Old 07-29-2002, 11:55 PM   #1
fatdoggy's Avatar
R/C Tech Charter Subscriber
Default Psycho TX cells ????
Hmmmm I run 1500 nimh cells in my TX, I've taken ok care of them discharging(by leaving TX on) and charging (at .5amps) and they have grown to about 2000mah, well I discharged them yesterday and forgot about them for 2 hours, leaving the TX on, then last night when I turned it on it still had some juice in then so I left them on for an hour. Hmm now the plot thinkens, They've been charging for 5 and a half hours and they just keep going, there up to over 3000mah and still rising, should I turn then off? there not hot and only slightly warm. Have I blow up my cells? Right now they have more capacity then my 2400 matched packs it's kind of freeking me out. What should I do?
Thanks.
fatdoggy is offline   Reply With Quote
Old 07-29-2002, 11:57 PM   #2
Moderator
Speedo's Avatar
stop it and check the voltage on each cell with a voltimeter.
Speedo is offline   Reply With Quote
Old 07-29-2002, 11:59 PM   #3
fatdoggy's Avatar
I have no volt meter.
Old 07-30-2002, 12:00 AM   #4
fatdoggy's Avatar
But it says on my charger that the current voltage is 12.25 volts. WHich is normal right?
Old 07-30-2002, 12:19 AM   #5
Moderator
Speedo's Avatar
That sounds ok
Often you can use your charger as a voltimeter, just touch the negative to the negative and positive to the positive and watch the volts.
Josh
Old 07-30-2002, 12:22 AM   #6
fatdoggy's Avatar
Nearly 3300mah 6 hours and 10 mins. Shoudl I kill the charge or let then go for it?
Old 07-30-2002, 12:26 AM   #7
Moderator
Speedo's Avatar
I would stop charging and put them in your radio and see how they are
Old 07-30-2002, 12:28 AM   #8
fatdoggy's Avatar
Ok I'll shut it down, thanks for the help speedo.
Old 07-30-2002, 07:26 AM   #9
work's Avatar
That happened to me too! Fatdoggy are you using Sanyo 1500mah twicells?
work is offline   Reply With Quote
Old 07-30-2002, 08:37 PM   #10
fatdoggy's Avatar
When it happened to you did you shut it down or did it stop charging by itself? Just wondering if it would actually shut down by itself at all.
No, I'm using "telepower" cells made by JBRO batteries, Lisle, IL.
Cheers.
Old 07-31-2002, 12:45 AM   #11
work's Avatar
I stopped the charging, it was going on for about 2 hrs. I didn't want my batts to die on me. But now the volts seemed to drop to 11v.
Old 07-31-2002, 01:13 AM   #12
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
What charger are you using?
Keep an eye on the voltage... it should keep going up, untill it starts to peak. it will hold steady for a minute or so..then the voltage will drop by .01 or more. A drop of .01 i would keep charging, .03 i would stop.
I charge my TX pack at one amp, and its a 600ma pack.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 07-31-2002, 04:48 AM   #13
fatdoggy's Avatar
Thanks for the info troy, I'm using a 16x9. After a fresh charge mine has about 11.5v's.
Old 07-31-2002, 11:42 AM   #14
RCTech Member #2
TSR6's Avatar
If it's not peaking, just keep an eye on the voltage.
I just walk into the room every couple minutes and peek at the T-35, see whats up.
Troy
RCTech Member #2
Old 08-01-2002, 02:20 AM   #15
You canot really derive capacity from charge time, this only relates to the energy put into the cells, which in this case, sounds like quite a lot. Your cells could have a large internal resistance, causing them to loose alot of charge energy to heat, without them getting all that warm because of the low charge rate over a long period of time. It sounds as though the charger is just not detecting the peak, and the fact that they aren't getting hot because of this is due to the low charge rate.
sleek the elite is offline   Reply With Quote
Psycho Nitro blast opinion thread scubajt41 Georgia Racing 101 03-23-2011 08:13 AM
Psycho Nitro Blast II - The Relapse Feb 6-8 2009 toolmbx6 Texas Racing 16 02-04-2009 08:31 PM
Psycho Nitro Blast II - The Relapse Feb 6-8 2009 toolmbx6 Tennessee-Kentucky Racing 18 02-03-2009 07:45 PM
FS/FT Hotbodies Revolution wheels/ Psycho tires Ur Next R/C Items: For Sale/Trade 5 12-20-2005 08:39 AM
