Old 03-23-2008, 08:39 AM   #1741
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Originally Posted by aaron_buran View Post
I sent him a note via ebay, no response? Do you know if he sells parts?
i send him too, no reply also. I dunno if he sell parts
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 03-25-2008, 10:23 PM   #1742
I)arkness's Avatar
after some suggestions on shock oil for the shin edition
having a bit of trouble getting the rear to keep traction at certain corners at my track,
i race outdoors on asphalt, low traction and bumpy. previously tried 35wt on front and 30wt on rear, but with no luck.
I)arkness is offline   Reply With Quote
Old 03-26-2008, 06:49 AM   #1743
Scrad's Avatar
Trader Rating: 15 (100%+)
Your weight seems about right how much rear toe are you running? You could try more toe or move the arms or rear hubs forward.
Scrad is offline   Reply With Quote
Old 03-26-2008, 01:45 PM   #1744
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
add more droop
King of B Main is offline   Reply With Quote
Old 03-27-2008, 12:55 AM   #1745
I)arkness's Avatar
ive been running with 3 degrees of toe in, which i think is too much so might try running with a bit less. i might try the more droop but find it hard to get droop while maintaining ride height.
Old 03-27-2008, 08:15 AM   #1746
Scrad's Avatar
Yeah 3 is enough. Try moving the arms or hubs forward or give it about 1.5-2mm of uptravel over ride height.
Old 03-27-2008, 08:54 AM   #1747
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
use the medium length lower shock ends, and you'll have plenty of droop...
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 03-27-2008, 09:28 AM   #1748
TRF415boy's Avatar
If you find that the rear ends steps out without warning and that the car is inconsistent because of that, I have experienced this problem last week end. Ultimately what cured it was to move the steering link position on the front hub to the rear. It changes the ackermann and smooths the steering action. I used the C-forward position on the bellcrank as well. Obviously you won't reach the stops on the C-Hubs when going full lock anymore, but I have found it not to be an issue at all, and I raced on a fairly tight carpet track.
TRF415boy is offline   Reply With Quote
Old 03-27-2008, 10:14 AM   #1749
Just unscrew the ball end caps as low as you can... Also I ended up using associated offroad spring retainers..
Another thing I use to do is when my rear end of my car would kick out, I would stand the rear shock up on the shock tower.
Good luck man
Old 03-27-2008, 11:43 AM   #1750
Mr. devenwhite's Avatar
do you have,
TF131
Aluminum Rear Suspension Holder L
(+3 / TF-5 Stallion SHIN)
TF133
Suspension Arm
(F&R/ TF-5 Stallion SHIN)
Mr. devenwhite is offline   Reply With Quote
Old 03-27-2008, 06:59 PM   #1751
SuperEk4's Avatar
u manage to get him?
Old 03-27-2008, 07:03 PM   #1752
aaron_buran's Avatar
Nope. So I moved the hole back on the chassis and am running the old linkage. with the old thick upper deck that Josh cut for me. The car is really getting good at our carpet track, it's keeping up with the RDX's and X-Ray's in 10.5 now.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 03-28-2008, 10:25 AM   #1753
SuperEk4's Avatar
So shin is not a good idea
Old 03-29-2008, 04:55 PM   #1754
kyosho is getting the rest of the shin parts in soon.
Old 04-10-2008, 04:01 AM   #1755
I)arkness's Avatar
does anyone know where you can buy kyosho tf-5 stallion shin parts apart from speedtech and off rc-champ, as tried finding looking for a reasonable kysoho parts seller and have had no luck in looking on the net
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
