in approx 2-3 weeks or sooner.
jw92656 is offline   Reply With Quote
Old 01-24-2007, 08:36 PM   #1280
Trader Rating: 55 (100%+)
hope this helps..
Originally Posted by tones
to bullet proof the plastic spool..
Yokomo ZS-501R Diff Joint Ring For MR-4BCS Front Diff
besides the color it is as if it was made for the kyosho.
then you need to bullet proof the center adapter otherwise it breaks where the hex pushes in on the side opposite to the pulley.
there are 2 ways of doing this.
#1 put the plastic sleeve close up against the pulley and use the red aluminium sleeve as a brace on the outside. i think you'll need to use a shim or two to stop the bearing from rubbing without filing a bevel on it.
#2 (the method i use) use the silver sleeve for the tf-5 that comes in the diff rebuild kit. cut it to the same size as the plastic sleeve and bevel the edges with a file so that it doesnt bind up on the bearing.
the only other problem i have had with the car is the motor shifting on tracks where breaks are used from high speed. have fixed for the most part by making up some slotted aluminium inserts to replace the o-rings in the motor plate (basically turns it into a standard style motor plate).
i think yokomo have discontinued that part number but still sell the same thing under a new one.
tones is offline   Reply With Quote
Old 01-25-2007, 02:08 AM   #1281
VoneSkip's Avatar
Trader Rating: 27 (100%+)
Send a message via MSN to VoneSkip
Gday Guys
Just have had my TF-5 SD Built , Would anyone be so kind and Help me out with a Good Starting Set-up with Rubber Tyres
Thanx in Advance ...
Skip
Team Destiny-A New Chassis - Top Quality and Value -PM me for further details
Hobbywing- For High performance ,Quality products.
PROAMPS - High performance Batteries and Servos - "When only the best will do"
TWT - For the ultimate Setup and Tweak boards.
S2H Bodies For all your custom Painting needs
VoneSkip is offline   Reply With Quote
Old 01-25-2007, 04:16 AM   #1282
sosidge's Avatar
Kit setup is pretty much spot on, all I did was dial in a bit more droop by lengthening the shocks (7 on the gauge front, 5 on the gauge rear).
Old 01-25-2007, 05:36 AM   #1283
Fervidsea's Avatar
Originally Posted by jw92656
TFW001-01
C-Joint adaptor
That is the part I am trying to replace.
Also thanks tones, I will use that for the sleeve.
Old 01-25-2007, 09:17 AM   #1284
7 and 5 less uptravle than 2 or 3 right ? what guage r u useing
Old 01-25-2007, 10:46 AM   #1285
VoneSkip's Avatar
Cheers
That Helps I will leave it at that and go from there ...
Looking forward to Trying it ..
Thanx for that ..
Skip
Old 01-25-2007, 03:11 PM   #1286
Scrad's Avatar
Trader Rating: 15 (100%+)
Skip are you running rubbers on carpet? If so I have a high traction setup and a low traction setup that work good. edit your sig say's permanent onroad track.
But really the kit setup is pretty damn good as is. Just add more up travel as stated earlier. About 2-3mm over ride height.
Scrad is offline   Reply With Quote
Old 01-25-2007, 04:31 PM   #1287
NT
NT's Avatar
Trader Rating: 21 (100%+)
Skip runs on outdoor asphalt I'm the one building his car
NT is offline   Reply With Quote
Old 01-26-2007, 02:17 AM   #1288
H4gI's Avatar
Hey
I`m the only one which drives the Stallion in Switzerland...
I have some Setup Sheets in PDF. If you need Setups, mail me greetz Hagi
PS: Only rubber tires
Team NFC
LRP
CAP
Nitro-mechanic-bitch of E.D. and R.V.
H4gI is offline   Reply With Quote
Old 01-28-2007, 07:29 AM   #1289
Scrad's Avatar
Has anyone played with the ackerman holes on the steering hubs? My SD is using the inside holes on the hubs. What will moving them to the outer hole give me. Less ackerman? I remember changing the steering hub holes on my 05 xray when the car would traction roll, but I can't remember which hole did what and I can't seem to find my setup notes.
Also what would adding a shim under the steering hub hole do? And what about removing the spacer on the rack?
My problem is whenever the track becomes high grip, my car seems to scrub too much speed in the middle of the corner. If I stiffen the car up to make it roll less, it makes is worse and will traction roll (too stiff). So I end up softening the front springs, leaning the shocks in and lower the roll centers. Now it won't traction roll and handles better but it ends up getting slower.
The best thing I've found is to lower the roll center, but keep the stiffer spring on the front with shocks leaned in. I've tried about everything I can think of and the ackerman is the next adjustment. Because the car handles really good, but it just seems to scrub too much.
Any suggestions? Thanks.
Old 01-28-2007, 08:31 AM   #1290
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I ususally run the outer/rear hole on my Stallion, it seems to make the car much easier to drive when the grip is high.
Just try and see what happens, it's a 1 minute job
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
