Like Tree2Likes
Old 10-03-2005, 12:35 PM   #1471
Regional Moderator
Darkseid's Avatar
When you guys use the TRF shocks on the TA05, what is the overall length of the shocks when your finished.
From tip-to-tip or from inside the upper mounting portion-to-inside the bottom mounting portion. Either one will do.
I took a look at the instructions while I wait for my kit, and I noticed they don't mention a specific length that the shocks should be when finished. I just want to compare the length of the TRF units to some of my other shocks.
Thanks.
TLR 22...Tamiya F104...
Old 10-03-2005, 12:44 PM   #1472
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Will a Cyclone TC2 (43mm x 28mm) fit in the TA05's rather restrictive ESC space? I know my LRP Runner and F1 Pro (40mm x 40mm) can't, there's not enough room between the motor and the back, but there is some more room from the side to the middle... just wondering how much. I can't look at the chassis since I'm away, and there's a TC2 someone's offering...
Thanks,
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-03-2005, 12:51 PM   #1473
Jam-ehz's Avatar
Thanks.
Hmm.. they probably don't make much of a note of it because the shocks will always be able to extend longer than what your droop screws will allow the arm to move. I know when I built a TT-01 you had to use O-rings inside to adjust the droop.. ugh.. thankfully that's all in the past
Old 10-03-2005, 01:50 PM   #1474
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Can anyone tell me the difference between #49293 shocks and the #49355 shocks?? do both work on the 05? thanks
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-03-2005, 02:11 PM   #1475
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I believe the 49293 are not completely blue...the adjuster nut is black...the 49355 everything is blue including the nut. The 49355 are the "Limited Editions".
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 10-03-2005, 02:21 PM   #1476
axle182's Avatar
Ive seen pics with the 49293 with everything blue, i was more worried that they were different lengths etc? as long as they are both the same dimensions, im happy thanks
Aaron "AJ" Freind
Old 10-03-2005, 02:27 PM   #1477
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
49355 have the flourine colored bodies, blue caps (top and bottom) that are ribbed. They also have the aluminum adjuster that has an oring in it. And the adjuster is blue. But it uses the black plastic lower spring retainer.
The 49293 uses the aluminum lower spring retainer
They are both the same otherwise
tamiyarcracer is offline   Reply With Quote
Old 10-03-2005, 02:45 PM   #1478
I have the 49293 on my TA05, so I know those work.
Old 10-03-2005, 04:17 PM   #1479
nekmiyevo2's Avatar
does it hurt a lot if I run the car in the parking log?
thanks
nekmiyevo2 is offline   Reply With Quote
Old 10-03-2005, 04:33 PM   #1480
axle182's Avatar
it will hurt the car ALOT if you run it into a log! lol it depends on the carpark. Its its clean and gravel free, and nice n smooth, just adjust your ride height a bit to give it clearance over any bumps or gravel on the surface. Thats if your worried about scratches etc. But if you dont care, just drive it how u like. but definately cover the open holes in the chassis with tape. Id even tape over the motor slot, but check the motor temp every 1-2 minutes.
Aaron "AJ" Freind
Old 10-03-2005, 04:39 PM   #1481
nekmiyevo2's Avatar
why do you need to cover the holes? to block the sand and rocks?
I am just worry that if the sand gets into the belt and the gear... what would happen?
Old 10-03-2005, 04:43 PM   #1482
I have run mine twice now on a parking lot for club days, first day I taped up the holes, second day, I didn't, and there wasn't any difference realy, actualy, thats a fib.... When I taped the holes up, I had the rear belt flip on me, so not sure if that was a ston trapped....
DA_cookie_monst is offline   Reply With Quote
Old 10-03-2005, 04:46 PM   #1483
nekmiyevo2's Avatar
what is the highest and lowest height that I can adjust?
thanks
Old 10-03-2005, 08:01 PM   #1484
JimmyMac's Avatar
Dark... all my TRF shocks are 62mm long (EvoIV/TA05/415). Hope that helps..
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-04-2005, 07:48 AM   #1485
TFR
TFR's Avatar
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
