Like Tree2Likes
Old 01-16-2013, 06:28 PM   #11221
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Ok, I'm sure this is answered somewhere here but, I can't seem to find it. Burned out the rear diff in my TA05 recently and want to replace the entire thing. I see that I can't use the new gear diffs since they are 37 tooth pulleys. Is there a way to convert the chassis to use them? If not, where can i even get the older 36 tooth diffs? Do I need to buy them in separate parts or is there a tamiya part number for the diffs complete?
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 01-16-2013, 06:39 PM   #11222
edhchoe's Avatar
Trader Rating: 41 (100%+)
Is your front diff ball diff ? If so, put it in the back and buy a spool for the front. The tamiya spool is 36t.
Or search eBay for tamiya 51212.
edhchoe is offline   Reply With Quote
Old 01-16-2013, 06:56 PM   #11223
muahdib4's Avatar
That's an idea. Though I looked at that part number and its just for the pulley. What about the out drives, diff balls and all the rest? Can't really replace it all without the rest.
Old 01-16-2013, 06:58 PM   #11224
edhchoe's Avatar
Then how about a gear diff? I run spool front, ball in rear. Vta type class.
Old 01-16-2013, 07:06 PM   #11225
muahdib4's Avatar
VTA is exactly what I'm getting it ready for. I thought about the gear diff in the rear but the gear diff is 37 tooth so the belt won't fit. I love gear diffs and have used them in my Mini for years. May try a spool up front. May change my driving style which usually involves running into all the boards currently.
Old 01-16-2013, 07:35 PM   #11226
ta04evah's Avatar
I've bought stuff from these guys before and they have been very reliable for me.
The link is for a complete ball diff for $16US, and it comes with a 36 tooth pulley.
http://broadtechonlineshop.com/eagle...l.aspx?id=3807
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 01-16-2013, 07:44 PM   #11227
muahdib4's Avatar
Cheers
Rob.
Now that could be interesting. May give those a try too. Thanks for all the help. Also glad to see the chassis isn't dead. Dreading the day I have to buy something new.
Old 01-16-2013, 08:56 PM   #11228
ta04evah's Avatar
I've been using them for well over a year now, I use one for 6 months then chuck it out and drop a new one in. It's alot cheaper than trying to buy all the parts separate to re build them.
In the car they are in I race on a regular weekly basis, sometimes twice a week and they have never let me down. I started out using a 21.5 in blinky mode but now the car has up to a 13.5 blinky in it.
I think they also sell a spool diff, but I'm not exactly sure if it'll fit into a version 1 ta05. http://broadtechonlineshop.com/eagle...l.aspx?id=3480
Nowdays I use my ta05 mostly as a VTA car for which is perfect for them as they are docile & easy to drive, even with the VTA tires & body shells on the car.
Cheers
Rob.
Old 01-18-2013, 05:56 AM   #11229
???E-Racer's Avatar
Default Well whoop de doo. The Novak XRS runs a Lipo!
Got my TAO5 dialed in just need some competition.
No-one I mean no-one runs touring cars here, it's a shame.
Novak, Viper, LRP
4wd Slash Platinum,4WD SC10,Stock Slash Latemodel Oval,Losi Slider,E-firestorm Bomber, Team Terribles,www.rkhobbies.com,GOLFLAND USA
???E-Racer is offline   Reply With Quote
Old 03-27-2013, 12:35 AM   #11230
Looking for help
I picked up a "used" TA05 IFS V2, it has a tekin RS ESC, LRP Vector X12 running 2s
when i first ran it temp's was hitting a little over 200 degrees after a few minutes of running, took it all a part cleaned, oiled bearings & set the pinion/spur mesh correctly temp are now down to 180'ish @ the 4 to 5 minute mark so i'm thinking its the gearing now?
its has the following
37t front diff gear on one way
36t rear diff gear
80t spur gear
56t pinion
18t pulley
I also noticed the front belt is "lightly" rubbing on the aluminum hinge pin holder not enough to cause any drag really but i'm guessing it has to do with the bigger front gear?
what gearing should this thing have for a 21.5t motor? what is the benefit of running a larger front gear in the diff?
thanks
DX3R TLR 22sct Tekin RS PRO Ballistic 17.5t JC B-Codes.....
TD DESC410 V2 Tekin RX8 SC4X 4.5.....
Bank statement NEGATIVE BALANCE!!! Just need to learn how to use it all
RcNuttz is offline   Reply With Quote
Old 03-27-2013, 04:36 PM   #11231
^^^ any one?
Old 03-27-2013, 04:49 PM   #11232
Originally Posted by RcNuttz View Post
Looking for help
36t rear diff gear
80t spur gear
56t pinion
18t pulley
thanks
well, i cant tell you much about gearing but i can tell you that the LRP x12 motors tend to run hot. i'm not surprised at the temps. the good news is, they are the most durable motors ive ever used. they can take the heat although performs does drop. my advise is to keep trying different pinions until you find the sweet spot.
DOTMAN is offline   Reply With Quote
Old 03-27-2013, 06:58 PM   #11233
what temp's should it be kept under?
Old 03-27-2013, 07:19 PM   #11234
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Looking for help
36t rear diff gear
80t spur gear
56t pinion
18t pulley
thanks
Are you running blinky or boosted?
Which timing insert do you have in the X12?
If I'm not mistaken, you're at an FDR of 2.94 which is tall gearing for a TC. You can get away with this with a really torquey motor on a moderately open track, but I suspect that for blinky with the X12, you'll want to go down a few teeth on the pinion, starting around 3.2 or so.
If you're running boost on the Tekin, then you'll need to very careful about the boost/turbo values. The Tekin/X12 combo can be very, very quick with boost, but take time to get the settings right.
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 03-27-2013, 07:30 PM   #11235
Phil.
no boost or timing in the esc or motor
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
