Like Tree2Likes
Old 08-30-2005, 08:31 AM   #1066
I am assuming that is a TRF setup sheet with a TA05 pasted on, but I am guessing from looking at the TRF manual, that you can use all the suspension inner pin mounting brackets on the TA05.
Just need a starting point for rubber tyres on Carpet now.
DA_cookie_monst is offline   Reply With Quote
Old 08-30-2005, 08:36 AM   #1067
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Pretty well, but I've made quite a few cosmetic changes from the 415 sheet.. no official TA05 sheet has come out, but this one can do for now, for those without the LW Suspension.
Blame TTSO for starting it all..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-30-2005, 09:52 AM   #1068
ttso's Avatar
What.?
ttso is offline   Reply With Quote
Old 08-30-2005, 10:06 AM   #1069
Jam-ehz's Avatar
Yeah, you.. troublemaker...
Old 08-30-2005, 10:49 AM   #1070
Jam almost all of us had a different set-up for the car. I think Ian was the only one on the 04 Suspension most of the rest of us had the LW suspension.
Car widths were the main changes between the car. Some ran ultra narrow some ran wider. I know Martin was on AA front and AC rear. I ran ultra narrow in the first runs and it was hell on the tires. I think Rod was running ultra narrow also. For camber link most settled on middle hole with variations of the link vert height.
The new 430 is a great body very stable and a touch pushy. A few of us ran with a touch of an airdam on the nose to give a little more steering.
All in all it was a fun weekend with tight competition. Rod and Martin were on a different course than the rest of us. But even still laptimes were very tight with a .3 spread from fast to slow.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 08-30-2005, 11:02 AM   #1071
Jam-ehz's Avatar
Neato.. what kind of springs did you need on that track? Did you have to use the kit tires?
(On a side note, I see on the TA05 upgrade pamphlet a pic of grey springs.. do they make grey? I thought they went as far as white. Who would need them that stiff?)
Old 08-30-2005, 11:29 AM   #1072
There is a Grey and a Purple that are rates above the White. Mainly they are carpet rates I have rarely used them even indoors.
As for spring rate I ran yellows as did most of us. Steve Williams ran White and Blue.
Old 08-30-2005, 11:33 AM   #1073
rayhuang's Avatar
hey dan-aka Past Chump. HOpe you had fun. I am switching to GT1 for next TCS season. Expect me to bug ya even more next year I even have devoted a car to just rubbertire/carpet duty!!
What wing do I order to run the ferrari body? Or will the wing off of my Skyline work?
Old 08-30-2005, 12:07 PM   #1074
rtypec's Avatar
It's neat that just about any setup will work on this car and still everybody would be only a couple of tenths off from each other.
I'm at work right now and don't have the car in front of me so here's what I can remember. Thanks to Martin for the text formatting It's all about the copy/paste hehe
Front
Arms : lw
Toe : 0
Camber : 1.5
Shock Mounts : outside hole on shock tower and middle of the three holes on the arm
Shocks : 400 tamiya with 2 hole 1 red sponge
Blocks : 1X Front and 1XD Rear
Arm Spacing: front block/1mm/arm/the rest/rear block
Ackerman : front hole on the steering knuckle
Upper Link : middle hole 4mm up
Downtravel : 24.6mm measured from top of axles to setup board
Springs : yellow
Swaybar : yellow
Ride Height: 5mm with TakeOff CS27
Rear
Arms : lw
Toe : 3 degrees
Camber : 1.5
Shock Mounts : in one hole on shock tower and inside of the two holes on the arm.
shocks : 300 tamiya with 2 hole 1 red sponge
Blocks : 1XC front and 1B rear
Arm Spacing: front block/the rest/arm/2mm/rear block
rear upright : 0 degree aluminum middle hole no spacer
Upper Link : middle hole on rear upright, middle hole on inside mount no spacer.
Downtravel : 25 mm measured from top of axle to setup board
Springs : yellow
Swaybar : yellow
Notes:
CF shock towers front/rear. 5mm clamp-on wheel hex. 46mm swingshafts. Hop-up diffs front/rear setup with front tighter than rear. Dual Rate on radio 85%. Expo -15%. 0.7mm spacer epoxied on steering knuckle to decrease steering throw.
I think that's it for now. The car is fast but cannot be overdriven. Touch a curb and over she'll go woops.
Special thanks to Kilruf for Satoshi's suspension block setup from rcworld.
rtypec is offline   Reply With Quote
Old 08-30-2005, 06:23 PM   #1075
SpeedTech's Avatar
Hi Guys,
Just want to post a quick news, for the new Tamiya TA05 sedan, we have a company that is working on a graphite upper and lower deck conversion kit together with aluminum front and rear bulkheads. No ETA just yet, but it is in the works and will be available in the US through Speed Tech R/C
I will keep you guys posted
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 08-30-2005, 08:40 PM   #1076
ttso's Avatar
Originally Posted by SpeedTech
Hi Guys,
Steve Wang
Steve you hurt my wallet.....
Count me in!!!
Old 08-30-2005, 09:37 PM   #1077
Send a message via AIM to aoizip
Steve...
you saying... you are going to make speedtech's own
"tamiya ta05-trf speedtech edition" ?
my wallet is getting thinner steve....
price please.. so i can start saving....
btw.. where is my suzuki parts for the BD.. oppss.. wrong thread....
Ming
aoizip is offline   Reply With Quote
Old 08-30-2005, 09:39 PM   #1078
Thai3g_Eclipse's Avatar
Hi Guys,
Steve Wang
Now that's what I'm waiting for.
HPI Savage Flux HP | Tamiya TB-03
Thai3g_Eclipse is offline   Reply With Quote
Old 08-30-2005, 10:14 PM   #1079
SpeedTech's Avatar
Hi Guys,
This is still preliminary information, but it will be manufactured by a very reputable company in Japan. In fact, their team will be running the TA05 with this conversion kit at the 2006 IFMAR worlds in Italy next year So the Japan market seems to believe the potential of the new Tamiya TA05
Steve Wang
Old 08-30-2005, 11:03 PM   #1080
over gear's Avatar
Trader Rating: 15 (100%+)
Hi Guys,
Steve Wang
Steve, will the aluminum front and rear bulkheads fit the stock tub chassis?
over gear is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
