Old 01-01-2008, 07:47 PM   #1681
Scrad's Avatar
Trader Rating: 15 (100%+)
Is anyone driving a Kyosho going to the Novak race besides me?
Scrad is offline   Reply With Quote
Old 01-24-2008, 02:20 AM   #1682
ON A MISSION's Avatar
Trader Rating: 32 (100%+)
Default parts
Who has alot of parts in stock for a tf-5 stallion ????????
ON A MISSION is offline   Reply With Quote
Old 01-24-2008, 08:29 AM   #1683
Do someone know TF5/Stallion spring rate?
There is 3 color, red, yellox and blue but no weight mentioned!
Arn0 is offline   Reply With Quote
Old 01-24-2008, 11:03 AM   #1684
94eg!'s Avatar
Trader Rating: 17 (100%+)
I recently helped a friend build a TF-5 Stallion, and I have a few questions:
1- Did anybody notice the servo saver horn is much bigger than the one shown in the manual? When assembled as shown, the link was too high causing it to hit the chassis. The fix was moving the link to an inner hole.
2- Did anybody have problems with the tie-rod turnbuckles hitting the rearward alloy suspension block? We had to flip the outer ball connectors to the top of the hub carriers just to get the steering to work.
Needless to say, these issues were a little dissapointing.
94eg! is offline   Reply With Quote
Old 01-24-2008, 11:13 AM   #1685
Default car
I did notice the servo saver hit the chassis but you have to shave the one side of the ball link if you look in the book it show how to do it ,also the droop is set way to low on your car you have to set it with the droop srews i had the same problem .it should fix the problem
Old 01-24-2008, 01:37 PM   #1686
94eg!'s Avatar
Thanks for the info with the ball link, but I'm quite sure we shaved it as stated in the book. Once we moved the ball to the more inward position on the saver, all is fine. It still have tons of steering angle on the wheels. I'll give it another once over next time I inspect the car...
As for the droop, I thought it might be the same thing, so we tried using the Ron Atomic asphalt settings. Even with only that 4mm of droop (from pan up to control arm tip), we were unable to avoid contacting the control arm block. Even with the car resting at 5mm ride height (w/ new Take-Off RP30 tires) the turnbuckles still hit.
The car seems to drive brilliantly with the ball links on top of the knuckles. This did cause minimal contact between tie-rod & the sway bar though. We moved to the sway-bar ball ends inward to give better clearance, but they still barely touch at full steering lock. I imagine this will stiffen the front sway a little bit...
Keep in mind that I have no real experience with competition cars, so I can't say for sure if the car drives well or not...
Old 01-24-2008, 02:52 PM   #1687
TRF415boy's Avatar
It probably don't as you've added a TON of bump steer. 4mm droop isn't enough on this car. I've got Steen Graversen's Prague setup and the front droop is 6mm. With this setting there is no contact. You could probably go to 5mm of droop but any lower value will result in the turnbuckles touching the toe block. Also what you might want to do, and any Stallion owners for that matter, is to mount the balls on the steering knuckle upside down. What I've done is to put a screw through it with a nut on the other side to hold it tight on the steering knuckle. This nearly eliminates the bump steer built in the suspension.
A picture is worht a thousand words so here you go...
TRF415boy is offline   Reply With Quote
Old 01-24-2008, 05:35 PM   #1688
Default pics
Those pics are very helpfull do you have more of you car curios on how you set up the elctronics ,please post if possible thanks
Old 01-25-2008, 03:23 AM   #1689
Default gearing
running a orion 10.5 with a 106 spur in the stallion any ideas for gearing ??/
Old 01-25-2008, 08:28 AM   #1690
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
I usually start around 5.0 final with a 10.5 orion
King of B Main is offline   Reply With Quote
Old 01-25-2008, 09:46 AM   #1691
TRF415boy's Avatar
I haven't put the electronics in yet, waiting for a spool so in the meantime i'm still using the old car... Have to say I was impressed by the quality of the parts, virtually no slop and the machining is to higher tolerances than with Tamiya, can't wait to put it on the track...
Old 01-25-2008, 04:28 PM   #1692
blown sv's Avatar
here are some pics, receiver is under the top deck on its side
Kyosho Touring Car-imgp1321.jpg   Kyosho Touring Car-imgp1322.jpg   Kyosho Touring Car-imgp1324.jpg
Ace Hobby Distributors Australia ,Team Associated, HobbyWing ,Proline Australia ,Plaig Bearings , JA Designs
blown sv is offline   Reply With Quote
Old 01-25-2008, 06:39 PM   #1693
Default pics
That looks nice what servo are you using ? i need to get a low profile servo,also are you using the 10.5 what pinnion are you using on that motor ??pinion,spur ???
Old 01-25-2008, 06:39 PM   #1694
Default pics
Old 01-25-2008, 07:31 PM   #1695
blown sv's Avatar
futaba 9550 low profile, its a 22t pinion but im using a 3.5 speed passion ,have to have a look what spur ,think its 104? with that pinion = 22mm roll out using rubbers
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
