Like Tree2Likes
Old 09-26-2005, 09:14 PM   #1411
topgluer's Avatar
Originally Posted by cheehtae
Towerhobbies.com
Thercshack.com- you can actually pre-order any parts from them, just give them the part number that you need , they are Illinois base.
www.rcKenon.com or www.KenonHobby.com
topgluer is offline   Reply With Quote
Old 09-27-2005, 04:43 AM   #1412
Are there any aftermarket parts for a casing over the belt to stop stones getting into the gears?
Seatbelt is offline   Reply With Quote
Old 09-27-2005, 05:35 AM   #1413
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Originally Posted by loopedeloop
Has anybody from the US ordered from here?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 09-27-2005, 06:42 AM   #1414
SpeedTech's Avatar
Originally Posted by kenny
Also,
Does anyone know of an online store that sells replacement and hop-up parts for the TA05?
Hi Kenny,
Here's a direct link to our TA05 parts section:
TA05 spare and hop-up parts
Let me know if you need further help ( [email protected] )
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 09-27-2005, 08:23 AM   #1415
rayhuang's Avatar
Can someone get Fred Medel to post his Vegas set-up on here? I plan on running my ta05 on carpet/rubbers Friday night.
Thanks,
Ray
Old 09-27-2005, 11:44 AM   #1416
SpeedTech's Avatar
Thanks,
Ray
I think Fred ran the 415 this past weekend
Steve Wang
Old 09-27-2005, 03:12 PM   #1417
neosan's Avatar
Default Suspension mount
Hi guys,
Just a little help ! I'm thinking buying the suspension mount for my TA05 with LW suspension. I wanna go X-series. I should buy :
Inner bridge suspension mount(A), outer front sm XA and outer rear sm XC ?
cheers
neosan is offline   Reply With Quote
Old 09-29-2005, 06:42 AM   #1418
Do any of you guys run your TA-05 in asphaslt? Like where there are some small stones and uneven surfaces? How does the TA-05 perform on surfaces like those?
Old 09-29-2005, 06:51 AM   #1419
First time I ran the car propetly was on an unprepaired carpark, taped up the holes in the chassis, worked fine (glad it was carbon fibre I scratched though!!!).
DA_cookie_monst is offline   Reply With Quote
Old 09-29-2005, 07:27 AM   #1420
The TA05 goes fine in the asphaslt ...
Only the open diff are not so happy with the little dirt ... they need to be clean and rebuild after 10-15 packs.
e_lm_70
PS: If you use 0.4 module like me ... is better to check & clean the spoor time to time.
e_lm_70 is offline   Reply With Quote
Old 09-29-2005, 09:48 AM   #1421
rayhuang's Avatar
Default Carpet/rubber tire starting set-up
Hey guys,
I dont really know where to start on a rubber tire/ozite set-up-so if you dnt mind-I'll post my set-up thats on the car and if youd offer chnages and why-I'd be much obliged. The track is 90x50 and grip will be med/high. Cars bone stock except for uni's and CF rear shock tower. Ferrari kit body or Nismo skyline.
Front
30 wt stock shocks, AE red spring
shocks middle on tower, out on arm.
2 deg camber
Camber link long and raised 2mm on inside.
droop 2mm above ride height5mm ride height
Rear
30 wt stock shocks, Tamiya yellow springs
shocks2nd in on tower fro outside and out on arm.
camber link longest possible.
2 deg camber
droop 2.5mm above ride height
5.5mm ride height
Yokomo 138g's or Tamiya type a tires with firm inserts.
I cannot put on sway bars or change tires cause this is all I got!!
Old 09-29-2005, 10:02 AM   #1422
I used 45wt on the front, kit locations on the wishbone and tower, 40 wt rear and I stood the shock up one hole on the tower, I used Tamiya Yellow springs all round on the TRF shocks. it was precise on this setup.
Old 09-29-2005, 10:08 AM   #1423
rayhuang's Avatar
Thank you-Do I also need o-rings on top of the bladders in the shocks with this set-up?
Old 09-29-2005, 10:51 AM   #1424
I just built them as is, with urethane bushings there, not sure what difference the o-rings will do at the moment, very new to TRF shocks I am.
Old 09-29-2005, 10:55 AM   #1425
rayhuang's Avatar
I'll mess around with the o-rings tomorrow night if time allows. It gives more rebound on the shocks-usually advantage when running soft oil and soft springs.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
