Old 12-06-2012, 07:44 PM   #1
Default Tamiya M chassis? Worth the build?
I'm looking for a fun but cheap build this winter. I've always wanted to build a Tamiya M Chassis Mini Cooper but never had the chance. Anyone have experience with one? They look like lots of fun!
Any recommended upgrades for good performance?
Thanksn
Jongrill is offline   Reply With Quote
Old 12-06-2012, 07:55 PM   #2
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Nearly 1200 pages for you to read. Enjoy!
http://www.rctech.net/forum/electric...ni-cooper.html
Yes. They're a fun car, but can be challenging to drive sometimes compared to a 4WD car.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 12-06-2012, 08:07 PM   #3
PERFECT! I better get to reading!
Challenging how? Steering? I would figure as much since its 2wd. Anything specific?
Old 12-06-2012, 10:07 PM   #4
c-lyon's Avatar
Also check out www.rc-mini.net.
c-lyon is offline   Reply With Quote
Old 12-07-2012, 12:54 AM   #5
jmellipse's Avatar
Buy a fwd (the m-03 is still very capable !) and find some local racing. Best and cheapest fun you will ever have on-road ;-)
jmellipse is offline   Reply With Quote
Old 12-07-2012, 02:00 AM   #6
Sith Lord's Avatar
Just completely different to 4WD Touring Cars. If you've never driven them, then don't worry. Yes, steering, throttle control, wheel spin/traction. All different, but all good fun (once you get the tyre selection right for the surface you're running on)
Old 12-07-2012, 02:39 AM   #7
Trader Rating: 15 (100%+)
don't u hate those super long threads?...it's annoying as hell...good thing there's such as thing as a search function...
IvVaum is offline   Reply With Quote
Old 12-07-2012, 05:51 AM   #8
orcadigital's Avatar
Trader Rating: 61 (100%+)
We just started a mini class at our local track and it has been great so far. I built up an M05 and it was a fun build. I had a large supply of hex head 3mm screws to replace most of the phillips ones that come with the kit and I pretapped the holes in the plastics (more durable in my experience, plus better with my carpal tunnel). Only non-stock items so far are the titanium king pins (mostly due to them not being phillips heads) and a set of left over plastic (but oil filled) Sakura shocks and the Tamiya short TC springs to go with.
Car is a hoot, and with the stock setup (adjusted ride height so the lower suspension arms are flat), the thing was cake to drive. It's slow (new unbroken in motor and a questionable nimh battery), but was a blast.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 12-07-2012, 06:46 AM   #9
Thanks!
I was looking at A M05
Never driven one so I think I'm in fir a treat! Only driven 4WD cars
AWESOME! Looks like I'm going to build a stock one for now. What do you plan on doing to the car?
Old 12-07-2012, 07:10 AM   #10
Thanks!
Only had it out one night so far. Took my time building and painting the body (got thr Alfa Romeo Mito). I'd recommend anything other then the friction shocks, but otherwise, I am not sure anything is needed. I did pick up a gear diff (oil filled Spec-R) which I have not installed yet , and holding off on bearings (the spec-R uses different bearings) as I may go to aluminum knuckles/uprights and they use a different size then the plastics (thinking in terms of durability really). Right now, just enjoying the car. I will also add that I have the Tamiya stiff servo saver setup with a 3Racing aluminum horn. They came with some car bits I bought a while back and just happen to be a perfect match for this. Using the Tamiya kit ESC and motor still as well.
Finished 4th in the 1st race (7 cars). My first time out with it (ran one practice battery before the qualifiers), and was beat by am M06 and 2 M03's, none of which were remotely stock, and all by better drivers. Running it again tonight and will see how it goes.
Old 12-07-2012, 07:16 AM   #11
If you plan to race in the TCS (Tamiya Championship Series) you need to read the rules section to see what is legal. The only change I made is picking up a set of Tamiya TRF shocks and springs for the Mini (worth the money). The rest is stock.
This is a fun class that is more driver than car though set up is still important.
AreCee is offline   Reply With Quote
Old 12-07-2012, 07:22 AM   #12
Not sure if I'm up for racing. I just build cars to run on my block. I've never raced... Ever!
Old 12-07-2012, 07:42 AM   #13
Still the best upgrade you can do is a good set of shocks. Tamiya plastic mini shocks work well and won't break the bank. You'll need those when running on uneven streets or else it will bounce all over the place.
Old 12-07-2012, 07:57 AM   #14
SteveM's Avatar
Trader Rating: 142 (100%+)
The M-chassis cars from Tamiya are a blast, but if you're competing on a high level the costs rise rapidly and you can easily end up spending more than you might on a top level sedan.
SteveM is offline   Reply With Quote
Old 12-07-2012, 09:36 AM   #15
Ok. M05 or M06?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22989 Yesterday 04:00 PM
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 03:12 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
