Kyosho Touring Car >
Kyosho Touring Car
Kyosho Touring Car
Old 12-15-2006, 04:57 PM
  #1126
ATOMIC's Avatar
Fervidsea - The 7mm and 4.5mm listing for sway bars is the amount of sway bar exposed past the ball . The pistons are kit pistons . The springs are made by Kyosho , not sure what the rating is. You can see the set up sheet on Kyosho Americas site. Not sure about the oneway as I have not used one.
ATOMIC is offline
Old 12-15-2006, 05:19 PM
  #1127
Fervidsea's Avatar
Anyone able to find an editable Setup sheet for the TF5 Stallion?
Fervidsea is offline
  #1128
Fervidsea's Avatar
Thanks Atomic for the explanations.
Old 12-16-2006, 08:03 AM
  #1129
Can someone post the roll-out for the shaft car please?
Andy who? is offline
Old 12-17-2006, 10:52 PM
  #1130
Customworksking's Avatar
Trader Rating: 74 (100%+)
Lightbulb stallion
I was looking @ the only 2 setups for the stallion R Atomic and Shinnosuke I see they both run 1.2mm offset hub carrier's now as it looks R Atomic runs A in E out =2mm + 1.2mm offset = 3.2mm toe right? and the other 1 runs C in E out =3 + 1.2mm off set =4.2mm toe is this right ? any other setups out u guy's know of..?
Customworksking is offline
Old 12-17-2006, 11:58 PM
  #1131
Trader Rating: 55 (100%+)
toe and offset are two different things... on the kyosho all the toe is inboard - the hubs are 0. so the amount from the inboard blocks is final.
the car comes standard with the 1.2mm offset hubs. i havent seen them but at a guess the 0mm hubs move the cvd intowards the car 1.2mm while still hinging in the same place, etc.
tones is offline
Old 12-18-2006, 12:03 AM
  #1132
you can find 3 more setups for the stallion here.
tones is offline
Old 12-18-2006, 09:45 AM
  #1133
GMartinez's Avatar
Trader Rating: 86 (100%+)
I will try to get you the set up I ran @ pnp the car was dialed would of had Tq if I did'nt stuff it @ the end.
GMartinez is offline
Old 12-18-2006, 10:34 AM
  #1134
Default right
be nice to have 2deg offset or 1 for 1 more tuneing option
Old 12-18-2006, 11:48 AM
  #1135
Fervidsea's Avatar
Thanks 710...
Using Atomics setup was good for me... still alittle loose in the rear, could've been my driving style since I SUX. But for the first time running the car, loved it.
Old 12-18-2006, 05:29 PM
  #1136
Red face novak
I didn't see any kyosho drivers sined up for the novak race or the 2 I know of
Old 12-18-2006, 07:45 PM
  #1137
Fervidsea's Avatar
Default Battery Strap
During my race this weekend the battery tape was cut about 6 laps into my 2nd qual. Has anyone tried to use another brand like xray, corally with any sucess. If so can you send pics? and ideas.
Old 12-18-2006, 08:36 PM
  #1138
Make sure you sand/dremel both top and bottom edges of the chassis slots where the tape goes thru...also put more tape across the top of the chassis where the tape comes thru the chassis
Barger is offline
Old 12-18-2006, 11:21 PM
  #1139
kidDynomite's Avatar
Absolutely! Prepping chassis is key. Here are some tips to help you round those corners.
http://www.teamcrc.com/crc/modules.p...d=16%5B/url%5D
kidDynomite is offline
Old 12-19-2006, 07:58 PM
  #1140
Fervidsea's Avatar
Default Pic
Picture of the my car during the race... Only have the one shot for now.
