Old 01-08-2007, 04:37 AM   #1186
academygaz's Avatar
Originally Posted by luke humphrey
one of my mates was running the TF-5 belt driven car, and he was doing stock, he wasnt going that fast, clipped a corner, and it bent the rear left bulkhead like a banana!!! bent the motor can!!! weakness there!
It was the motor mount, and he hit (nearly side-on, like 70-75 deg angle) into a large heavy box. It bent on both an upper and lower screw hole, in such a place where its the weakest section of that part. I doubt any other car would have survived it.
Changed the part and went on to plant it firmly in the 19t A-main, was running 2nd until he got taken out!
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 01-08-2007, 04:58 AM   #1187
academygaz's Avatar
And here it is:
Old 01-08-2007, 09:42 AM   #1188
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
it was me that did it, whilst going flat out with a 19t, (not a slow incident)
not damage at all to rest of car nor the motor can
as said before ended up qual 2nd in 19t main.
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 01-08-2007, 09:48 AM   #1189
SpeedTech's Avatar
Hi Guys,
We just updated our Kyosho TF-5 and TF-5 Stallion section with a few new parts
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-08-2007, 09:48 AM   #1190
Customworksking's Avatar
Trader Rating: 73 (100%+)
Originally Posted by celtic
not a bad result dude its hard when only car hopefully more will join us let you no what i find this weekend
tell me what u r running on and i will let u know what i found works best for hight bite or even med bite i took my car to all the top team drivers for help and it worked the only thing i didn't try that was a matter making the A in both calsses i did know till the end of the day but what i can tell u will save u a lot of time !!!!!!!
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-08-2007, 09:56 AM   #1191
Originally Posted by SpeedTech
Hi Guys,
Steve Wang
thanx Steve your a man of your word !!!!
Old 01-08-2007, 10:34 AM   #1192
celtic's Avatar
racing on carpet with lrp vetec 24r tyres good grip normally thanks dude
celtic is offline   Reply With Quote
Old 01-08-2007, 10:46 AM   #1193
Scrad's Avatar
Trader Rating: 15 (100%+)
Custom, were you running a one-way? I forgot to tell you I was using one on my car at Trackside.
What did you end up with for a setup?
Scrad is offline   Reply With Quote
Old 01-08-2007, 12:47 PM   #1194
Post
ok my terms for droop is up travle from ride heigth.....
frt springs corally black 14.5 40wt AE oil 3hole A A blocks Diff position start with B,sus.arm spacer all to the front, knuckle spacer .03 sway bar blk, camber,start with 1.5 if need more steering go to 2deg but try no shims under your camber links 1st 2nd try removing the sway bar 3rd try hole # 2 on the bulk head... if u have too much streering rais the camber link ..shock hole#4 ..start with #2 sus.spacer if u have a exit push go to 1 and still pushes then flat and ...1way.. 5mm ride height and 2mm up travle if the car wants to traction roll got to 1mm uptravel or less camber,flater camber links no glue on side walls u want the car on the edge of traction rolling so,if u get it to roll over back off on side bite via camber and shims under camber links i had no problem entering but if u do go to .5 deg toe in on the front tires or A -B orA- C blocks in the front ,,steering wiper B mibble hole on with shaft #2hole on wiper
REAR corally 12.5 spring C in B out #2 under blocks if u have a push 1st try no Sus holder spacers under the front "if u can get it to work with no spacers all around do that I didn't have time to try it" silver sway bar,diff position B if u want less rear bite go to C ...camber link 1mm shim if u have a exit push go to 2mm,1.5 to 1mm camber and u still have a push rais the roll center to #3 hub carrier up. 2mm uptravel if it traction rolls got to 1mm and if it still rolls go up in oil AE 40 and if it still rolls go up in spring rate, hub spacer kit setting Sus Arm spacer shims to the back to have the wheel base short .camber hole 1,shocks hole 3.....Keep this in mind U want the car to roll over stop on the droop screws then roll into the shocks and if the shock springs r too stiff it will traction roll because of the springs r too stiff not cause of traction it's self so U want to rollover & rub the chassis then flip.. then u know it's very close so rais the roll center 2nd less camber 3rd camber links "flatter less side bite moving the shocks in will take away side bite as well and last go to thicker oil 5.5 ride height....I found a quick fix for traction rolling is springs and u want to do that last oil B4 springs because as the bite go's up your car will roll less and push/flip because it's not rolling into the suspension....shocks 62mm no pressure form...the car need's a 3rd front camber link and 2 and 3 deg rear hub's if i miss something let me know ..tires Cs27"s motor co27 gearing 100/25 2nd car novak 13.5 100/38..note dope the tires for3 to 5 min 1/2 frt full rear then wipe off if u leave in on too long it may roll so work with it and find what works for you at the time as the track changes
Old 01-09-2007, 11:09 AM   #1195
celtic's Avatar
Smile
Thanks dude give that a go nice to have some info for the car
Old 01-13-2007, 06:55 AM   #1196
KyLayfield's Avatar
Trader Rating: 86 (99%+)
Check out these prototype rear arms, and new chassis on the Stallions running at the DHI Cup this weekend.. -Ky
KyLayfield is offline   Reply With Quote
Old 01-13-2007, 08:39 AM   #1197
John Doucakis's Avatar
the 2nd photo is not from DHI.
Its from JMRCA 2006 finals
John Doucakis is offline   Reply With Quote
Old 01-13-2007, 08:50 AM   #1198
KyLayfield's Avatar
Yeah I know but it gives a better shot of the new chassis moving the batteries closer to the centerline. -Ky
Old 01-13-2007, 09:09 AM   #1199
Lightbulb car
I seen Josh Cyrul car at the 2007 novak the only thing that was the same as the stallion was the toe blocks....it was fast,he was on pace in every class but he said they didn't like it becaus it geared more for foam
Old 01-13-2007, 09:12 AM   #1200
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Yeap and Josh's car he ran at the Novak was one of the best looking and most ingenious top deck ideas on a TC I have seen in a long time!! It was PIMP and fast as hell too!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
