Tamiya TA05 Touring Sedan >
Like Tree25Likes
Old 09-15-2009, 09:00 PM
  #10666
jolson88's Avatar
Default Balancing Chassis
Hey all. I recently picked up an MIP tweak station to get my tuning process started on my TA05. I figured that trying to check tweak would be pointless before verifying that the chassis is balanced right-to-left (correct me if I'm wrong ).
What is the best/easiest way to balance? Since this is my first racing chassis, I have no clue where to start . Any tips would be much appreciated .
Also, what is the easiest test to see if the diff is slipping? Is that something that can be done during setup, or only out on the track?
jolson88 is offline
Old 09-16-2009, 12:34 AM
  #10667
niznai's Avatar
It's not necessary to have the car balanced when measuring tweak.
To balance the car you need to get some weights and put your car on a couple of balancing needlepoints like those made by Hudy (probably other companies offer similar devices) or you can make your own.
Alternatively you could get four small kitchen scales and rest each wheel on one.
Remember that the further away from the centre of the chassis you place the weights, the less weight you need to add to balance the car out but the more their inertia will count when going around corners. Check what is the minimum weight you are allowed by the rules and try to achieve that weight.
niznai is offline
Old 09-19-2009, 07:54 AM
  #10668
AUDI 0000's Avatar
Iam going to purchase brushless system for my TA05, which ESC will fit in the very limited amount of space? I have been told Novak GTB fits snug, prob what I will get, but curious which others. Iam ebay shopping for a good used unit so your input will help. Thanks.
AUDI 0000 is offline
Old 09-19-2009, 10:06 AM
  #10669
Trader Rating: 17 (100%+)
Brain,
It fits when you take alittle off the reinforcing rib behind motor and point the wires to the center of car, but it's kinda hard to see the LEDs. I can't make it this Thursday, but I'll bring my oval TA05 IFS-R the following thursday and show you. Also, Jamie Hanson is selling some of his old speedos
John
billb60 is offline
Old 09-19-2009, 10:22 AM
  #10670
niznai's Avatar
Tekin fits but the trick is to find one S/H.
niznai is offline
Old 09-19-2009, 11:22 AM
  #10671
Blacktiger355's Avatar
Trader Rating: 81 (99%+)
Yes the GTB does fit. It is a bit snug as said above. But I got it in with out any grinding on the chassis. Also the LRP Sphere series fits alot easier.
Here is a pic of each installed in the car.
Blacktiger355 is offline
Old 09-19-2009, 11:35 AM
  #10672
just a question for some ta05 owners. Iam newer to the hobby and purchased a used ta05r a few months ago. I love the car and recently have been racing it on asphalt. Iam now addicted. Iam also addicted to hop-ups ect. I have been spending alot on Tamiya hop-ups (no 3racing or square). I was about to order some more items (maybe not neccesary but part of what makes the hobby fun). My question before I own a 600$ Ta05, Is this chassis worth it or should I just spend the money on a used Ta05ms or used trf416. I plan to keep racing.Thanks for your opinions, I do love the Ta05 and its easy to drive and maintain.
I've tried many tamiya chassis and here is my input. The TA05 is a great platform to run on. It is durable and forgiving to drive. I also spent a ton of money upgrading it, enough to buy a CF chassis roller. If can get that car around a track with minimal crashes, and think you can go faster, a 416 might be a better choice. But if you are running 17.5 or even 13.5, you should be able to get away with the 05. Main point here is: how good is your driving? GL
inpuressa is offline
Old 09-19-2009, 11:51 AM
  #10673
AUDI 0000's Avatar
thanks for the input, and pictures
Old 09-19-2009, 12:05 PM
  #10674
If you do stay Tamiya, the "C" doesn't have alot of spares but will order for you at a fair price so, keep extras. Also look at Losi, there many fast ones running at the C. So much so I got one and when I move up to Sportsman class I'll probably use it over the EVO 5.
billb60 is offline
Old 09-19-2009, 12:08 PM
  #10675
In first photo, I guess that is a metal gear servo? What arm is that you are using instead of servo saver?
billb60 is offline
Old 09-19-2009, 12:10 PM
  #10676
Your welcome!
billb60, You are correct. It's a KO servo. The arm I can not remember where I got it. I had a few in my pit box. I have some for all the main brand servos, JR/Hitec/Air/Fut etc. I will try and track them down and let you know. It works well for the application. Lines up the link perfect.
Old 09-20-2009, 08:08 AM
  #10677
M-Technic's Avatar
Trader Rating: 15 (100%+)
I have a GTB in my TA05 as well. However, I have the wires facing the outside of the chassis, opposite of the one pictured above. It's a tight fit.
M-Technic is offline
Old 09-20-2009, 10:56 PM
  #10678
jolson88's Avatar
Default HPI Ford GT or Zonda on non-IFS TA-05?
Can anybody confirm whether the Ford GT and/or Zonda HPI bodies work on a non-IFS TA-05?
Thanks!
jolson88 is offline
Old 09-21-2009, 05:19 AM
  #10679
M-Technic's Avatar
I don't think HPI makes any bodies specifically for IFS cars.
Old 09-21-2009, 06:53 AM
  #10680
TimPotter's Avatar
Trader Rating: 14 (100%+)
With a little grinding, the SP 2.0 fits in there...
TimPotter is offline
