Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 06-06-2011, 11:03 AM
  #11116
spring71's Avatar
Smile
We have indoor rc track & hobby shop in chino CA.
Spec R Gear Diffs and Universals are in stock.
Click Here to see Spec R products.
Click Here to visit the parts store
Please visit www.tqrcracing.com for more information.
spring71 is offline
Old 07-05-2011, 07:14 AM
  #11117
silverhkswrx's Avatar
Originally Posted by tamiyarcracer View Post
Strong but medium weight - medium to fast wear
There are2 Titanium axles one for the reversible Lightweight suspension, (53718) and one for the standard TA04 / TB02 / TA05 suspension (53681)
Super lightweight & soft
There is the aluminum axle from the TRF415MSX Reinhard edition (53939)
Super strong, good wear, & heavy
To really confuse everyone there are the stock steel axles for the standard TA04 / TB02 / TA05 suspension (53499) & the steel axles for the reversible lightweight suspension (51094)
That is your lesson for today, class!
You wouldn't happen to know if any of these titanium outdrives work with the TA06 would you?
silverhkswrx is offline
Old 07-23-2011, 12:55 AM
  #11118
TOJ
TOJ's Avatar
hello guys,
does anyone know if the TA05 has option pulleys? larger & smaller mid pulley or front diff pully to create overdrive ( front wheel turn a bit faster than the rear wheel ) or underdrive ( front wheel turn a little slower than the rear wheel ) usually option pulley has 1 slot more or 1 slot less than the standard pulley for the belt tooth.
few kits has this option feature like TA03 , LOSI JRXS as far as i know.
TOJ is offline
Old 07-23-2011, 01:28 AM
  #11119
JimmyMac's Avatar
Yeah, you can use 36 or 37 pulleys. But don't ask me about belts. I don't remember. I'm still using old school pulley setup 36/16.
JimmyMac is offline
Old 07-23-2011, 03:50 AM
  #11120
Originally Posted by TOJ View Post
hello guys,
square and active make overdrive kits for the ta05. if ur only looking for tamiya made products u either can do a front/rear pulley of 36t or 37t and a center pulley of 16t or 18t. not sure if anyone has tried using the ta06's front 39t pulley.
platypus_s13 is offline
Old 07-23-2011, 04:37 AM
  #11121
TOJ
TOJ's Avatar
so it's possible, thanks a lot.
TOJ is offline
Old 07-24-2011, 09:30 PM
  #11122
big al's Avatar
I don't know of this has been brought up, but I realized today that the xray castor blocks for the 07,08 and 09 are almost a direct for the ta05. You could then use the xray knuckles. I only came upon this because I have a hard time getting tamiya parts up here in the pacific north west.
big al is offline
Old 07-25-2011, 12:27 AM
  #11123
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
http://www.stellamodels.net/catalog/...oducts_id=5636
Wonder how this compares to the Spec R diff, certainly cheaper!
nexxus is offline
Old 07-27-2011, 03:51 PM
  #11124
kdeselms's Avatar
Just in case anyone is interested, I have a fully-loaded TA05 v2 up for sale including everything but a receiver, transponder and battery - it's got almost all of the TRF upgrades on it, as well as the Exotec carbon chassis. Lots of extra parts and Solaris tires, as well. Also a Hudy 10th scale touring car setup station.
http://www.rctech.net/forum/r-c-item...p-station.html
kdeselms is offline
Old 07-29-2011, 03:32 PM
  #11125
TA05 gear diffs are in.
stitchy is offline
Old 07-31-2011, 11:31 PM
  #11126
monkee's Avatar
Trader Rating: 15 (100%+)
I keep breaking king pins
I know it's happening when I overshoot the turn at the end of the straight
Regardless, until I increase my skill, I need to change something
What's the best option?
Going back to plastic knuckles? Or c hubs? Or a different top bearing?
Please give me any help
This is frustrating. I've gone through 4 so far amd this is the last pin I have on hand
Drilling them out sucks
monkee is offline
Old 08-01-2011, 04:47 AM
  #11127
Blacktiger355's Avatar
Trader Rating: 81 (99%+)
For now I would go back to at least the plastic knuckles. And maybe the c-hubs. The plastic knuckles are easier to get in a pinch than the king pins. And are more forgiving than the aluminum.
Blacktiger355 is offline
Old 10-03-2011, 11:06 PM
  #11128
RossoTorro's Avatar
Well, i have searched and looked for answer but can't find one...
I got a loaded TA05R and want to use oil gear diffs, and all i find are for TA05 V2's. Now, can i change over to use them on my car?
What parts are needed to change?
Anyone have part numbers?
I know i have to buy the diffs partnumber 54312.
What pulleys and belts do i need?
RossoTorro is offline
Old 10-04-2011, 01:09 AM
  #11129
the ta05r used 16t center pulleys with 36t f/r pulleys. all the newer ta05's from the ifs-r to the v2-r use 18t center pulleys with 37t f/r pulleys. you will need to buy the 18t centers and the belts for an ifs-r or v2 and you will be able to use the v2's gear diffs.
Old 10-04-2011, 06:53 AM
  #11130
RossoTorro's Avatar
What about clarence in chassi for bigger diffs?
Maybe upgrade car to v2 with new chassi and v2 paarts also then...
