Old 08-06-2008, 03:05 PM   #1831
TRF415boy's Avatar
Originally Posted by dodo View Post
are those TRF dampers?
Yes they are
TRF415boy is offline   Reply With Quote
Old 08-06-2008, 06:03 PM   #1832
[[john]]'s Avatar
Trader Rating: 24 (100%+)
Originally Posted by I)arkness View Post
ive seen these on the net but cant ever seem to get one as they are always sold out, would they do just as good a job as the one you have
Brad, I think you might have trouble fitting that, Its for the KYSHO TF5..
[[john]] is offline   Reply With Quote
Old 08-20-2008, 05:44 AM   #1833
32819toon's Avatar
Default diff shaft
Which upgrade is the best, LA201 steel diff shaft, or TFW001 aluminium diff shaft ? Which is more durable ? I would have guessed the steel one, but it is much cheaper than TFW001.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 08-20-2008, 07:58 PM   #1834
I)arkness's Avatar
you would probably be better off with the steel ones, but saying that you could end up going through a lot more blades. im using the aluminum ones and wear the blades sit its worn down the outdrives.(will post a pic tonight to show you)
there are also some after market ones mad by 3racing i think for like $12.50US which are steel and dont use blades which also could be an option.
I)arkness is offline   Reply With Quote
Old 08-21-2008, 06:37 AM   #1835
32819toon's Avatar
Thanks I)arkness, I'm running the car for the first tme tonight with the stock set up and a 19T2 Orion motor and I have the Kyosho steel outdrives on order. I'll see how I get on.
32819toon
Old 08-25-2008, 04:35 AM   #1836
VoneSkip's Avatar
Trader Rating: 27 (100%+)
Send a message via MSN to VoneSkip
I know I asked this Question sometime ago
But has anybody herd if Kyosho are bringing out a New Model in the near future ?
I have tried contacting Kyosho but seem to get answers giving nothing away
Team Destiny-A New Chassis - Top Quality and Value -PM me for further details
Hobbywing- For High performance ,Quality products.
PROAMPS - High performance Batteries and Servos - "When only the best will do"
TWT - For the ultimate Setup and Tweak boards.
S2H Bodies For all your custom Painting needs
VoneSkip is offline   Reply With Quote
Old 08-25-2008, 04:57 AM   #1837
I)arkness's Avatar
well what i was going to try out in experimentation was to buy the 3 racing steel outdrives like i mentioned for both front and rear. but only use the diff in the rear, and i have some old team losi spool pads which are like $2 which you use instead of the balls, which then you tighten the sh!t out of it. to create a spools or looked diff.
thus not using any blades at all. solving the problem we have at the moment. but this could then create a problem of going through more universal shafts as the pin would wear.
but from what i can see happening skip is that many of the team drivers aren't using the standard one anyways so its likely to be improved or changed. its just a matter of time to when they release it
i would also like to see them release the chassis that many of the team drivers are using as well as it allows the use of lipos. As the current square lipos don't fit, only the the team orion stick pack configuration ones go into the shin chassis, due to where the spur gear shaft sits.
anyways talk to you more about it at wodonga.
Old 08-28-2008, 10:46 PM   #1838
ON A MISSION's Avatar
Trader Rating: 32 (100%+)
Default car
check my for sale thread's two kyosho tf-5 stallions and part's 310 shipped
ON A MISSION is offline   Reply With Quote
Old 09-02-2008, 10:42 PM   #1839
mrfunkyjay's Avatar
Hi guys, I wonder where u buy KYOSHO Stallion parts? I am in Indonesia and need spool for my Stallion, thanks!!
~R/C Drifting is more than Arts...~
"Currently looking for R/C Drift Team"
mrfunkyjay is offline   Reply With Quote
Old 09-03-2008, 01:36 AM   #1840
RC MARKET's Avatar
Kyosho KNUCKLE & HUB CARRIER 4
cleaner sale $4.67 only !
RC MARKET is offline   Reply With Quote
Old 09-05-2008, 05:24 AM   #1841
Trader Rating: 23 (100%+)
has anyone tried using standard TF005 arms on the Shin edition? i cant find TF133 arms anywhere and was thinking of using TF005. Does it make much difference on the Shin?
thanks
poop is offline   Reply With Quote
Old 09-05-2008, 05:39 AM   #1842
I)arkness's Avatar
i dont see why they shouldn't work, as long as you have the same arms on both sides of the car.
as you find many setups online that aren't using the tf133 arms in their setups sheets so they must still work just as good
Old 09-05-2008, 06:44 AM   #1843
thanks dark i'll give them a go. seems like that's the only choice i have...
Old 09-26-2008, 02:20 AM   #1844
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
for low/medium traction asphalt, what is a good starting setup for a TF-5 Readyset? Its gonna be running stock 27 turn with a lipo. I know balancing it is important but what about camber/toe/caster/etc? I plan on tightening down the front diff all the way and getting the rear to good point but i want to reach a more controllable yet performing setup (something easy to drive that'll do well) as this car is going to a rookie driver.
also, any idea what to gear it with a 27turn bluecan? (co27)
Syber Serulean is offline   Reply With Quote
Old 09-26-2008, 09:21 AM   #1845
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Look for Ron Atomics setup it should be on the kyosho.com homepage. Great starting point..
King of B Main is offline   Reply With Quote
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
