Like Tree2Likes
Old 08-29-2005, 09:21 AM   #1051
Which type of tyre come with the TA05 kit ?
Type A ... or something different ?
e_lm_70
P.S: I have my TA05 on the way to my home ...
1 x 58345 TAMIYA 1/10 RC TA05 Ferrari F430 4WD Belt Driven
1 x 49360 TAMIYA 1/10 RC TA05 TITANIUM SCREW SET
1 x 53845 TAMIYA 1/10 RC TA05 FRONT CARBON DAMPER STAY
1 x 53846 TAMIYA 1/10 RC TA05 REAR CARBON DAMPER STAY
2 x 53849 TAMIYA 1/10 RC TA05 HIGH PRECISION DIFF JOINT
2 x 53843 TAMIYA 1/10 RC TA05 ARAMID DRIVE BELT
2 x 53847 TAMIYA 1/10 RC TA05 46mm ASSEMBLY UNIVERSAL SHAFT
1 x 53848 TAMIYA 1/10 RC TA05 ALUM RACING STEERING SET
1 x 53842 TAMIYA 1/10 RC TA05 FRONT & REAR STABILIZER SET
Did I miss something important in my TA05 ??? ... about one-way so far I have not a big fan of this front one way stuff in my cars ...
e_lm_70 is offline   Reply With Quote
Old 08-29-2005, 09:30 AM   #1052
e_lm_70
Hi,
You have about all the go fast goodies, but I would also get me the LW suspension, and a spool!
The LW suspension makes it more easy for the tires to go fast during a longer period, and makes the car also more responsive! That makes it easier for the excellent shocks to do their work!
A spool is always nice! This makes it more easy to pass someone!
Bye, Thomas
840918001 is offline   Reply With Quote
Old 08-29-2005, 09:33 AM   #1053
Originally Posted by 840918001
Hi,
Bye, Thomas
Hi Thomas ... do you have the Tamiya code for these items ?
Danke
e_lm_70
Old 08-29-2005, 09:47 AM   #1054
Danke
e_lm_70
Hi,
Spool is # 49358
Lw suspension is # 49346
Bye
Old 08-29-2005, 10:01 AM   #1055
Hi,
Spool is # 49358
Bye
Both items don't sound TCS GT2 friendly ... so I will stay with my list ...
e_lm_70
Old 08-29-2005, 10:21 AM   #1056
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
e_lm_70
The TA05 come with racing radials, which aren't too bad, actually.. they're not as grippy as Type A, but I think if they're sauced and on carpet they'd do well enough, or on wet pavement perhaps.. they're nowhere near as bad as the radials that came with the enzo ferrari. I use those for drift.
You may want to add:
53570 Clamp type aluminum wheel hub (4mm thick)
Tamiya 53725 TB Evo IV Carbon body mount stay (bling for the bumper - if you don't crash too much, has never caused me problems )
Tamiya 53837 TA05 Aluminum motor heatsink (nice sideways fins don't cover the motor holes! )
Tamiya 53849 High Precision Diff (at least one for the front if you use low-turn motors and aren't using the one-way)
and perhaps switch to a 64p 105T spur gear before you invest too much into those .6 Tamiya gears. Much quieter, and a lot more gearing options.
Then again, the heatsink and diff might not be available yet, but they're pretty nice to have.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-29-2005, 10:32 AM   #1057
Ghostfit's Avatar
I'll say the heatsink is definately a MUST-HAVE ! .....and not just for the Bling factor, pple here driving the Yokes BD and others are like snapping it up !
Ghostfit is offline   Reply With Quote
Old 08-29-2005, 02:56 PM   #1058
I found two types of lightweight suspension.
-Tamiya (#49346) - Tamiya TRF415 Reversible Lightweight Suspension Set
-Tamiya (#53794) - Tamiya TB-02 & TA04 Reversible Lightweight Suspension Set
The manual of the TA05 mentions the 53749 set as an option.
What is the difference between the two? Which one works better on the TA05?
F1mechanic is offline   Reply With Quote
Old 08-29-2005, 03:09 PM   #1059
SpeedTech's Avatar
The components for the two are the same, except for the universal bones:
TAM49346 have the 46mm bones included
TAM53794 have the 42mm bones included
To fit it on the TA05, you'll have to go with the 48mm bone anyway (although 46mm seems to work for some racers over the weekend at TCS) so going with either one you'll be fine.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 08-29-2005, 04:49 PM   #1060
cheehtae's Avatar
Trader Rating: 15 (100%+)
Hi,
Bye, Thomas
Hey thomas,
Have you actually fitted the spool to a TA05 or do you have to retro fit it?
I'm thinking of buying one if its a sur fit.
TNX
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 08-29-2005, 10:09 PM   #1061
ttso's Avatar
WARNING!!!WARNING!!!WARNING!!!
TRF415 spool WON'T fit TA05. The front bulkhead-to-bulkhead width of TRF415 is 3mm wider than TA05. The TRF415 spool is too wide for TA05 and there is no easy fix/mod for that. The only applicable solution is using TA05 dedicated spool, either you made one by yourself, or wait after-market parts (SpeedTechRC.... I'm callling you..... )
DO NOT buy TRF415 spool for TA05, there is no easy fix/mod to turn TRF415 spool into TA05 spool.
ttso is offline   Reply With Quote
Old 08-30-2005, 04:02 AM   #1062
The TA05 is my first belt-driven car.
What tension should the belts be and how should I check this?
Due to variable humidity the tension varies a bit.
Old 08-30-2005, 06:40 AM   #1063
I just picked up a TAo5 and very much impressed with the drivetrain, not looking for a spool or one-way, doing carpet racing, what I was after is a source for online setups, is there one for the Tamiya??
Also, I know I haven't read through all these pages yet, sorry if this has been asked before, but has anyone had an issue with the steering on the TA05, in as much as one of the steering cranks (right hand side), the hole for the drag link screw is to far forward and leaves the steering incorrect, plus pushes the ball cup into the chassis brace??
DA_cookie_monst is offline   Reply With Quote
Old 08-30-2005, 08:02 AM   #1064
Jam-ehz's Avatar
You have that right crank reversed.. flip it over, and it'll be fine.
I didn't pay attention and did it myself at first, it almost looks to have equal lengths on both sides, but one's a weee bit longer for the steering servo link side.
Now that the North American TCS is over, there should be a slew of setups available from the past champs, who had to race that car.. I'll have to hit up Martin for his setup next time I see him..
Old 08-30-2005, 08:12 AM   #1065
Jam-ehz's Avatar
Here's an improved setup sheet to get you started..
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
