Old 12-03-2012, 04:10 PM   #1
Default Problem with Orca VX after ver 3.0 upgrade
Hi,
I have just upgraded to version 3 and it went fine into the esc its the program card i cant upgrade to ver 3 saying its not compatible my program card is code: P/N: OPC111VS for the VX. Any help will be greatly received thanks.
Scott
scottyf01 is offline   Reply With Quote
Old 12-03-2012, 04:22 PM   #2
stikman's Avatar
Originally Posted by scottyf01 View Post
Hi,
Scott
are you sure you are using the right files for the program card? it is different from the ESC
stikman is offline   Reply With Quote
Old 12-03-2012, 04:55 PM   #3
Hi,
Scott
What is the file name that you were using for the update?
Regards,
Ian
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 12-03-2012, 05:03 PM   #4
If you didn't update the program card too it wouldn't work, that's for sure.
Be sure to plug the card correctly on the USB link, sounds silky but happened to me.
You shouldn't have any issue.
mojo tom is offline   Reply With Quote
Old 12-04-2012, 03:06 AM   #5
I updated the usb to link installer V1.2 then updated the esc to VX ver 3.0 1209220 which all was fine then tried to update the program card to ver 3.0 1209220 which then said it was not compatible im not sure why????
Am i updating in the right order? does it have to be done in a certain order? will keep trying thanks for your replies.
Old 12-04-2012, 03:41 AM   #6
What do you guys use to open the bin file for the program card ver 3.0?
Old 12-04-2012, 04:10 AM   #7
There are two separate files for the esc and the program box
**Destiny RX-10s**Futaba**Trinity**Montech**SpeedyRC
Madmaxaus is offline   Reply With Quote
