Kyosho Touring Car
#961
gearing
Originally Posted by Barger
We have 3 stallions locally in Australia...we have had them from 2 weeks to 1 month.One guy runs mod and 2 run stock.We are all very happy with the cars and in stock they are pretty much on the money out of the box.No tweak good turn in and great power out of corners
#963
Originally Posted by Customworksking
whats a good starting point stock spur and what pinion ? on rubber
#965
I got to test drive mine on Sat. The track has not been driven on since March so not alot of traction. The car felt pretty good. Our first warm up race is this Friday so I will get a full shake down once the track grooves up.
#967
How can i find the manual at pdf format?
#968
Protoform Dna Shell.
I am trying to elimate the edgey feel of a kyosho stallion with a one way for another driver. As he is an new starter I am wondering if the DNA shell gives the car more agression when cornering i just have to touch the steering and the car turns. Note it running a one way on carpet i manged to change the setup to lose the front endyness of the car it want to turn like a 1/12th scale with kit setup.
I did the following
took the front and rear roll bar off
moved the front shock in one
increased the droop from 4mm to 5mm
set front ride height 5mm and rear to 5.5mm
I could make it understeer more by either increasing the wheel base or changing the shock oil to slow the roll but i don't want to change the grip and handling too much
I am wodering the what the best way to raise the front roll center as i think this would be the next thing to play with.
i really think it need a spool or a front diff to suit the driver style of driving.
It running on sorex 24r on medium grip carpet the cureent setup feels awsome for me but i need it to handle an agressive style stock driver.
Also how loose can i go with the belts from kit setting
I did the following
#969
#970
The spool lasted one lap at sharley park! And the front c hubs why so much play in them we need about 2mm of spacer to take the play out of it.
#971
the parma alpha is more stable than the dna. considerably.
whoops, nevermind. i was thinking foams. sorry.
#972
#973
The included plastic spool is nothing but crap, i broke mine when passing another car and we barely touched each other...
I hope the Alu spool and diff joints are coming soon.
#974
bump
#975
The plastic outdrive do not look like they will hold up. I think you can make the zx-5 steel ones worn if you use zx diff rings. Cant wait for Alu. ones. Race on Friday, will report on progress.
