Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 08-15-2010, 12:40 PM
  #11026
Anyone here that uses the Yeah Racing bearings (the ones with the blue seal) ?
Tjello is offline
Old 08-16-2010, 04:53 PM
  #11027
Suspended
@ encore75 -
Crap I got that bumper and its only a TB03D bumper dyed black -
But its a LTD edition tamiya part - so that is kinda cool.
*Limited Edition Itens
49462 - TA05 Urethane Bumper (Black)
Looks like my kit box item, without the wear and tear of three years of abuse
But it's not grey but that's cool
dragnse7en is offline
Old 08-16-2010, 10:01 PM
  #11028
encore75's Avatar
Trader Rating: 26 (100%+)
Originally Posted by dragnse7en View Post
@ encore75 -
IIRC, the TB03 bumper is the same as the for the 416, TA05MS, and TB-EVO 5. I can't interchange the bumpers between my TA05R and Evo5 because the holes line up differently.
But yeah, the Limited Edition bumper for the TA05 is just the same as the stock one...just in black foam (to better match the black of the chassis). From what I've seen, most of the "Limited Edition" items are just different colored versions of the stock pieces rather than different designs. For example, I have the Limited Edition "Milky Blue" sway bar set and White spring set on my TA05R (and the Limited Edition "Black" sway bars on my Evo5), which are single color, respectively, instead of the usual red, yellow, and blue.
encore75 is offline
Old 08-17-2010, 01:35 AM
  #11029
Suspended
Dood - I just got #49462 and the mounting holes fit sweet - looks like it would fit a V2 as well; with a knife
Have you used the shims yet - and do they help. My TC5FT in the rear has opposite angle (anti-squat) but with no shims I have roughly 1 (anti-dive)
Old 08-30-2010, 07:53 PM
  #11030
Suspended
Originally Posted by kowkl View Post
Hi Guys,
I was at the LHS yesterday and enquired regarding the no on the rear hub carrier. He mention that the no indicated is the deg of toe in. So Now I'll fix the 3racing rear hub with my 1A rear inside and D rear outside will give me 3.5 deg. I'm not sure if it's too much but will post my experience with this setting. Thanks for all the help.
Regards.
I found this in the TA05MS manual -
Old 09-06-2010, 06:36 AM
  #11031
Suspended
All dressed up and nowhere to go until the big dance in October:
I changed the rear end's springs again and used some tuned springs from my TC5 this time. Lighter stabilizer bar installed as well.
Old 09-11-2010, 01:34 AM
  #11032
Dragnse7en,
Thanks for the info. I'm now using the alluminum 2+ hub with a 1C + 1A as to achieve 3 deg toe in. Now looking to make my care more drive able. I've got a race using a TA05 is making all the xray guys a run for their money as he's a good driver and some of them just trail him from the back.
Hopefully to get his standard with my TA05.
kowkl is offline
Old 09-11-2010, 07:58 PM
  #11033
Post tamiya ta05ms
4 sale ta05 ms kit only with ferrari fxx body shell no elctronics included.
09216013419. 5 times lng ginamet with spare parts included and box.
anthonyco14 is offline
Old 09-13-2010, 07:06 PM
  #11034
Trader Rating: 36 (95%+)
hi, i recently bought the porsche 934 ta05 ms, the chassis is the 230 mm wheelbase, I know there are no other bodies that will fit it, is there any way to make it 237mm, as i have a bunch of corolla bodies, the spacers only give 3 mm in adjustment need another 5mm, any help would be great, thanks
zaraz is offline
Old 09-27-2010, 05:54 AM
  #11035
Trader Rating: 35 (100%+)
If anyone is interested, I have a heavily optioned (Tamiya parts only) TA05 IFS-R for sale. Take a look at my post. Good price for a chassis that is in excellent condition. Lots of photos.
http://www.rctech.net/forum/r-c-item...y-options.html
Geppetto is offline
Old 09-27-2010, 12:43 PM
  #11036
Suspended
I will offer 70 bucks, eps since the R version has been announced . . .
Old 09-27-2010, 01:20 PM
  #11037
Leroifittipalde's Avatar
How is your MMP esc mounted? Im having problems getting mine to fit. Did you cut your chassis on that side?
Leroifittipalde is offline
Old 09-27-2010, 05:54 PM
  #11038
RielTime Racing's Avatar
I have the Mamba Max Pro also. This is what I did to make it fit. No problems running other than finishing 2nd all the time in qualifiers and mains
RielTime Racing is offline
Old 09-28-2010, 12:40 PM
  #11039
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Searched but was getting nowhere fast...
Can suspension arms 51104 be used instead of 50868 as a direct replacement? Thanks
minicooper is offline
Old 09-28-2010, 01:33 PM
  #11040
Ah, I was hoping to not have to do any cutting of the tub but it seems unavoidable with an esc this size. The pic helps, thanks.
