Old 08-10-2009, 03:28 PM   #1966
stitchy's Avatar
Default TF-5 springs...
Can someone please tell me what kinds of springs I have here? The first springs on the left are silver, while the third one has a gold tint to it. The last ones on the right are silver with a bit of light blue paint on the bottom...
Or is there some kind of Kyosho on-road spring chart somewhere?
THANK YOU
edit: come to think of it...are these even Kyosho springs? (got this car used)
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 08-10-2009, 06:01 PM   #1967
Canyon's Avatar
Trader Rating: 8 (91%+)
Here's my ASPHALT RUBBER TIRE setup for the SHIN VERSION from this past weekends Summer Sizzler:
Front
Camber link: Hole 1 with 2.5mm spacer
Shock on tower: Hole 1
Shock on arm: Hole 2
Front suspension block: A w/0mm under
Rear suspension block: In C w/1mm under
Droop: 2mm of lift
Wheelbase: 2mm in front 1mm in rear
Diff height: A w/Spool
Ackerman: middle chassis and top plate block w/forward B in wiper. 1mm under balls on wiper. Outer balls upside down and in back hole on knuckle.
Ride height: 5mm
Toe: 0 deg
Camber: -1.5 per side
Sway bar: 1.3mm with 0mm sticking out
Shock: 3B piston with 500wt Kyosho oil and Xray 2.8 spring. Kit diaphram without the pressure foam. 62mm overall length with 0 percent rebound.
Rear
Camber link: Hole 1 with 1.5mm spacer. Hole 1 on hub w/0 spacers
Shock on tower: Hole 2
Shock on arm: Hole 1
Front suspension block: Out C w/1mm under
Rear suspension block: Out D w/1mm under
Droop: 1mm of lift
Wheelbase: 1mm in front 2mm in rear
Diff height: A w/aluminum diff halves
Ride height: 5mm
Camber: -2 per side
Sway bar: 1.2mm with 1mm sticking out
Hub height: Down. Hubs middle on arm (1mm front and back). Kit hub with 5mm hex's and .5mm wheel spacer.
Shock: 3B piston with 400wt Kyosho oil and Xray 2.6 spring. Kit diaphram without the pressure foam. 61.5mm overall length with 0 percent rebound.
General
SJR 36's with full sauce all around. Tire tweak Sauce. Sauce and heat for 15 min. Hacker 4.5 with 9.0fdr. Protoform Mazda Speed 6 body with stock wing. 1oz of weight in rear on chassis between suspension arms. 1/4oz in front between suspension arms.
Canyon Thompson
Canyon is offline   Reply With Quote
Old 08-11-2009, 08:21 AM   #1968
Scrad's Avatar
Trader Rating: 15 (100%+)
The silver ones with the paint are Kyosho springs. Some of those other ones look like Xray springs. I think the orange ones are HPI.
Scrad is offline   Reply With Quote
Old 10-23-2009, 08:55 AM   #1969
Trader Rating: 17 (100%+)
Default tf-5 readyset
Hi guys, I am off work for 3 months due to a motorcycle crash and am looking at doing a little indoor carpet racing when I am able to move around. Nothing too serious, I am mostly looking to get out of the house. How is the tf5 readyset? I would hope to pull the receiver out and put a spektrum in that I already have. Would this car be decent to practice on and to do some club racing?? Are the wheels standard mounting so I could get some foams for it?? Thank you in advance!!
Snopro440 is offline   Reply With Quote
Old 11-15-2009, 07:04 PM   #1970
rays_tt's Avatar
Trader Rating: 26 (100%+)
Hi guys i run a shin, but find it quite fragile, the spool's finally had enough and now just running a one-way but i guess for 540 i can live without a spool, however i've gone through all my spare knuckles and can't source any ... anyone got ideas on best place to buy from?
cheers!
www.melbRC.org
rays_tt is offline   Reply With Quote
Old 11-15-2009, 10:38 PM   #1971
blown sv's Avatar
R/C champ in japan will have them or get them , give them an email the service is awsome and they are very nice people to deal with, also shipping is cheap.
for 540 you probably should be running a oneway to keep corner speed up, i run a shin in mod and 10.5 and the spool is really the only weak part, but that can be fixed by using TOP spool sleeves over the out drives so they dont spread apart, look on the TOP web site and youll see them
chad
Ace Hobby Distributors Australia ,Team Associated, HobbyWing ,Proline Australia ,Plaig Bearings , JA Designs
blown sv is offline   Reply With Quote
Old 12-01-2009, 01:35 AM   #1972
Canyon's Avatar
Updated carpet setup for the Shin
Front
Camber link: Extended to bulkhead mount w/no spacers
Shock on tower: Hole 3
Front suspension block: A w/3mm under
Rear suspension block: In C w/2mm under
Droop: 2mm of lift
Wheelbase: 2mm in front/1mm in rear
Ackerman: Middle chassis and top plate block w/A in wiper. 1mm under balls on wiper. Outer balls upside down and in back hole on knuckle.
