Old 07-22-2007, 07:45 PM   #1531
Trader Rating: 23 (100%+)
Originally Posted by Scrad View Post
Is there a 5 cell chassis available? I remember seeing some pics of one of the Japanese drivers cars with the standard stallion bulks, but the cells were moved more in toward the centerline with 5 cells.
No word on that yet.
Originally Posted by idawina View Post
Hey guys i was wondering if someone could help me to find part number for the plastic outdrives used in the front spool for the stallion. They are listed as part 141 in the manual but there is no reference to part 141 in the spare parts listings!! please help!
Looks like the actual outdrive ring is #28. You might have to call K-America about the acutal parts tree number or Speedtech Rc. Steve at Speedtech might be able to give his inventory a quick look to see if it is included. It seems that the same part is used with the spool and diff sets. It might be in those part trees. If you are running the spool on a regular basis you might want to consider the aluminum spool. It works great.
Originally Posted by blown sv View Post
just a question for the pro's
i run on ashaplt ,medium grip using foams 40 shore, 3.5BL , blue front springs ,yellow rear, everything else is as per kit setting
having trouble with the rear snapping on weight transfer(say through a quick left right) ,has heaps of steering
any help
thanks
chad
I dont have experience running the car on asphalt with foams but..... you might want to start increasing the front spring rate and dampening. The setup might be a little soft for the foam tires. We either run foam on carpet or rubber on asphalt. Good luck. Let us know what you learn.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 07-23-2007, 02:06 AM   #1532
blown sv's Avatar
what springs are available ,which are harder than the blue kyosho? what other brands fit?
thanks
Ace Hobby Distributors Australia ,Team Associated, HobbyWing ,Proline Australia ,Plaig Bearings , JA Designs
blown sv is offline   Reply With Quote
Old 07-23-2007, 04:17 AM   #1533
Patriiick's Avatar
Hpi s and xray springs fit, just need to file a bit the top of the spring to "open up", you can use tamiyas but you need to unscrew the collar of the shock and put it upside down
Patriiick is offline   Reply With Quote
Old 07-23-2007, 08:42 AM   #1534
thanks
Kyosho Blue is approx 20lbs.
The HPI Springs will give you a good option.
White 20.3
Yellow 21.7
Red 22.4
TEAMORCA.SHOP
Old 07-24-2007, 02:13 AM   #1535
blown sv's Avatar
White 20.3
Yellow 21.7
Red 22.4
thanks guys
so we use a much softer spring compared to say corally , which aus team drivers use up to and around 40+lbs ,but the stallion has a very stiff chassis correct? so we'd use a much softer one to compansate?
chad
Old 07-24-2007, 08:31 AM   #1536
thanks guys
chad
The spring rate list I provided was to illustrate the heavier spring rates just a bit stiffer than the Kyosho blue.
The Stallion does has a relatively stiff chassis. Based on what other competitors are using on other cars should give you a better idea of what spring rate to use even if you have a different car. LIke I mentioned before we dont run electric classes like yours (foams on asphalt) here in the US except for carpet.
Ask the guys at your club what they are running, if you can, borrow some srpings from them and see what they do on your car.
It is really trial and error. There are a lot of variables that can also effect the setup you are working with.
TEAMORCA.SHOP
Old 07-26-2007, 07:00 AM   #1537
RC MARKET's Avatar
Here is my setup from Reedy for the Shin Edition.
The setup was originally developed for the Stallion - Steve Wang continued to run this after I converted my car over - the setup carried over really well.
Thanks your setup !
RC MARKET is offline   Reply With Quote
Old 07-26-2007, 07:16 AM   #1538
RC MARKET's Avatar
Thanks your setup !
Old 07-27-2007, 05:07 AM   #1539
hello:
pardon by my English of google.
I am interested in a TF-5 cardan joint, I have a Asso at the moment. TC4 + novak 3.5R + lipo, I am tired of the maintenance of the differentials of balls. my question is him can be put to the Tf-5 the back differential of satellite of the FW-05 or some of the mark.
a greeting and thank you very much
loloramos is offline   Reply With Quote
Old 07-27-2007, 09:03 AM   #1540
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Mark we are racing 13.5 stock at socal tonight. Should be fun .. Derick, Hiro, Taka,Me, Calvin,bitter ...Just in case you have no plans tonight..
King of B Main is offline   Reply With Quote
Old 07-27-2007, 05:29 PM   #1541
Thanks for the info; it is too bad that it is a hike from LA to the OC. Good luck.
TEAMORCA.SHOP
Old 07-29-2007, 06:35 PM   #1542
Hebiki's Avatar
Trader Rating: 26 (100%+)
mark... i think i read in here that the diff height can be adjusted on the kyosho car? if this is true.. what does that to do in terms of handling? (i.e. raising the rear diff over the normal position? or lowering it from normal position?)
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-29-2007, 07:55 PM   #1543
My notes around this are;
All Diffs...
-high, will make the car run flat but more responsive.
-low, will increase onpower steering
Generally...
-high rear, low front = most steering.
How is this going to help you with a Tamiya car
TEAMORCA.SHOP
Old 07-29-2007, 08:42 PM   #1544
Hebiki's Avatar
All Diffs...
Generally...
thanks! TA05MS has diffs that can be adjusted height wise
Hebiki Design Works
Old 08-03-2007, 12:42 AM   #1545
POOKYT's Avatar
Any word as for pricing or availability of the Shinn edition?
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Kyosho TF-5 Competition Touring Car controlledchaos R/C Items: For Sale/Trade 9 10-16-2010 10:18 PM
New Kyosho Touring kit from Championship r1champ Electric On-Road 4 01-22-2008 11:17 AM
FS/FT: KYOSHO NITRO TOURING CAR RTR FUJIMO R/C Items: For Sale/Trade 9 01-05-2007 12:06 PM
Kyosho EP Touring car ChadCapece Electric On-Road 20 03-20-2005 03:16 PM
Kyosho KX-One touring car slamminsam R/C Items: For Sale/Trade 4 02-19-2002 09:13 PM
