Like Tree2Likes
Old 09-10-2009, 05:18 AM   #10636
niznai's Avatar
The Tamiya bodies are pretty much built around the same wheelbase and width. The only possible difference may be the body post holes if they come pre-drilled.
200mm bodies have totally different proportions. Even if the wheelbase is the same they just look wrong. But they can be used.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-11-2009, 12:42 AM   #10637
jolson88's Avatar
Thanks niznai!
On a different note, does anybody know where I can pick up spare parts other than Tamiya USA? I need to rebuild my stock front-diff (currently am running front one-way, but class I want to race in won't allow it), but many of the necessary parts are currently out-of-stock at Tamiya USA .
Associated B4
Tamiya TA-05
Traxxas Slash
jolson88 is offline   Reply With Quote
Old 09-11-2009, 01:01 AM   #10638
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by jolson88 View Post
Thanks niznai!
Try Speedtech RC
What parts do you need. I think I have all the internals for th 05 diff. I can get them to you @ the Hanger on the 20th if you can't find anthing. PM me we can chat.
tamiyarcracer is offline   Reply With Quote
Old 09-11-2009, 01:15 AM   #10639
bl4
bl4's Avatar
Hi What is the format to calucate the number of spur & pinion gear teeth to use to suit on the motor turn we use? Thks!
bl4 is offline   Reply With Quote
Old 09-11-2009, 02:17 AM   #10640
niznai's Avatar
All you need is set up an excel spreadsheet with the various numbers and you can work it out yourself for whatever application you need.
Team Greasy Weasel
Old 09-11-2009, 02:26 AM   #10641
bl4
bl4's Avatar
Do you any example? I know nut of all this! Thks alot!
Old 09-11-2009, 02:44 AM   #10642
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Towards the back of the manual for the TA05 is a section on gear ratios, including the formula for calculating it (page 18 for the standard TA-05 chassis).
A good online tool can be found at gearchart.com
Knowing what ratio works for your track isn't something that these will calculate for you, so checking with an experienced local is always a good idea.
Cheers,
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 09-11-2009, 03:04 AM   #10643
niznai's Avatar
Here you go.
You can see the formula in cell number L10. Pinion sizes in the left column, spur sizes across the top, C3 and D3 are diff pulley and center pulley sizes respectively, internal ratio C4.
The beauty is that you can change diff and centre sizes in cells C3 and D3 and the table will update instantly with the new ratios. you can also have another table where ratios are sorted increasing in value and paired with the corresponding spur/pinion pair so you can actually vary the the FDR incrementally by changing both accordingly.
Team Greasy Weasel
Old 09-11-2009, 03:32 AM   #10644
bl4
bl4's Avatar
Thks for all the help and info.
Old 09-11-2009, 06:18 AM   #10645
M-Technic's Avatar
Trader Rating: 15 (100%+)
Or if you are out at the track and you need to calculate it on your cell phone calculator the formula is:
spur / pinion X internal = final drive
For instance, 90 (spur) / 40 (pinion) X 2.25 (internal of the TA05) = 5.06 final drive.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-11-2009, 07:30 AM   #10646
niznai's Avatar
That's why I caved in and did the whole table in the end. Trust me, I hate computers and am at about sub-bozo level with the whole thing. But once you print your ratios ordered in whatever increments you like, it's the best thing to have at the track. Especially if you like me have a hopeless mobile phone that doesn't know anything.
Team Greasy Weasel
Old 09-11-2009, 09:16 AM   #10647
bl4
bl4's Avatar
By the way my is the TA05 ver.2 the internal isit the same?
Old 09-11-2009, 10:12 AM   #10648
niznai's Avatar
Nope. You've got 37 tooth diff pulleys and 18 tooth centre pulleys. That's 37/18=2.0555. What I posted above is the setup for modified xray 007.
Team Greasy Weasel
Old 09-11-2009, 08:23 PM   #10649
bl4
bl4's Avatar
Which mean the Ver. 2 transmission ratio is 2.0555? The gear ratio is 1:7.19Thks for all the help!
Old 09-12-2009, 09:45 AM   #10650
BXBENNY's Avatar
Send a message via MSN to BXBENNY
Questions?? Question
Hey all, Iíam running a ta05 with the gear ratio of 2.117:1 78 spur and 33 pinion giving me a final of 5.0038:1... But this ratio is not working on my club track I am running 2nd 3rd all the time and i just donít have the legs to catch 1st...... Can anyone suggest anything my club track is carpet and the layout is attached.
NOVICE TA05
scrutineer
BXBENNY is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
