Old 01-16-2007, 12:27 AM   #1216
SpeedTech's Avatar
Originally Posted by Customworksking
Steve can U pm me when U get the new arms and other parts listed on your web site I have a order ready like to save on shipping ...thanks Kevin
Kevin,
The parts are in, and should be on the website tomorrow (couldn't get to it today...it was a long day) but I remember seeing pulleys, and some belts too.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-17-2007, 07:36 AM   #1217
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Toe In/Out
I need to have rear toe at 2.5 deg, and front toe at 1.5 deg...what cups/blocks do I use to get those numbers- the instructions are a bit confusing for me.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 01-17-2007, 08:12 AM   #1218
sosidge's Avatar
Basically each letter is 0.5 degree difference.
So, for 2.5 degree at the rear I would suggest B-block IN at the front (kit setting I think) and E-block OUT at the rear (I think this is kit setting too or maybe it is F in the kit). The letters are offset so in/out is easy to work out.
For the front, 1.5 degree out would be the D-block OUT.
At the rear you can also mess around with track width, if you ran say F IN at the front and A at the rear you would narrow the car by a few mm.
Old 01-17-2007, 08:39 AM   #1219
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
One good pic on Adachi's DHI-car.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-17-2007, 08:46 AM   #1220
sosidge's Avatar
No HPI arms on that...
I like the 5-cell chassis, neat design. How did Adachi do in the race?
Old 01-17-2007, 08:51 AM   #1221
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default toe
what I did is take the Kit stock fixed block from the front the 1 that u cant put the black toe pucks in and moved it to the rear so , A in the back of the 2 blocks and D D in ,in the front this setting will pull the arms in to the back of the car it's like having toe in @ the front of the car as well as the back U will need to re-center your wheels because this setting will give you toe out at the Front....hope this helps
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-17-2007, 08:56 AM   #1222
sosidge's Avatar
Found out that Adachi was in the C, Toni Rheinard was in the B.
Old 01-17-2007, 10:05 AM   #1223
celtic's Avatar
might sound like stupid question but what are the ajustable track ends for on the front if you get ur front toe from pin holders
celtic is offline   Reply With Quote
Old 01-17-2007, 10:26 AM   #1224
Default car
what do u mean pin holders..u talking about the suspension holder bushings they r the only way u can change the track ...max is 190mm
Old 01-17-2007, 08:51 PM   #1225
Scrad's Avatar
Trader Rating: 15 (100%+)
Does anyone know where you can get some 1/16 thrust balls? Preferably Ceramic or Carbide.
Nevermind, Acer has some.
Scrad is offline   Reply With Quote
Old 01-17-2007, 09:40 PM   #1226
VoneSkip's Avatar
Trader Rating: 27 (100%+)
Send a message via MSN to VoneSkip
I have got myself a Kyosho TF-5 SD heading my way , I hope i am Happy with my Purchase
Team Destiny-A New Chassis - Top Quality and Value -PM me for further details
Hobbywing- For High performance ,Quality products.
PROAMPS - High performance Batteries and Servos - "When only the best will do"
TWT - For the ultimate Setup and Tweak boards.
S2H Bodies For all your custom Painting needs
VoneSkip is offline   Reply With Quote
Old 01-17-2007, 09:56 PM   #1227
Default car
if its anything like the stallion U will be happy
Old 01-17-2007, 11:25 PM   #1228
NT
NT's Avatar
Trader Rating: 21 (100%+)
Guess that means i've got a build job coming my way soon?
NT is offline   Reply With Quote
Old 01-18-2007, 04:48 AM   #1229
celtic's Avatar
thanks dude makes sense now ran car on carpet rubber tyres at weekend set up front camber 1.5 toe out 0.5 bulk heads flat on chassis 1mm spacer inner top camber link yellow springs no roll bars. rear camber 1.5 bulk heads flat on chassis 3 toe in 1mm spacer inner upper camber link yellow springs no roll bar car was ok but lots of rolling about what do you suggest
Old 01-18-2007, 05:01 AM   #1230
sosidge's Avatar
Unless the carpet is very low grip or very bumpy, run the anti-roll bars. Makes the car a lot smoother and better balanced.
I normally try and get a decent no roll bar setting, then throw the bars on, always seems to make the car nicer on carpet.
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
