Old 04-08-2005, 11:11 AM   #1
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
Default RDX - Tech, Tuning and Setup Tips
This thread is only for tech and tuning questions ideas and exchange for racing.
If you want to chitchat or otherwise meet your fellow RDX racers around the world view the corally RDX general thread.
Cheers
BadBoyRC is offline   Reply With Quote
Old 04-08-2005, 11:19 AM   #2
Default cool
im in dude SoCAL in the house
lickrim is offline   Reply With Quote
Old 04-09-2005, 06:05 PM   #3
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Yeah, good idea
How would you distribut those 8 & 5 grames golden weights for a well balanced chassis?
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 04-09-2005, 11:49 PM   #4
Trader Rating: 15 (100%+)
Default ultra lows
Ran the ultra lows last night and car was dialed.Smooth and predictable .
If anybody needs a rubber tire setup for carpet email for details.
AARON YOUNG is offline   Reply With Quote
Old 04-10-2005, 06:03 AM   #5
Pat
Send a message via AIM to Pat Send a message via Yahoo to Pat
Hi MSB.
I have found that the RDX needs some extra weight on the battery side of the chassis. This is because the batteries have been moved inward and the motor has been moved out slightly on the other side. The standard car is quite underweight though which compensates for the balancing weight required. I'd suggest putting four 8-gram weights in the back right corner behind the battery, and then evenly spread any other weight to get your car to the legal limit.
Aaron, by 'ultra lows' do you mean the custom lowered shock towers that people have been making? Sorry, I haven't kept up with the other RDX thread. What handling characteristics have you found with this modification?
Pat.
Pat is offline   Reply With Quote
Old 04-10-2005, 06:15 AM   #6
RayWarner's Avatar
Send a message via AIM to RayWarner
Hey BadBoy does thismean no more pics of "chasis"?
Has anyone run the ultra low blocks on asphault?
Ray
RayWarner is offline   Reply With Quote
Old 04-10-2005, 06:32 AM   #7
corallyman's Avatar
Trader Rating: 99 (100%+)
Default Ultra low
Pat,
I believe he means ultra low roll center mounts for the arms.
Aaron would you please pm me your rubber set up. I have not found one yet myself, but I will get it sooner or later. Are you running mod or stock or 19t.
Thanks,
Steve
corallyman is offline   Reply With Quote
Old 04-10-2005, 07:21 AM   #8
Rob Phillips's Avatar
Why take up server space for a double thread? I would just use the one that's already there.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 04-10-2005, 10:17 AM   #9
Default Lowered roll center blocks
I will post it here tonight ..Im on my way to go practice ..and will have some setups for asphalt tonight ..
Old 04-10-2005, 04:34 PM   #10
MSB
MSB's Avatar
Originally posted by Pat
Hi MSB.
Pat.
Much obliged Pat.
cheers
Miguel S. Braga
Old 04-10-2005, 11:46 PM   #11
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Rear Toe adjustments ????
Anyone knows if there is a handling difference in using toe spacer compared to using -2 degree rear blocks?
Another one is: What the best way to lower the spring retainers up in front. Is there an option or should I just shorten the lower ball cup for the retainers to sit lower?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-10-2005, 11:57 PM   #12
Korey Harbke's Avatar
Well generally when you use the stock 0 deg carriers you have to use shims to get the toe in. Since it sweeps the arms forward you are shortening the rear wheelbase. This will give you a little more initial steering, but will put more weight over the rear tires. If you use the 2 deg carriers, you wotn nee shims. There wont be any arm sweep, and wheelbase will bit a bit longer. This puts a little bit less weight over the rear tires so it might give a touch mroe on power steering. The pins are also parallel to the centerline of the chassis, and that is when the suspension is most efficient. So there is a combination of things that it could do. I'm not totally sure since I have not tried it yet.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-11-2005, 12:00 AM   #13
edseb's Avatar
Seemes like a lot of you talk about lowering the shock tower up front, but does it really help or is it just cosmetic and if it is better for handling, could it be donr somewhere else onthe car to get the same results? The other post about it seems like it was mostly cosmetic.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 04-11-2005, 12:15 AM   #14
Default setups
carpet rubber tires
caster 4deg,
7mm droop,
no kickup,
1deg toe out,
camber 1.5,
ride height 5mm,
low roll blocks 190mm wide,
1.3 pistons 60wt,
spring 19lbs,
1hole in on top and all the way out on arm,
x-hard arms ,
oneway and std ackerman.and second hole on bottom for camber link,
rear
0 deg anti squat,
toe 1.5,camber 1.5,5mm droop,ride height 5mm,low role blocks,shocks 1.3 with 40 wt,17 lbs spring, outside hole on tower and extension on lower arm.camber link one hole in on bottom.
stock wheel base,ride mk3 stratus,losi alpha wing,
Old 04-11-2005, 10:11 AM   #15
Lowering the shock tower enables your to just lower the body. I guess it can give you a little more steering since your body is a bit lower, but it does look cool when you can slam a sedan body down
-Korey
Tuning tips for O.S. VZ-B??? jbish4 Nitro Off-Road 1 10-17-2007 10:02 PM
TECH TIPS OF THE DAY LOWGEARED Electric Off-Road 5 03-16-2007 09:51 PM
Tuning Tips. sl4ppinb4ss3r Electric On-Road 21 07-13-2006 04:35 PM
mp 777 sp 2? looking for any tuning tips gabbyb3 Electric Off-Road 2 03-05-2006 06:10 PM
New Build & Tuning - Tips Pls :) joshb Australian Racing 9 12-20-2002 11:42 PM
