Like Tree2Likes
Old 02-10-2010, 08:47 PM   #10741
Send a message via AIM to A-Ko
Originally Posted by PaPeRo View Post
I've never had any problems with 3Racing titanium hex screws. As with any screw you have to use the correct size driver and never overtorque. Also superglue is NOT a substitue for locktite
With the advent of light lipos I use steel hex screws now. I can get 6 different sizes, with a quantity of 600, for $40.
Superglue I use on wheel axles to keep the nuts from backing off. With Tamiya spoke rims loctite tends to ruin the plastic making the wheels throwaways.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 02-11-2010, 06:56 AM   #10742
abailey21's Avatar
Trader Rating: 36 (100%+)
To touch on the wheel nuts;
If you have lock-nuts backing off you need to replace the nuts, NOT use superglue
Also look into serrated nuts where you can use loc-tite, but more than likely you wont need it because the nut is serrated and will dig into the rim.
As juvenile as it sounds, keep your wheel nuts fresh...they cost like $3.00 for a new set, or buy them in bulk and keep them in your box.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-11-2010, 11:18 AM   #10743
Hebiki's Avatar
Trader Rating: 26 (100%+)
+1
Hebiki is offline   Reply With Quote
Old 02-23-2010, 07:19 PM   #10744
Hi guys I have a 3racing conversion on my ta05 which is completely stock besides the chassis. I run a mamba max 7700 on a very big asphalt track. What would your suggestions on pinion-spur combos be, I am considering carbons shock towers f/r and some trf dampers. What would be some parts that would strenghten up my drivteain as I understand that the mamba does put stress on the divetrain.
Thanks for the help!
jztwin1 is offline   Reply With Quote
Old 02-23-2010, 09:07 PM   #10745
abailey21's Avatar
Try asking the people who make the power system as a start point, not the place the car is made.
K.C.C.O.
Old 02-24-2010, 07:45 PM   #10746
Thanks mate!ill give it a try
Old 02-24-2010, 09:02 PM   #10747
Has anybody had any past experiences with rc station before, sorry for shooting all these questions at you guys Thanks
Old 02-25-2010, 05:35 PM   #10748
Building my ta05 how tight should the diffs be.
strong is offline   Reply With Quote
Old 02-25-2010, 07:30 PM   #10749
Archie10's Avatar
Trader Rating: 18 (100%+)
Hi all.. i have a TA05 ifs i was just wondering.. what spur and pinion should i use.. im running the new lrp x12 17.5 and TEKIN RS.. and i run at westcoast raceway.
thanks in advance
archie10.
Archie10 is offline   Reply With Quote
Old 02-25-2010, 09:08 PM   #10750
abailey21's Avatar
What surface?
K.C.C.O.
Old 03-01-2010, 07:12 AM   #10751
Just built my stock TA05........How do I lower my front ride height....The back is ok at 5.5mm but the front came out about 12mm.....Way to high.
Old 03-01-2010, 07:22 AM   #10752
abailey21's Avatar
Are your shocks threaded, if so then you just rotate the collar.
If they are spacer shocks, then add or remove the spacer clips
K.C.C.O.
Old 03-01-2010, 09:12 AM   #10753
My shocks are not threaded and I have no spacers on the front shocks.......That's why it's wierd that the front is higher......But I just remembered I did use 3racing universals swing shafts on the front.....maybe that's why.......Sorry I will check that at lunch.
Old 03-01-2010, 09:32 AM   #10754
M-Technic's Avatar
Trader Rating: 15 (100%+)
CVD's would not affect the ride height.
I never had the kit shocks on my TA05. Is it possible that the springs are specific to the front or rear? Did you install the shocks in the correct position? Were the shocks built too long?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 03-01-2010, 12:26 PM   #10755
Never Mind.....Found the problem......Shocks not seated correctly....Car run nice.....very smooth......THANKS.
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