Ride height: 5.1mm
Toe: 0 deg
Camber: -2 per side
Shock: 3B piston with 550wt Kyosho oil and Xray 2.8 spring. Kit diaphram w/no pressure foam. 62mm overall length with 0 percent rebound.
Rear
Camber link: Hole 1 with .5mm spacer. Hole 1 on hub w/0 spacers
Shock on tower: Hole 5
Shock on arm: Hole 3
Front suspension block: A w/2mm under
Rear suspension block: Out B w/2mm under
Droop: 2mm of lift
Wheelbase: 3mm in front/0mm in rear
Ride height: 5.5mm
Sway bar: 1.2mm w/2.5mm sticking out
Shock: 3B piston with 350wt Kyosho oil and Xray 2.4 spring. Kit diaphram with no pressure foam. 61.5mm overall length with 0 percent rebound.
General
Jaco blues with full sauce all around. Sauce for 15 min. Hacker 13.5 with 4.4fdr. Protoform Mazda Speed 6 body with stock wing.
Canyon Thompson
Old 12-04-2009, 08:17 AM   #1973
MikaR's Avatar
Hello,
have the Kyosho TF-5 Readyset with Orion brushless 17T motor (stock spec class).
Spur is the stock 68T - now what size pinion gear would you suggest for it?
Have 20T, 24T and 31T (and the stock 38T).
Have a race coming tomorrow and it looks like the 24T is pretty okay. Seems like the 31T is too tall and the motor does not accelerate well...it kinda goes back and forth.. Accelaration looks good with the 24T, slightly worried of the top speed since the track is quite large...
Any experince anyone? Help much appreciated.
Thanks!
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 12-05-2009, 03:48 PM   #1974
Canyon's Avatar
Originally Posted by MikaR View Post
Hello,
Thanks!
What speed control and battery are you using? How large is the track? Carpet or asphalt?
Old 12-06-2009, 04:57 AM   #1975
MikaR's Avatar
Hi, good questions, thanks for responding -
it was medium size carpet track with very good grip, motor is 17T brushless Team Orion combo (don't know the exact model but it's a rather new one)
During the race day I tried out 24,26,27 and 31 pinions and settled with the 26T eventually. It was a rather good combination of acceleration and top speed and gave me the best lap times. Not sure but I calculated final gear ratio of something like 6.5 with that 26T pinion.
Old 12-06-2009, 08:30 AM   #1976
Scrad's Avatar
Are the gears on the ready set version 48 pitch? Because you should be around a 4.2 final drive with a 17.5 brushless running 64 pitch gears. spur/pinion x 2.5 = FD.
Old 12-06-2009, 02:42 PM   #1977
MikaR's Avatar
Yeah, readyset 48 pitch gears. So it is 68/26 x 2.5 = 6.5
I got so hooked on carpet racing that I'm planning to get the Stallion Shin -version
Old 12-06-2009, 06:58 PM   #1978
Canyon's Avatar
Scrad is right. Regardless of the pitch of your gears, your final drive ratio should be around 4.2 with a 17.5 motor. It also matters what speed control and battery you're running. The different speed control settings will determine a lot! Believe me, you will not be disappointed with the Shin version of the Stalion! Check out my setups above when you do get one.
Old 12-07-2009, 03:16 AM   #1979
MikaR's Avatar
ORION 4000 lipo
Thanks! I will propably get one soon (for Xmas)
Getting 4.2 final gear ratio would mean 40T pinion gear I believe which is way too large. I tried 31T and it was freakin fast but impossible to drive in the technical sections.
Is this correct:
4.2 = 68/x * 2.5
4.2 * x = 68 * 2.5
x = 68 * 2.5 / 4.2
x = 40T
Old 12-07-2009, 06:45 AM   #1980
TRF415boy's Avatar
I'm confused, the readysets come with a 27T brushed motor combo. Did you get a brushless system on top of that ?
TRF415boy is offline   Reply With Quote
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
