Old 12-07-2012, 11:06 AM   #1
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
Default Parts Fab Contractor?
If I want to have some parts fabbed, does anyone know of a low price place that does small production runs?
I've got a custom designed bumper part I'm working on. In some sort of flexible plastic or maybe kevlar. Looking for a production run of 50 or less, at around $5-$8 per part maybe. Just starting to explore the idea.
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 12-07-2012, 01:22 PM   #2
AdrianM's Avatar
You will have to be friends with the owner of a machine shop to get a run that small made at that price. Most machine shops charge ~$135 per hour for small run work.
If you have production drawings with in CAD or Solid works you will charged an hour to set up cutter/laser/water jet paths. If you have a hand drawing they will have to draw the part in their CAD CAM system before they can do anything and that will be another hour.
Add 1-3 hours for setup (if fixtures are complex and need to be designed and made) plus the cost for any material needed for fixtures to hold your part while its being cut/machined.
Add the cost of your raw material of choice
If its a simple 2D part add about an hour of machine time for 8 parts.
You would be looking at ~$750 to $1000 to prototype 8 parts.
If you were confident the product was viable you get 100 pcs made for ~$10ea
1000 pcs would end up costing $2 to $3 each depending on your raw material.
Adrian Martinez
Old 12-07-2012, 01:25 PM   #3
Plexabit's Avatar
You could buy a $1200 3D printer and fab your own parts. Not sure how strong it would be, but hey, if they break, soon you would be able to just grind up the plastic and reuse it. Cool, huh?
Please pray for the worms.
For they are victims of global worming.
Plexabit is offline   Reply With Quote
Old 12-07-2012, 01:34 PM   #4
The Captain's Avatar
Do some google searching, there are places where you can upload your file and businesses will bid on the job.
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 12-07-2012, 01:36 PM   #5
Not for anywhere near $5-$8 per piece. That's barely material costs in most cases.
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 12-07-2012, 01:45 PM   #6
Hmmm, what about molding or injection molding? any tips on prototyping that way maybe?
Old 12-07-2012, 01:51 PM   #7
Regional Moderator
CarbonJoe's Avatar
Injection molding would never happen for anything that small. Injection molds run anywhere from $15K - $30K if they're made in China, more if made here.
Why not invest in a small milling machine like a Sherline and make them yourself?
http://www.sherline.com/
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-07-2012, 02:08 PM   #8
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
3 hours to set up a cnc is retarded.
We can do any 2.5d millwork in minutes direct from solidworks and alpha cam lol. But that would be a typical
Machine shop rate. Paying all overhead and still making a little cash.
If
You can design the component to be cut in 2.5d and the machinist doesnt have to touch it after putting the stock in, could be cheap to make a single peice then copy it using smooth on products.
Maybe not as technical as xrays plastics but smoothon makes pretty much any casting resin you could want to use.
The task series would be my choice for impact absorbing parts.
Of course. I dont know your technical ability. So it could be more or less hard. Of course. All this stuff we take for geanted before had to be made somehow before cncs and injection molding in china came around.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 12-07-2012, 02:08 PM   #9
Appreciate the tip!
Old 12-07-2012, 02:17 PM   #10
If
Ok one more noob question. If I can make it out of a pair of strictly 2d parts and assemble it myself, how much easier / cheaper does that make it?
Old 12-07-2012, 02:22 PM   #11
Not really. Depending on size, most places would just use scrap.
-Derrick-
Old 12-07-2012, 02:25 PM   #12
valk's Avatar
Try emachineshop.
My stuff
My RC
Old 12-07-2012, 03:59 PM   #13
Lessen's Avatar
Send a message via MSN to Lessen
Try emachineshop.
I have fiddled around with that software a bit. Super easy to use even if you have zero technical drawing experience.
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 12-07-2012, 05:11 PM   #14
hanulec's Avatar
Trader Rating: 27 (100%+)
I tell everyone -- one piece or 100... Costs at least 1k.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-07-2012, 05:22 PM   #15
vabroom's Avatar
I been meaning to see this place, sounds like you be able to fabricate your parts. On the website is the location of all the shops, maybe one near you.
http://www.techshop.ws/
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
