Old 02-18-2010, 11:22 AM   #2026
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
Default 5.5t fdr
hi may i know what gear ratio will be perfect for the tf5 shaft drive?im using 78t and 19t pinion right now but its slow me down on straight..
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 02-18-2010, 02:29 PM   #2027
stitchy's Avatar
Size of track/straight? ESC? Motor?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-19-2010, 11:04 AM   #2028
g-wan's Avatar
as for the motor im using hobbywing xerun 120A and 5.5t brushless motor,the track is outdoor,and technical track...
Old 03-29-2010, 10:39 PM   #2029
64buick's Avatar
Default gearing help!
Yes, theres still a few of us who run stallions. Anyhow Im running a tf-5 with a ballistic 17.5,tekinrs,and thunder power 100c.Our local club races parking lots and the length of the track is 160ft.Curious what gearing I should be taking on.
tf-5,slash mod,slash spec,hpi 5t,losi comp,mrc,t-maxx(custom electric)
64buick is offline   Reply With Quote
Old 05-20-2010, 06:55 PM   #2030
Trader Rating: 25 (100%+)
Hey guys, just wanted say hello to everyone, i'm a newbie. i just bought a TF-5 shaft drive as my first TC car. i own a Lazer SP and love it so much, i decided to try the TF-5! before you guys bash me about the "search button" i just wanted to say i did use it and i still could'nt find an answer. it actually got me more confused! well my problem is about gearing. according to the manual my gear ratio is 2.5:1. i know your suppose to divide spur/pinion x gear ratio = F.D.R. but thats where i get lost. i dont know what FDR is suppose to represent or what i use it for. i will be running 2 motors, a 10.5 and 13.5 Speed Passion v3 brushless motor. i am so confused what pinion gears to use. i will be buying on-line so i cant physically experiment what works for me. i just want a basic setup. i tried looking at everyones setup sheets but no one runs a 96t spur gear. everyone runs 100 and up. is there a reason why? for now i just want to stick to stock settings so i can practice and get the hang of it. i will be practicing on the streets until i build enough confidence to go to the local track. it is a small tight track with no straight aways, just twists and turns. any help would be appreciated. Thanks.
bomber9 is offline   Reply With Quote
Old 05-21-2010, 10:10 AM   #2031
Scrad's Avatar
Trader Rating: 15 (100%+)
What ESC you are running will determine what FDR you are looking for. If your running the SP with the newest firmware you will need to ask what people are shooting for in FDR with a 10.5 and a 13.5. It is just a ratio to figure out what gearing you should be running. For every full turn on the motor turns the the wheels on the car x amount of times.
I'd imagine something around a 5.5 or 6 to start with using the turbo firmware.
Then just plug in the numbers to get desired FDR. On my TF5 I'm running VTA so 4.3 is the lowest FDR your supposed to run.
I believer I have, spur 76 / pinion 39 x internal ratio 2.5 = 4.8 FDR.
If I wanted to go lower 76/42x2.5=4.5
Now if your running foam tires you need to figure gearing out as rollout and you have to measure the diameter of the tires.
Scrad is offline   Reply With Quote
Old 05-21-2010, 08:49 PM   #2032
Scrad, thanks for the help. i am running rubber tires and using the Futaba MC950CR esc. i was just on amainhobbies getting ready to order pinion gears 31 all the way to 43(odd numbers) because i thought no one would help me! so you say 5.5 to 6 just to start. does is that for both motors, 10.5 & 13.5? what set of pinion gears would you recommend me purchasing? Thanks.
Old 05-22-2010, 05:35 AM   #2033
32819toon's Avatar
Hi,
I'm running the SD and am struggling to find spur gears. I use the 48 pitch ones. Which other manufacturers spur gears will fit ?
Thanks,
32819toon
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 05-22-2010, 08:47 PM   #2034
Scrad's Avatar
I use the black kimbrough spurs and pinions. But robinson pinions work fine too.
bomber9, I really don't know what fdr you need with the futaba. I ran a 4.6 with my GTB and with a 17.5, but that esc doesn't have the turbo function. You need to find a FDR recommendation for guys that run the futaba.
I said 5.5 or so with the Speed Passion ESC, but that one has a turbo function. I would think starting around a 6 fdr would be ok and then adjust from there.
Old 01-27-2011, 03:25 AM   #2035
Default tf5 readyset questions
Hello there!
I need your help. I have the TF5 shaft driven Readyset.
It has front/rear ball diffs, but i want to use a front spool. If i order the TFW051 Aluminium Spool Shaft what else should i change? Are there any instructions for mounting it to my TF5?
A few months ago i bought TF006-4 Knuckle & Hub Carrier instead of LA-231-02 and i discovered that there are a lot of other parts that need to be changed. Can someone which parts are these? After fitting the TF006-4 the universals move in-out 2-3mm thus narrowing-widening the front.
Thanks in advance!
crusadores is offline   Reply With Quote
Old 01-28-2011, 07:08 AM   #2036
Scrad's Avatar
You should probably get another bevel gear set for the spool and the pin cushions for the dog bones have to be used on the aluminum spool.
Old 03-26-2011, 09:53 AM   #2037
DriftMonkeys's Avatar
Send a message via MSN to DriftMonkeys
Default Need info on Fdr for TF-5
Hello was wondering Whats the recomended fdr for zerotimming 11.5t?
and was wondering is Lower fdr = low temp .?
and what type of spur 48 or 64 pitch ?
thanks .
DriftMonkeys is offline   Reply With Quote
Old 05-16-2011, 02:29 PM   #2038
corallyman's Avatar
Trader Rating: 99 (100%+)
For those of you that own a Kyosho TF-5 Shin Edition, were are you guys buying parts? Overseas, Online, US based, any info would be helpfull.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 06-07-2011, 12:58 AM   #2039
RsageD's Avatar
Hello fellow TF5ers!
I was wondering about Gear ratio. I use a 5.5T 60a ezrun with an FDR of 8.125.
I run it on a fairly technical track. 78spur/24pinion. Kinda overheats after awhile.
Shall i try the 96s/32p? I will get 7.5 FDR.
Anyone know the stock FDR with the 20t motor?
Thanks in advance.
RsageD is offline   Reply With Quote
Old 06-07-2011, 01:56 AM   #2040
nice
amagad is offline   Reply With Quote
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
