Old 04-07-2005, 10:17 AM   #1
Tamiya shock pistons in pro 4.
Hi, in the uk hpi driver andy moore uses tamiys shock pistons in his pro 4,has any one done this? and if so can you tell me where to get them or does any one know the part numbers for these parts.
Thanks,
Phill c is offline   Reply With Quote
Old 04-07-2005, 10:21 AM   #2
RCGaryK's Avatar
They do fit, I measured them with a caliper and the diameter is virtually identical.
53572- 2 hole pistons
53573- 3 hole pistons
Both available from Speedtech RC, here's the link:
http://www.speedtechrc.com/store/ebp...?catmainid=262
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-07-2005, 10:29 AM   #3
Thats great thanks.
Old 04-07-2005, 10:31 AM   #4
RCGaryK's Avatar
Anytime. And Steve/Speedtech does ship internationally too.
HorizonHobby.Com
Old 04-07-2005, 10:34 AM   #5
Why not just use the the Tamiya TRF Flourine shocks entirely? They are the smoothest TC shocks on the planet. And that's hard for me to say because I don't really care for Tamiya products as a whole.
Chris
ApexPredator is offline   Reply With Quote
Old 04-07-2005, 10:37 AM   #6
RCGaryK's Avatar
The HPI's are pretty darn close to the TRF shocks. The plastic pistons that come with the HPI shocks just aren't as smooth as the Teflon TRF ones
HorizonHobby.Com
Old 04-07-2005, 10:49 AM   #7
Yes i use speedtech alot, there is a package on its way to me now, but i have to put a large order together to cover the postage costs. i might get the teflon shocks, but will they come with the 2 hole and 3 hole pistons.
Old 04-07-2005, 11:01 AM   #8
J-P
J-P's Avatar
Hi Phill,
ive run them for 6 months now and they really good. the reason that andy and other drivers use them is because they are machined and not moulded so they are true. thats what he explained to me. i use the no3 pistons you can get them from rainbow ten in japan
J-P
J-P is offline   Reply With Quote
Old 04-08-2005, 07:23 AM   #9
Spud_J's Avatar
You will also want to use a very thin 0.005" (0.15mm) motor shim between the e-clip and the piston to take out the enfloat. The piston is just a tiny bit thinner than the HPI one and you will end up with a small deadspot if you dont use a shim.....you will see what I mean!
Once you have done that they will be silky smooth. The pistons really do make a difference in these dampers. Beautiful and easy to build.
We used the 3 hole pistons most of the time here in the UK.
Hope that helps
Spud_J is offline   Reply With Quote
Old 04-08-2005, 08:24 AM   #10
Cool
Thank you all for your help, i will try it out at ashby in the next round of torque.
Old 04-08-2005, 08:39 AM   #11
Spud_J's Avatar
You will want to be pretty soft at Ashby with all those bumps Phil. Think we ran 35wt front and 30wt rear with XRay white springs all round (17.5lbs)
Quite a lot of droop as well.
Steve
Old 04-08-2005, 09:14 AM   #12
I have got andy moores set up sheet from last year and am going to start with that.
Old 04-08-2005, 09:33 AM   #13
Spud_J's Avatar
Never a bad place to start!
Tamiya TRF shock 3 hole pistons GSM Storm Australia Wanted to Buy 2 01-02-2008 06:42 AM
Fioroni Dual Action Ergal Shock Pistons HHHOGGG Electric Off-Road 0 03-25-2007 09:50 PM
Losi & AE Shock Pistons lightning lee Electric Off-Road 5 11-07-2006 12:48 AM
Kyoso K3 shock pistons WANTED maxxman101 R/C Items: Wanted to Buy 1 07-19-2005 05:37 PM
RPM valved shock pistons timmay70 Electric Off-Road 12 02-06-2004 03:47 PM
