Old 12-03-2008, 03:39 AM   #1891
VoneSkip's Avatar
Trader Rating: 27 (100%+)
Send a message via MSN to VoneSkip
Originally Posted by Andy63 View Post
i think the new spool will fit the old car so i think you font have too buy new car anyway. What i can see on pics so should it fit.
Yeh but if it's a New Car I will have to have 1
Just hope that most of the other Parts fit
Team Destiny-A New Chassis - Top Quality and Value -PM me for further details
Hobbywing- For High performance ,Quality products.
PROAMPS - High performance Batteries and Servos - "When only the best will do"
TWT - For the ultimate Setup and Tweak boards.
S2H Bodies For all your custom Painting needs
VoneSkip is offline   Reply With Quote
Old 12-03-2008, 04:07 AM   #1892
Andy63's Avatar
I wouldnt hehe, the only difference a eye can see is the carbon(over) plate crossover the chassies, Spool, New steering construction. If you change that on your sjin you got exactly the same car.
I think the spool is the best part of the new car.
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 12-03-2008, 06:21 AM   #1893
pete68's Avatar
Default stallion
hi guy's is that a newer sedan from the big K
and what do you think of the car !!
are the parts weaks in strenght compare to a rdx
thanks
pete68
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 12-03-2008, 06:46 AM   #1894
Andy63's Avatar
I am sorry. That new car is just a prototype for the 2009 year Stallion car.
But the version thats out now is a good car. I Havent been in the 1:10th scale so long time yet but sofar i like it and the only bad thing with the old car is the spool. Bur the New Kyosho car will be much better. Just look at the worlds results. The car is fast 2.
The new car is the better choice if youre looking for a new car. The corally isnt bad, but i think Kyoshos car is easier too setup.
Old 12-07-2008, 02:45 PM   #1895
Andy63's Avatar
How many here will buy the new kyosho when it comes out? I will check if the spool fits on the SHIN car before i buy one
Old 12-09-2008, 07:48 AM   #1896
ITO NIEVES's Avatar
Hi, i`m new in the world of electric touring, i ran alwas nitro touring, i`m need some setting for a large track, i have a 3 turn LRP wiht lipo batteries, the car is out of the box, spur 106/ pinion 20.
CAPRICORN_ Lab C01---- Sirio XXXV.
ITO NIEVES is offline   Reply With Quote
Old 12-09-2008, 12:03 PM   #1897
ITO NIEVES's Avatar
And the track is medium traction and bumpy.
Old 12-09-2008, 12:10 PM   #1898
Canyon's Avatar
Trader Rating: 8 (91%+)
Asphalt or carpet? Rubber or foam tire? Shin or standard Stallion?
Canyon is offline   Reply With Quote
Old 12-09-2008, 01:30 PM   #1899
ITO NIEVES's Avatar
Asphalt, rubber and standard, thank you.
Old 12-09-2008, 02:59 PM   #1900
TRF415boy's Avatar
Just to point out guys, there is no certainty about the release of that car, as far as I know they might not even release it at all.
TRF415boy is offline   Reply With Quote
Old 12-09-2008, 09:50 PM   #1901
Canyon's Avatar
Start with this. It's Ron Atomics setup and it worked fairly well for me.
http://www.kyoshoamerica.com/downloa...2006-10-07.pdf
Canyon
Old 12-10-2008, 12:16 PM   #1902
ITO NIEVES's Avatar
Canyon
Thank you.
Old 12-10-2008, 12:31 PM   #1903
Canyon's Avatar
Thank you.
Anytime. Now if you step up to the Shin kit, I've got a DIALED setup for rubber tires on carpet.
Canyon
Old 12-13-2008, 08:22 PM   #1904
Patriiick's Avatar
they will release it .. just not ready yet.
Patriiick is offline   Reply With Quote
Old 01-01-2009, 10:05 PM   #1905
Canyon's Avatar
Dialed rubber tire carpet setup for the Shin
Front
Camber link: Hole 1 with 1mm spacer
Shock on tower: Hole 3
Shock on arm: Hole 2
Front suspension block: A w/1mm under
Rear suspension block: In B w/1mm under
Droop: 4.5
Wheelbase: 2mm in front 1mm in rear
Diff height: B w/Spool
Ackerman: middle chassis and top plate block w/forward B in wiper. 1mm under balls on wiper. Outer balls upside down and in front hole on knuckle.
Ride height: 5.1mm
Toe: 0 deg
Camber: -1.5 per side
Sway bar: 1.6mm with 3mm sticking out
Shock: 3B piston with 500wt Kyosho oil and Tamiya blue spring. Kit diaphram and pressure foam. 62mm overall length with 50 percent rebound.
Rear
Camber link: Hole 1 with 1mm spacer. Hole 1 on hub w/0 spacers
Shock on tower: Hole 4
Front suspension block: Out C w/1mm under
Rear suspension block: Out D w/1mm under
Droop: 5
Wheelbase: 1mm in front 2mm in rear
Diff height: B w/aluminum diff halves
Ride height: 5.1mm
Camber: -2 per side
Sway bar: 1.5mm w/ball ends flush
Hub height: Down. Hubs middle on arm (1mm front and back). Kit hub with 5mm hex's and .5mm wheel spacer.
Shock: 3B piston with 450wt Kyosho oil and Tamiya blue spring. Kit diaphram and pressure foam. 61.5mm overall length with 40 percent rebound.
General
Sorex 28's with full sauce all around. Sauce for 5 min. Hacker 13.5 with 4.5fdr. Protoform Mazda Speed 6 body with stock wing. 1oz of weight in rear on chassis between suspension arms. 1/4oz in front between suspension arms.
Canyon
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
