Like Tree2Likes
Old 09-05-2005, 04:38 PM   #1156
racer's Avatar
Originally Posted by Hebiki
Thanks for the link!
racer is offline   Reply With Quote
Old 09-05-2005, 05:29 PM   #1157
fire929's Avatar
Default Suspension blocks
Originally Posted by fire929
Are the front and rear bridge blocks A's or B's
Anyone know the bridge block letter front and rear.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 09-05-2005, 07:38 PM   #1158
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rtypec
Thanks to Mr. Greg Hodapp for haning out and taping a neat video of an 8 minute main with TA05's. Wow...I'm such a hack lol. Sorry for the LD (let down) guys hehe. Oh well Greg, the website's FAF, funny as f...!
Past Chump A1 TA05s Martin owns All
Oh man, looks fast Rod. Just a little less RED BULL next time.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-05-2005, 07:49 PM   #1159
topgluer's Avatar
anyone can tell me what pinion and supr gear for stock mtor is best
topgluer is offline   Reply With Quote
Old 09-05-2005, 09:15 PM   #1160
rtypec's Avatar
You could be right Mike. But the Mobil gas station up the street had a special on RockStars. 3 for $5 man I was buzzin.
Powered by:
rtypec is offline   Reply With Quote
Old 09-06-2005, 02:22 PM   #1161
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Do the X series suspension blocks come with spacers to allow you to use them bridged?
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 09-06-2005, 02:37 PM   #1162
Hebiki's Avatar
Trader Rating: 26 (100%+)
yes, they come with 3mm spacers.
edit: the "X" block for the evoIV does NOT come with spacers. only the MS series "X" blocks come with spacers (1XA, 1XB, 1XC, 1XD)
Hebiki is offline   Reply With Quote
Old 09-06-2005, 03:28 PM   #1163
Those were cool videos of the TCS. Man Rod, you were fast. I didn't think anyone could run down Crispy like that. After watching that video though, we're gonna have to change your nickname from Rodzilla to Rollin' Thunder
DOTMAN is offline   Reply With Quote
Old 09-06-2005, 04:05 PM   #1164
WarpdSpazm's Avatar
Originally Posted by DA_cookie_monst
Raced it yesterday against Xrays....
Hey Cookie... You got any other shots of you car... I'd like to get a better look at that paint scheme... What's the back look like? I'm trying to get inspiration for mine.
I've got til Sat, 3PM to paint it.
Ray
Brownies Hobbies | BlackMaven MotorSports
Euro Truck|TT-02|1/12 Spec
Long live the Silver Can! I like to go slow
www.facebook.com/blackmavenmotorsports
WarpdSpazm is offline   Reply With Quote
Old 09-06-2005, 04:23 PM   #1165
cheehtae's Avatar
I have tried 100/23 on a 64 pitch , my temp gauge say that it was 150 Farenheit, someone on the thread here said I could go up to 27, I would try it this weekend and see. But I guess 150 is hot already although my car was not really that fast. recommendations from any PRO or Factory driver?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 09-06-2005, 04:35 PM   #1166
WarpdSpazm's Avatar
You got that hot because you were actually way undergeared... Believe it or not... Undergearing is just as bad as overgearing... I've just installed a 104/30 combo which ='s a 7.8 overall ratio.. a 104/29 would yield an 8.06 which would be better, but I don't have a 29T right now. This is on my Handout motor from last year's indoor Nats... Don't know if anyone else liked that motor, but it ran well for me.
remember it's Spur/PinionX2.25=Overall Ratio
To add to it, this is just a starting point... The way to fine tune to your track (at least the way we do by me) is to set the car so that you top out about 3/4's down the straight. Which is usually 1 tooth up or down from the above. good luck, and hopefully someone else can chime in with better info on the 05.
Ray
Old 09-06-2005, 04:38 PM   #1167
Your motor may well be hot because the motor is 'under geared' so it is constantly revving it's nuts off, being under geared is just as bad almost as being over geared.I just ran my TA05 on 48dp gears, 78/24 which is 7.3:1 and motor temps were fine.
More pics, sure
Tamiya TA05 Touring Sedan-p1010047.jpg   Tamiya TA05 Touring Sedan-p1010051.jpg   Tamiya TA05 Touring Sedan-p1010048.jpg
DA_cookie_monst is offline   Reply With Quote
Old 09-07-2005, 03:24 AM   #1168
Default Set up needed for outdoor medium grip / not so flat track
Hi,
Going to put on a race track my new TA05 with a 17T motor this weekend.
I need some hint for the set up:
- The ground level setting via the 3x12 screw in the suspension arm ... is something that is normaly used ... or should I just play with springs adjustament like the TB01 setting ? ... this sound to me to limite the down travel, and have already a "higher" initial resitance before allow the suspension travel ...
- Stock oil and number of hoel in the piston.
I"m currently set up 1 hole in the front, and two hole in the rear ... this in theory should allow more grip on the rear ... so a more easy undestearing set up .... is my assumption correct ?
- Stabilizer .... in a bumpy tracks ... does make sense to use stabilizer ... if yes just on the fron or just on the rear ... or on both ?
A part from using 2 hole in the rear piston, the TA05 is set up 100% as tamiya manual.
Here people drive with quite soft suspension cars, with a final gear sometime close to 5 (around 5.5) with a 17T motor ... gotta use my 26T pinion, since is the biggest 0.6 pinion that I have ... and still I will have less top speed then competition ..
e_lm_70
PS: Going to use CS27 tyres. (opt. CS22 if it is cold, or I don't have enough grip)
e_lm_70 is offline   Reply With Quote
Old 09-07-2005, 03:34 AM   #1169
OK, I used 40wt oil in the TRF shocks with one hole all round, this left the car feeling quite nice amount of grip (but I was using racing slicks not the kit tyres).
As for the suspension, set the spring collars so you have 5.5mm front and 6mm rear ride height, the adjust the threaded screws in the wishbones so the car lifts an extra 1mm front and the same rear, also, make sure the settings are the same left to right.
If you then want more grip on the rear off-throttle, you can give the rear a little more suspension travel (droop).
Old 09-07-2005, 04:20 AM   #1170
What is the main effect on using 2 hole piston with 40wt stock oil ?
2 hole should be more soft & fast ... so more grip ... isn't goot for the rear ?
e_lm_70
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
