Old 11-07-2006, 04:23 AM   #1066
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Originally Posted by sosidge
Droop
I was sent a PM asking how to get more droop out of the car. My answer is this...
To get more droop just run the shock ends a little bit unscrewed (I also put plastic spacers on the shaft to cover the exposed threads).
I run about 2mm extra length on both front and rear shocks - this gives me plenty of droop for rubber tyre racing. For small diameter foams you might even want to try longer shock ends like the medium cups on UM112.
try not to unscrew the rod ends too much, as the stock rod ends are quite weak and they pull off the shock shafts easily....
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 11-11-2006, 01:29 PM   #1067
Hi guys!
you have some pictures of TFW001-01?
What's part is this?
Thank you
Stallion forever!!!
Cla88 is offline   Reply With Quote
Old 11-12-2006, 01:39 PM   #1068
sosidge's Avatar
TFW001-01 is replacement blades for the optional alloy diffs and spools.
Old 11-12-2006, 02:19 PM   #1069
Thank you very much!!!
What springs and stabilizer bars are in the box with car?
Thanks a lot
Old 11-13-2006, 02:49 AM   #1070
sosidge's Avatar
Kyosho #34 - 1.5x4 for the front, #30 - 1.5x4.5 for the rear/ Stabiliser is 1.4mm for the front, 1.2mm for the rear.
Old 11-13-2006, 07:17 AM   #1071
Thank you again!
Old 11-15-2006, 05:41 PM   #1073
Thanks for the help with those parts. Alu. outdrives are a must for Modified foam racing. It still sucks to spend that kind of cash for a car and have to buy upgrades just to keep it on the track. I have played with setup a little more and its getting better. Changed rear toe and Front and rear roll centers. Also changed ackerman, although I had problems with center acker block hitting front pulley. More to come. Also any truth to an upgraded kit coming out soon?
saabdrifter is offline   Reply With Quote
Old 11-22-2006, 09:39 AM   #1074
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default stallion
Where can I find some setup's for the stallion ?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 11-22-2006, 10:47 AM   #1075
Tim Johnson's Avatar
Here are two Setups to check out
Rubber tire asphalt (ron atomic)
Rubber tire carpet (Adatchi)
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 11-22-2006, 10:53 AM   #1076
Try here,
http://www.kyosho.com/eng/support/se...tf5_index.html
http://www.kyosho.com/jpn/support/se...tf5_index.html
The japanese site has a few more for the shaft drive but you can get an idea.
Kyosho Evolva M3 / Kyosho Lazer ZX-5 SP / Xray T3
aantonis is offline   Reply With Quote
Old 11-22-2006, 11:55 AM   #1077
the two Setups i have posted are the latest setups.
Airtronics|Kyosho|
Old 11-22-2006, 12:07 PM   #1078
Default setup
thanx I want as many as I can get looking for stock rubber indoor carpet ...getting ready for the Novak race
Old 11-24-2006, 02:44 AM   #1079
nikoskar's Avatar
I just bought LRP 4 Star Brushless and Spere Competition.
Do you know what is the Stallion's internal Ratio?
I have the kit's spur 106.
Our Track has many tight turns and 2 medium straight and i dont know what pinion should i have.
Can you tell please?
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 11-24-2006, 03:52 AM   #1080
sosidge's Avatar
Internal ratio is 1.83:1 (says it on the side of the box).
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
