Old 01-25-2008, 08:44 PM   #1696
ON A MISSION's Avatar
Trader Rating: 32 (100%+)
Default car
Any idea's if running the car setup with the esc in front of the motor will effect the car not having that weight in the back ??
ON A MISSION is offline   Reply With Quote
Old 01-26-2008, 06:53 AM   #1697
TRF415boy's Avatar
Originally Posted by Arn0 View Post
Do someone know TF5/Stallion spring rate?
There is 3 color, red, yellox and blue but no weight mentioned!
Just calculated them for you...
Kyosho Blue are 346.5 gf/mm -- 19.4 lb/in
Kyosho Yellow are 326 gf/mm -- 18.25 lb/in
Kyosho Red are 308 gf/mm -- 17.25 lb/in
Of course they are theoretical values, however I found that comparing theoretical values with measured values has always been pretty acurate.
A Tchô !
TRF415boy is offline   Reply With Quote
Old 01-26-2008, 08:24 AM   #1698
A Tchô !
Thanks a lot, that really nice, I did search during hours (at least one) with nothing more than part number!
Arn0 is offline   Reply With Quote
Old 01-26-2008, 10:33 AM   #1699
TRF415boy's Avatar
All you need are the dimensions and a good formula...
Old 01-26-2008, 11:18 AM   #1700
Shame on me, I have both formula and dimensions when I ask!
k=(Gd^4)/(8nD^3), G = 81500 N/mm² for steel, D = spring diameter (measured mid-mid wire), d = wire diameter, n = nbr of coil.
On my way to hang myself!
Old 01-27-2008, 01:23 AM   #1701
blown sv's Avatar
not at all, my stallion is as good as any car on the track
Ace Hobby Distributors Australia ,Team Associated, HobbyWing ,Proline Australia ,Plaig Bearings , JA Designs
blown sv is offline   Reply With Quote
Old 01-27-2008, 08:17 PM   #1702
Default car
I have mine set up with esc in the back and was thinking about redoing it like you car was set up .
Old 01-28-2008, 12:04 AM   #1703
blown sv's Avatar
you could try it, but i think you'd find most people would have the speedy in front of the motor, up to you really, i think in front would be better for the speedy cause it can get colder air to reduce thermal
Old 01-31-2008, 01:03 AM   #1704
SpeedTech's Avatar
Who has alot of parts in stock for a tf-5 stallion ????????
We have plenty of Stallion parts in stock. We also ship worldwide. Please let me know if I can help.
Cheers,
Jeff @ SpeedtechRC.com
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-31-2008, 10:55 AM   #1705
SuperEk4's Avatar
anyone here has knuckle binding problem? Any help? I am almost giving up, almost selling it. Someone told me to file the knuckle.
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 02-01-2008, 01:35 AM   #1706
Default problems
Have had no problems ,maybe post pics of the problem to get a visual
Old 02-01-2008, 06:28 AM   #1707
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
I would definately go back to your owner manual and make sure you are following the directions..I have never had any problems with the knuckles binding..
King of B Main is offline   Reply With Quote
Old 02-01-2008, 07:14 PM   #1708
SuperEk4's Avatar
each time i rebuild my car, when i screw the top ball screw & lower screw to secure the knuckle it get tight. I hv to loosen the screws till its smooth. But most of the time the screws are almost half way out. Thats the problem.
Old 02-01-2008, 09:16 PM   #1709
Scrad's Avatar
Trader Rating: 15 (100%+)
I put a really thin shim under the ballstud to keep the knuckle tight without binding. I think I got it out of the Losi shim kit.
Scrad is offline   Reply With Quote
Old 02-02-2008, 12:55 AM   #1710
I have never had that problem sorry...Are you sure you are putting the knuckle on right. There is a Top side and a bottom side.. The Top side has the lower stub to the knuckle and the bottom side is the big stub of the knuckle..
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
