Kyosho Touring Car
Old 10-30-2008, 02:00 PM
  #1861
Canyon's Avatar
Trader Rating: 8 (91%+)
Hey just a little tip for those of you having problems with the aluminum front spool: replace the front wheel shaft with the same as the rear (LA231-02) but keep the same front swingshaft. This will space the swingshaft 2mm further into the aluminum spool making it a little stronger. You will need to add 2mm worth of spacers to the inside of the wheel shaft to space it properly. Use the plastic cup (LA211B) that captures the end of the stock plastic spool on the end of the aluminum spool to add even more strength. Add a dab of shoe goo to the plastic cup and it will stay on the spool and still be easy to remove when needed. I've run mine like this for about 3 months now and have had no problems at all.
Canyon
Canyon is offline
Old 11-05-2008, 01:15 PM
  #1862
Canyon's Avatar
Come on! Someone out there has to have some Shin parts. TF126 and TF132. I need them before the 13th for a race!!!! Someone hook it up.
Canyon
Canyon is offline
Old 11-15-2008, 03:53 PM
  #1863
TRF415boy's Avatar
Hi guys,
Here's a link to my setup for the Shin on high grip carpet in 10.5/lipo.
I used this setup to qualify and finish 3rd of the last round of carpet wars in the UK last week end.
Any questions feel free to ask.
Fab
TRF415boy is offline
Old 11-19-2008, 10:26 AM
  #1864
I'm sure someone has asked this question already but I couldn't find it anywhere....so here it goes.
Do people run lipo's with the Kyosho TF-5 Stallion? If so how do they keep them strapped down?
Bogi is offline
Old 11-19-2008, 10:30 AM
  #1865
TRF415boy's Avatar
I've machined a plate that not only adds the 200g missing to make the lipo to the same weight as a pack of cells, but also offsets the pack by 3mm to the right so the bulkhead isn't in the way anymore.
Old 11-19-2008, 10:48 AM
  #1866
So I guess I can't order one online then huh?
Bogi is offline
Old 11-19-2008, 10:50 AM
  #1867
TRF415boy's Avatar
Nope.... But maybe the cool can fan plates will fit ? Although they're not as good as mine
Old 11-19-2008, 11:01 AM
  #1868
Cool can fan plates? What's that?
Bogi is offline
Old 11-19-2008, 11:24 AM
  #1869
TRF415boy's Avatar
Sorry I can't find the thread about them, but there's that one
http://www.rctech.net/forum/electric...lone-xray.html
You can always ask him if he can make one that offsets the pack by 3/4 mm.
Old 11-19-2008, 02:10 PM
  #1870
Andy63's Avatar
Is there anyone know the best setup for the kyosho with 5 cells?
Andy63 is offline
Old 11-19-2008, 02:57 PM
  #1871
TRF415boy's Avatar
Is that the Shin or the original Stallion ?
Also what surface and tyres?
Old 11-19-2008, 03:03 PM
  #1872
Andy63's Avatar
ops, forgot to tell. Shin edition and indoor carpet with medium traction.
Andy63 is offline
Old 11-19-2008, 03:59 PM
  #1873
TRF415boy's Avatar
Try THIS SETUP
Should be nice and easy to drive.
Old 11-20-2008, 07:15 AM
  #1874
Andy63's Avatar
Thanks, i hope it will work nice on the track i will drive at.
Andy63 is offline
Old 11-20-2008, 10:21 PM
  #1875
Canyon's Avatar
So what are your opinions on the shorter rear arms compared to the original longer ones? What do they do for the car?
Canyon
Canyon is offline
