Like Tree2Likes
Old 02-07-2012, 11:26 AM   #11146
stitchy's Avatar
Originally Posted by roylo View Post
A simpler question:
What is a part number for a front spool to fit a TA05 ISFR?
53877
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-07-2012, 11:49 AM   #11147
Originally Posted by stitchy View Post
Thankyou..
roylo is offline   Reply With Quote
Old 02-11-2012, 01:37 PM   #11148
Anyone know who makes alloy 16T and 17T centre pulleys. Looks like 3 racing only make then in plastic.
Old 03-01-2012, 02:19 PM   #11149
TeamNuts's Avatar
Trader Rating: 35 (100%+)
can anyone help me with this problem-
my ta05 fishtails and spins from a dead stop with moderate throttle and also on corners when applying throttle on the way out of the apex.
Using the car as USVTA with spec tires which have plenty of life left.
I rebuilt the front ball diff which didn't seem to help but before i tear the back one apart I was hoping someone had experienced a similar problem and figured out the problem.
Do I need to rebuild the rear diff or tighten it down?
The belts are a little loos but work fine - should I replace them?
Thanks!
Level 3 RC - Team Nuts Designs
Spektrum - GensAce
TeamNuts is offline   Reply With Quote
Old 03-01-2012, 02:42 PM   #11150
kwkride's Avatar
How tight is your rear diff?
If it is too tight it could cause the car to react like that.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 03-01-2012, 03:13 PM   #11151
Thanks!
Sounds like one of your drive axles is broken.
DOTMAN is offline   Reply With Quote
Old 03-01-2012, 03:56 PM   #11152
C&B RC's Avatar
Thanks!
TeamNuts
You're near Omaha right?
Kwikride & I both race on Weds night. You should stop out and we can take a look at it on the track @ the PLEX.
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 03-01-2012, 04:11 PM   #11153
Serpent Guy's Avatar
Thanks!
your belt tension is adjustable in the bulk heads, if the tensioner is maxed out then its time for new belts, what is your rear toe? what is your camber?
one of the quickest things toy can do to help is loosen your rear diff
Serpent Guy is offline   Reply With Quote
Old 03-03-2012, 04:36 PM   #11154
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Question:
I'm getting ready for TCS and Which is the best Tamiya bodies works best for this TA05 Ver2 IFS?
OVA is offline   Reply With Quote
Old 03-04-2012, 01:53 PM   #11155
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by OVA View Post
Question:
i'd say the HVS, or the Corolla but i know the IFS NSX seem to work very well also
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-04-2012, 06:02 PM   #11156
dirtman71's Avatar
well I just picked up a new TA05 ver 1 roller in a trade its put together and I think it has a few upgrades to the center diff and belts. I realy know nothing of onroad, I do have a M-05 I have been running for a couple of months.
I do know this is not the greatest car to start with so I know set up will be everything to help me get competitive. I read through a bunch of pages but dont have time to read through 744 pages.
I will be running novice 17.5 and will use a Novak 17.5 ss. Has a 78t 48p spur. I have a 27t pinion is that a good starting point? or do I need to go taller?
What are the hop ups? Somebody said one of the other cars parts transfer
Any little points would be great....thanks Curt
Kyosho SC-R, RC8Be, Jammin X1CRe, Jammin SCRT10, RC10GT2, T4.1
Slash 2wd ChuckWorks slice B2, E-maxx, RC10T3, Tamiya M-05, TA-05
dirtman71 is offline   Reply With Quote
Old 03-04-2012, 09:40 PM   #11157
you can take arms,c-hubs and knuckles from the TRF 416, they are much lighter and have better geometry
a front spool would be a good investment as well as a set of cvds
the stock shocks are ok for kit shocks, but if your looking to spend any more TRF shocks are worth every penny
after that its all about learning to drive the car smooth and quick
Old 03-04-2012, 10:04 PM   #11158
dirtman71's Avatar
Thanks, have cvds and just the stock shocks
Now I dont know much about spools but isnt that just a locked diff? I would think that would give me an issue with the steering? But I bet it would drive out of the corners hard
was thinking about about some 3racing shocks down the line, are they anygood?
Old 03-05-2012, 08:27 AM   #11159
subaru73's Avatar
Trader Rating: 41 (100%+)
Default ta05
yes the spool is locked it does pull hard out of the corners that is what alot of people are running.as for shocks the tamiya trf shocks are well worth the money.getting back to the spool you should not have any problems with steering.any more questions just ask there are alot of very good people on rc tech
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 03-05-2012, 02:28 PM   #11160
3racing shocks are a little better than stock but, in my opinion aren't really worth spending money on.
a spool is basically a locked diff, the big difference being the spool will last along time, but a stock diff locked will ware out pretty quickly because its not intended to be used that way
as for how it handles, the spool lets you get on the power sooner to pull the car out of the corner faster, personally i like the way it steers that way and if you look at a lot of high end cars they all come with front spools these days.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
