Old 12-01-2012, 05:27 AM   #1
cyclone's Avatar
Default which charger?
Hi guys,
I have an LRP touch but don't really like it for some reason..
Buying a charger used to be pretty obviously, lrp, orion, and much more (since lipo's)
Now though I go to buy a charger and get completely confused..
What charger do you guys think is the best, best value, best interface, features charger to spend your money on?
Thanks!
cyclone is offline   Reply With Quote
Old 12-01-2012, 10:39 AM   #2
NolanP's Avatar
Originally Posted by cyclone View Post
Hi guys,
Thanks!
I am a huge fan of my Orion charger. I have the advantage touch. It only charges at 6amps but you don't really need more than that. It shows the graph on the balance and exactly which cell is charged to what. It has been dead accurate at big races on the voltage which sounds stupid but at a roar race being spot on is very handy so you don't miss qualifiers or races. It's 1 cell capacity seems to be .1 over but thats also an easy fix. The touch screen does make life very easy as well. You put in the mah of your battery. 2cell or 1. Balance or no balance. Plus its ac/dc.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 12-01-2012, 11:54 AM   #3
scootr117's Avatar
iCharger 106b..
Charges all the types of batteries RC uses
Adjustable endpoint for voltage
Small
Inexpensive by comparison
10Amp max charge rate.
As mentioned before. having a charger that is consistent and has the option to be set for a desired voltage helps at races where the batteries are teched. I did tech at the Champs last weekend and I had several racers need to burn off voltage to pass. Some races will DQ if you try to go thru over max voltage.
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 12-01-2012, 12:12 PM   #4
Unfortunately my Orion Advantage Twin Spec has not been that faithful. At last year's IIC it charged everything just fine...at this year it charged everything over.
I"ll be picking up a new charger this month as well...so far I'm looking at the Hyperion, Thunder Power, and the iChargers as I hear good things about all of them.
Old 12-01-2012, 01:50 PM   #5
Geezatec's Avatar
For a few years, RC Cars and RC Airplanes I've been useing.
Bantam e-Station BC-6 BCDXDX-ii AC/DC or
Bantam e-Station BC8DP AC/DC
with no problems. Use it on every battery I need to charge up. NiMd, lipo's, LiFe's, and PB's. www.RCaccessory.com to look into it. Also has discharging functions. And accessories for the Charger.
Geezatec is offline   Reply With Quote
Old 12-01-2012, 02:05 PM   #6
Honestly, I do not believe you can go wrong with the Orion Advantage Touch. It is an awesome charger that has all the functions you could ask for.
Mikes Hobby Shop--> mikeshobbyshop.com
-Viper-RC Solutions-
Team Tree Top!
Damon_English is offline   Reply With Quote
Old 12-01-2012, 02:09 PM   #7
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
have nothing bad to say about my Thunder power charger. I might actually drop the $275 for their twin charger lol.
small, quiet can charge at 10 amps with a strong power supply. zero complaints.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 12-01-2012, 03:12 PM   #8
Odin544's Avatar
Trader Rating: 93 (100%+)
I have the Thunder Power TP820CD. By far the best charger I have owned. Has 2 ports and can charge up to 20amps per port if you were to need it to. Measure IR. A little spendy but well worth it.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 12-01-2012, 04:55 PM   #9
you have the best-LRP Touch!
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 12-01-2012, 05:16 PM   #10
Trader Rating: 60 (100%+)
Powerlab 8 hands down. You need to use your computer to really get it all dialed in, but it will handle ANYTHING you may ever charge. 6s helicoper, 2s TC, 1s 1/12th scale, parallel charge (4) 4s batteries simultaneously at 40A....ect. It's nearly endless.
MC112b is offline   Reply With Quote
Old 12-01-2012, 06:59 PM   #11
abailey21's Avatar
Trader Rating: 36 (100%+)
My Orion Touch has been the best charger since selling my GFX
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-02-2012, 07:21 AM   #12
nwv327's Avatar
whats everyones opinion on the dt ice 8amp chargers? back when lipos first came out these things were extremely popular
xray t3/t4 viper vtx10r/vst, tc3 VTA novack edge/ballistic , rc18r reedy , losi muggy, axial exo MM2/castle 1415, losi 8ight T 2.0 /castle 1515/MM2 , proboat blackjack29 hobbywing 130 HV/turnigy super edf 6s =)
nwv327 is offline   Reply With Quote
Old 12-02-2012, 08:13 AM   #13
UrabusDenis's Avatar
I use a Graupner charger, charges up to 20 amp and is very well priced. Most of the top guys here use it or the LRP touch. Dont know if you can get in the US though
Alpha Plus - alpha-rc.com
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 12-02-2012, 08:58 AM   #14
nwv327's Avatar
i have an original graupner systems racing catamaran so a matching graupner charger would be nice
Old 12-02-2012, 02:39 PM   #15
GFX 35.
mackin is offline   Reply With Quote
Which charger- Dynam DC6 Doublepower or Dynam DC6 supermate? Redlinez Radio and Electronics 7 02-11-2011 02:12 PM
Which charger? dont slow down Radio and Electronics 33 07-22-2009 08:49 AM
Which Charger? lp3233 Rookie Zone 23 01-21-2006 08:22 PM
which charger??? in the market for a new one jaejw1 Electric Off-Road 17 11-16-2005 04:17 PM
