Old 11-02-2006, 05:45 AM   #1051
sosidge's Avatar
So that Yokomo part is a good fit without mods then? Do you have a part number?
Good discovery.
Old 11-02-2006, 07:31 AM   #1052
Trader Rating: 55 (100%+)
to bullet proof the plastic spool..
Yokomo ZS-501R Diff Joint Ring For MR-4BCS Front Diff
besides the color it is as if it was made for the kyosho.
then you need to bullet proof the center adapter otherwise it breaks where the hex pushes in on the side opposite to the pulley.
there are 2 ways of doing this.
#1 put the plastic sleeve close up against the pulley and use the red aluminium sleeve as a brace on the outside. i think you'll need to use a shim or two to stop the bearing from rubbing without filing a bevel on it.
#2 (the method i use) use the silver sleeve for the tf-5 that comes in the diff rebuild kit. cut it to the same size as the plastic sleeve and bevel the edges with a file so that it doesnt bind up on the bearing.
the only other problem i have had with the car is the motor shifting on tracks where breaks are used from high speed. have fixed for the most part by making up some slotted aluminium inserts to replace the o-rings in the motor plate (basically turns it into a standard style motor plate).
tones is offline   Reply With Quote
Old 11-02-2006, 07:43 PM   #1053
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Good discovery.
the part # is SD-630D, it fits on the tf5's rear input shaft, but dont expect it to fit 100% although no filing etc is needed. but some shims are needed to take up the spaces as this unit is slightly shorter in length compared to the kit unit. i've ran a few packs using this unit and so far its held up fine. alternatively, there's a light weight version from yokomo as well, but anodised blue which doesnt seem to go quite well with the red.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 11-02-2006, 08:23 PM   #1054
did anyone else here that their suppose to come out with a thicker chassis for the stallion?
bosfan is offline   Reply With Quote
Old 11-04-2006, 04:01 PM   #1055
GMartinez's Avatar
Trader Rating: 85 (100%+)
If anyone can post a gear chart for the shaft car it would be very helpful since i can't find my manual.
THANKS IN ADVANCE
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 11-04-2006, 04:25 PM   #1056
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
THANKS IN ADVANCE
well the internal drive ratio is 2.5 so divide the spur by pinion and multiply it by 2.5 = FDR
spur/pinion x 2.5 = fdr
Old 11-04-2006, 04:29 PM   #1057
Super Moderator
Marcos.J's Avatar
THANKS IN ADVANCE
George you can borrow my calculator tomorow
Old 11-04-2006, 04:50 PM   #1058
www.gearchart.com
use the above ratio to make a final drive chart
rollout chart
Barger is offline   Reply With Quote
Old 11-06-2006, 04:46 AM   #1059
Default FOR SOSIDE
Hi,I am thinking of buying a "STALION" are there any down sides to the car,also what extra parts do you advise me to get.thanks MARTIN
BREEZER is offline   Reply With Quote
Old 11-06-2006, 05:20 AM   #1060
sosidge's Avatar
Hi Martin, the only real weakness on the car is the plastic front spool (LA211 is the spare). I would try and source one or two of these as spares if you plan to run the spool (we are out at the moment, hopefully more in our next Kyosho delivery). The aluminium replacement should also be available shortly.
I've also broken a couple of the C-hubs/uprights (TF006-4), I don't think these are a weak part, I just clipped unforgiving corners at speed (or got punted into orbit by another car!), these are the parts that always break on tourers.
Other than that I think the post made by Barger a short while ago sums it up, the car just works out of the box. Can't ask for much more than that really!
Old 11-06-2006, 06:40 AM   #1061
Patriiick's Avatar
just got the aluminium version.. looks mighty solid (lots of material where needed).. even for a spool.
Comes with blades too.. a very nice touch
Patriiick is offline   Reply With Quote
Old 11-06-2006, 09:13 PM   #1062
GMartinez's Avatar
Thanks Marcos I had it geared correctly just could not remember the FDR
car was dialed let my son drive he was very rusty but got really comfortable in the mains couple of more practice races he will be on point.
Old 11-07-2006, 12:42 AM   #1063
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Shock towers are nice to have too, i broke a front one when another car went the wrong direction on the straight. Yokomo BD towers fit as a last solution.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 11-07-2006, 01:13 AM   #1064
nikoskar's Avatar
You run the Stallion with 5 or 6 cells?
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 11-07-2006, 04:07 AM   #1065
sosidge's Avatar
Droop
I was sent a PM asking how to get more droop out of the car. My answer is this...
To get more droop just run the shock ends a little bit unscrewed (I also put plastic spacers on the shaft to cover the exposed threads).
I run about 2mm extra length on both front and rear shocks - this gives me plenty of droop for rubber tyre racing. For small diameter foams you might even want to try longer shock ends like the medium cups on UM112.
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
