Like Tree2Likes
Old 03-27-2013, 07:35 PM   #11236
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by RcNuttz View Post
no boost or timing in the esc or motor
Ok, so which insert is in the motor? I'd recommend the 3-dot insert and start with the gearing around 3.2 (51T pinion). However, this will vary according to the track and your driving style (I don't so much as have driving style as crashing style )
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 03-28-2013, 09:08 AM   #11237
when I got the setup it had the 3 dot insert I replaced it with the 2 dot since it was running hot
I'm thinking it needs more then just a pinion the battery that i've been using I can run my 22sct for over 15 minutes with it and that has a tekin RS Pro & ballistic 17.5t this car is only getting around 8 minutes, last night I looked it over again and think the front belt is a touch snug and that might be part of the head problem really not sure since i dont have another one to compare it to
DX3R TLR 22sct Tekin RS PRO Ballistic 17.5t JC B-Codes.....
TD DESC410 V2 Tekin RX8 SC4X 4.5.....
Bank statement NEGATIVE BALANCE!!! Just need to learn how to use it all
RcNuttz is offline   Reply With Quote
Old 03-28-2013, 10:56 AM   #11238
what temp's should it be kept under?
my experience was performance would really start to drop around 175-180
DOTMAN is offline   Reply With Quote
Old 03-28-2013, 07:12 PM   #11239
PDR
PDR's Avatar
The 2 dot insert is more can timing than the 3 dot one. The 4 dot insert is the least timing. If you insert the 4 dot one reversed, you get maximum can timing.
I won plenty of blinky races with this combo, generally with the 4 dot insert and geared a little shorter than the guys running Orion, Reedy etc.
The drive train should always be nice and free, regardless.
Old 04-15-2013, 09:01 AM   #11240
Default Tamiya TA05
Hi guys,
who can tell me what the weight loss would be from using the "lightweight carbon reinforced" tub chassis vs. the stock standard plastic tub from the basic kit?
tamiyadave is offline   Reply With Quote
Old 04-15-2013, 10:19 AM   #11241
Originally Posted by tamiyadave View Post
Hi guys,
Maybe the reinforced TA05 chassis weights less, but it's not Always the case of being lighter.
My TA06 kit chassis weights about 99gr and the reinforced one weights 102gr.
addicted2blue is offline   Reply With Quote
Old 04-15-2013, 01:54 PM   #11242
well i had my suspicions thats why I ask... ideally i'd like to shed about 50~100 grams total weight thats quite a bit...
Old 04-15-2013, 05:50 PM   #11243
Sith Lord's Avatar
Trader Rating: 21 (100%+)
If you use the search function, you'll find this thread:
http://www.rctech.net/forum/electric...ing-sedan.html
which will probably discuss the issues there. I remember when I ran a TA05, using all the "lightweight" parts I couldn't get anywhere near the minimum race weight
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 04-15-2013, 05:58 PM   #11244
niznai's Avatar
You can shed that much weight by going to a lightweight shell alone. Better too.
Not sure if using a carbon tub is better than a plastic tub for the TA05. Definitely not that much difference.
151g for the plastic version, 140 carbon. There you go.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-16-2013, 03:38 AM   #11245
tc3team's Avatar
the ta05 is a heavy chassis in general, it is not a trf designed car so unfortunately it is built more for durability, not as a top spec race car.
That said, it is a very good car for club level racing The extra weight can be useful for high grip tracks to tame grip roll and give stability.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 04-16-2013, 03:19 PM   #11246
thats right I am racing it in a "stock"class on a technical low-medium grip asfalt track and so far so good (i'm on podium) but my class weight is 1400 gr and all up I got 1470 so ideally i would like to get lower.
Old 04-16-2013, 09:28 PM   #11247
stitchy's Avatar
Try a shorty pack. You'll probably have to ADD weight after that
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 04-16-2013, 09:34 PM   #11248
niznai's Avatar
Yes, that is somewhat true. The chassis built as per the stock kit is a bit heavier than a dual carbon plate chassis, but if you start with an R version and make a wise choice of upgrades (quite a few; don't remember exactly what came in the kit, but mine has all the alloy parts possible), you can bring the bulk down a fair bit. Using Ti screws alone saves about 30 grams.
Sure, you will say this brings the price up way above a TRF car, but hey, you'll have a tank.
Team Greasy Weasel
Old 06-11-2013, 07:58 AM   #11249
Did tamiya release a chassis that fits Lipos for the TA05? I have a IFS VerII and it is just sitting in my shop, seems like a shame. So I want to build it up with some TRF parts. What are the best upgrades for this chassis?
djtang88 is offline   Reply With Quote
Old 06-12-2013, 08:08 AM   #11250
Trader Rating: 37 (100%+)
Using a TA05R "2 hole front arms"...
What swing shafts are guys using? 46mm? Sorry been away for awhile and building one up to race USGT.
Nexus is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
