Like Tree2Likes
Old 09-16-2005, 01:26 AM   #1261
rayman's Avatar
Originally Posted by marvi
you guys know if tamiya will release a carbon upper deck? im thinking of getting one from tech racing but i prefer to get tamiya only hopups (in the hope of someday joining our local tcs ) however, if the tamiya upper deck is months away, ill get an aftermarket one thanks for any info
Ey fred, where's your source for the tech racing hopups? Did that guy selling at the for sale forum push through with his offer to import? I doubt if tamiya releases an upperdeck anytime soon unless they bring a pro or r version within the coming months.
__________________________________________________ _____________________________
My Gallery
rayman is offline   Reply With Quote
Old 09-16-2005, 01:36 AM   #1262
You can find it at RainbowTen. 2980YEN for the upper deck ... quite expensive CF BTW
e_lm_70
e_lm_70 is offline   Reply With Quote
Old 09-16-2005, 02:57 AM   #1263
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Default CF chassis
have any of you guys seen the CF convertion of the TA-05 made by XENON
buboy28 is offline   Reply With Quote
Old 09-16-2005, 04:31 AM   #1264
Is the upperdeck something like this?
:http://www.rctech.net/forum/attachme...chmentid=85405
Someone posted the picture a while back.
Alwin.
F1mechanic is offline   Reply With Quote
Old 09-16-2005, 05:36 AM   #1265
Alwin.
Yes ... you can check on: http://www.tech-racing.co.jp/op_parts_new.htm
See also the pict of their CF stuffs ...
e_lm_70
Old 09-16-2005, 08:50 AM   #1266
Herc Driver's Avatar
Sweeeet pix...I gotta see the r or trf version!
Herc Driver is offline   Reply With Quote
Old 09-16-2005, 09:09 AM   #1267
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Originally Posted by cheehtae
I bought the rear uprights, both the 2- degrees and the 0- deg but both are hard ones, what I need to know is the part number for the Hard front c-hubs - 50985 is part # of reular plastic one, I need the the stiffer ones, anybody HELP.
Here's the hard stuff..
53579 TA04 Hard Front Upright
53428 Hard Rear Upright (TA04)
53427 Hard Suspension Arm (TA04)
53472 TA04 Toe-In Rear Upright
Hmmm. The C hubs are actually part of the F tree, haven't found any in hard material, just these:
50985 C-Hub Carriers (F-Parts) (4 degree caster)
53458 TA04 Racing Hub Carrier Set (6)
The second has a little more caster, and I'm still not sure about the material. I figure being "Racing" they'd be harder... otherwise, all we have is the F parts tree...
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 09-16-2005, 11:50 AM   #1268
rayhuang's Avatar
Hey guys,
I am chomping at the bit-a bit-here. My cars late in coming so I can only ask questions.
The stock hingepin blocks on the car-are they equivalent to evoIII/Iv blocks or are they narrower or have built in kick-up in front? Maybe different roll center?
Please advise. Need t know if I need ot go shopping again
Also-whats wrong with running the stock blocks? Lack of bling?
Thanks in advance,
Ray
Old 09-16-2005, 12:20 PM   #1269
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by rayhuang
Hey guys,
Thanks in advance,
Ray
Ray,
here you go.
1. The stock hingepin blocks on the car-are they equivalent to evoIII/Iv blocks or are they narrower or have built in kick-up in front? -- the bridge blocks are like the 415 "A" Blocks.. front/front block is same as an "A" block. im not sure about the rear/rear block. no they are not narrower and no they no kick up. roll center is the same
IF you use evoIII/415/IV blocks.. you need to buy suspension balls to go on the hinge pins. since the stock blocks are plastic, they just insert in without using the suspension balls.
2. Also-whats wrong with running the stock blocks? Lack of bling? -- nothing is wrong but knowing you..like i know me.. you'll put the bling on there. on a serious note, the different blocks is a good tuning option for this car.
car is really good on asphalt btw
Hebiki is offline   Reply With Quote
Old 09-16-2005, 12:26 PM   #1270
Regional Moderator
Darkseid's Avatar
Hey guys, I'm actually thinking of giving the TA05 a try to go along side my JRX-S. What kinda stuff are you guys adding to them to bring them up to race spec? I'm not big on adding a bunch of unneccesary alloy parts, so if it isn't absolutely needed, I usually don't add it on.
Upgrading to the TRF shocks seems like the first step, so what else is needed?
Oh, and when is the full TRF version expected to be out?
Darkseid
TLR 22...Tamiya F104...
Old 09-16-2005, 12:56 PM   #1271
Well, the REAL needs are the CVD's and the ballraces for the steering, otherwise the rest are just realy fine tuning.
DA_cookie_monst is offline   Reply With Quote
Old 09-16-2005, 01:08 PM   #1272
rayhuang's Avatar
Originally Posted by Hebiki
Ray,
here you go.
Whats asphalt?????? Thank you Chris.
Old 09-16-2005, 03:00 PM   #1273
Hebiki's Avatar
hehe ill be racing carpet in a few weeks.. then ill know what you're always talking about
Old 09-16-2005, 03:10 PM   #1274
cheehtae's Avatar
Trader Rating: 15 (100%+)
tried searching this at Tamiya website and towerH. does not seem to exist
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 09-16-2005, 06:48 PM   #1275
rayman's Avatar
e_lm_70
Tnx. Its near where my cousins live in Nagoya. Maybe I'll just ask em to buy it for me .
My Gallery
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
