Like Tree2Likes
Old 01-11-2011, 09:42 PM   #11101
monkee's Avatar
Trader Rating: 15 (100%+)
So.... I keep breaking kingpins
The top kingpin that holds the steering knuckle in the c-hub
Both the knuckle and the hub are 3racing aluminum parts
I'm thinking that the metal on metal isn't allowing enough flex for my inconsistent driving abilities
I have everything stock plastic available. Which would be the best to replace with stock? The hubs or the knuckles?
monkee is offline   Reply With Quote
Old 01-12-2011, 02:53 AM   #11102
Blacktiger355's Avatar
Trader Rating: 81 (99%+)
I would try the Hub first and see how it does. If it keeps breaking, swap them and try again.
Blacktiger355 is offline   Reply With Quote
Old 01-12-2011, 11:58 AM   #11103
monkee's Avatar
will do.
sadly, a solid smack to the sideboard coming off the back straight tends to snap the pins clean off forcing me to dremel out the end of the pin
Old 01-13-2011, 03:32 AM   #11104
Ouch!
Old 01-15-2011, 10:35 PM   #11105
daign's Avatar
new body and wheels. Kyosho Ferrari 575 GTC...
daign is offline   Reply With Quote
Old 01-26-2011, 07:50 PM   #11106
Blue_VB_SL253's Avatar
Send a message via MSN to Blue_VB_SL253
Hey guy's. Just wondering if its possible to use the
3 racing TA05-IF22/WO Graphite Conversion Kit For TA-05IFS and set it up to use it for 3 racingTA05-09/V3/WO Graphite Chassis Conversion Kit Ver. 3 For TA-05 componets as they are out of stock for version 3. Here are the picture for the two of them different links
http://os.3racing.hk/products.php?products_key=2858
http://os.3racing.hk/products.php?products_key=3722
Input would be much appreciated.
Blue_VB_SL253 is offline   Reply With Quote
Old 01-28-2011, 09:06 PM   #11107
daign's Avatar
With the 575 GTC body...
+ YouTube Video
New 2007 911 Cup GT3 Body
Old 02-14-2011, 09:59 AM   #11108
hi, very late to the party. just got a new-to-me bog standart ta05 that needs it chassis replacing. Originally thought to replace it with the carbon tub but a mate mentioned the 3 racing v2 conversion kit for a little bit more. However, I have read that due to the "good fit", there could be some campside mechanics required to do this. Is it go or no go for the conversion. Oh, how will handling be affected? For ref. the last TC I had was a TC3 and the one before that a ta03. Thanks.
one-nil is offline   Reply With Quote
Old 05-08-2011, 10:17 PM   #11109
zafira2310's Avatar
Default spur n pinion combination on TA05 with 3600kv motor
HI All,
just play 1/10 electric again after 3 years absent.
now i having problem with the gear ratio, the TA05 have 2.25 gear ratio. now I'm running BL system with no sensor. the motor have 3600KV on it. the store say its 12.5T motor.
I expect to have a fast car, but when i try the car is very slow in strait track. I having 104T (64P) spur with 30T pinion. Am I doing right or total mistake using that spur and pinion combination. need help - Thank you
zafira2310 is offline   Reply With Quote
Old 05-08-2011, 10:32 PM   #11110
Originally Posted by zafira2310 View Post
HI All,
ur fdr is a 7.8. you need to use a diff spur and pinion combo and try to get down to the 5-4's
platypus_s13 is offline   Reply With Quote
Old 05-08-2011, 11:03 PM   #11111
zafira2310's Avatar
thank you, sorry what is FDR? and what i need to bring down to 5-4s
Old 05-08-2011, 11:14 PM   #11112
fdr=final drive ratio
so like i said you need to change the pinion and spur combo so you can bring that number lower. for example if you use a 64 pitch 40t pinion and 89t spur you will have an fdr of 5.01. try that combo but u need to temp ur motor and esc after a 5-6 minute run to see if it gets too hot or not.
Old 05-09-2011, 12:31 AM   #11113
zafira2310's Avatar
got it, thank you so much. will try and update.
Old 05-09-2011, 12:56 AM   #11114
tmomedrano's Avatar
just want to share my ta05 tourer... since its my only rc car it gets all my lovin.
pretty humble setup for 13.5 with boost.
aluminum suspension mounts
universals upfront
cf conversion
aluminum shocks
opted for a non ifs configuration as its easier. wanting that gear diff from spec-r though... this handles in our home track quite well. even competing with trfs (same level driving as me)
any more suggestions for hops? i am still thinking if aluminum bulkheads are really necessary though.
[ Team Maxx Traxx ] http://iloveporrc.blogspot.com/ * http://timmedrano.com
tmomedrano is offline   Reply With Quote
Old 05-09-2011, 01:35 AM   #11115
Thats a great looking Ta05. They are a great car and can compete with anything at club level.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
