Tamiya TA05 Touring Sedan >
Like Tree77Likes
Old 07-07-2009, 08:03 AM
  #10516
squidd's Avatar
Originally Posted by rnd_tang
Nice car squidd. Those diff covers were what I was after as well but couldn’t find any – would you be able to give me the part number?
53970
squidd is offline
Old 07-13-2009, 10:39 AM
  #10517
DanielC.'s Avatar
Trader Rating: 56 (100%+)
hey does anyone have a ta05 diff or spool theyd like to sell or know anywhere domestic where i can get one? i need one ASAP
DanielC. is offline
Old 07-13-2009, 09:50 PM
  #10518
Airflow's Avatar
Hi, I want to change my foam bumper to what the 416 or TBEVO V is using.
Will it fit the TA05R without any mods?
Airflow is offline
Old 07-14-2009, 04:17 AM
  #10519
Blacktiger355's Avatar
Trader Rating: 81 (99%+)
supafastsupra2, pretty sure you will need to buy the diff parts seperate. I don't think they sell a full assembled diff. I could be wrong though. But check speedtech r/c. He has the front spool in stock.
http://www.speedtechrc.com/store/ebp...id=459&id=5802
Airflow, most of the local racers around me just use the Parma tc3/tc4 bumpers. Takes just a little bit of shaving on a few spots and it drops right on. Just place it on top of the stock bumper.
Blacktiger355 is offline
Old 07-17-2009, 11:03 AM
  #10520
jonest's Avatar
Guys, I need some help. bought off alu bulkhead from a friend but there are 2 markings on the tensioner, triangle and circle. Which side should I use?
jonest is offline
Old 07-17-2009, 12:07 PM
  #10521
94eg!'s Avatar
Trader Rating: 17 (100%+)
One mark mounts the diff high, and the other mounts the diff low. If you don't know the difference, just mount it low as this is typical for most touring cars. To find out the difference, check out one of those tuning books.
94eg! is offline
Old 07-17-2009, 08:14 PM
  #10522
jonest's Avatar
Thanks. So it doesn't matter which pt I use, triangle = lower, circle = higher. What tuning books?
Thanks.
jonest is offline
Old 07-18-2009, 12:17 AM
  #10523
it's for your car's roll center.
and this is the "setup book" he's talking about..
Minami is offline
Old 07-18-2009, 08:36 AM
  #10524
94eg!'s Avatar
Diff height doesn't effect roll center, does it? Perhaps center of gravity, or may have some gyroscopic effect. I'm not really sure...
94eg! is offline
Old 07-18-2009, 10:21 AM
  #10525
Skitee's Avatar
Yip it doesn't effect the roll center, since the camber link, suspension arm angles aren't changed at all with a change in diff height. Do you think there's enough weight in a diff to have a gyroscopic effect.
Skitee is offline
Old 07-19-2009, 09:35 AM
  #10526
sorry.. i got confused. what i meant was you can control how much roll you have with the eccentric diff bearing holders. because the holder is eccentric, you can position your diffs above or below your car's roll center. i hope i got it cleared.
Minami is offline
Old 07-25-2009, 03:45 PM
  #10527
encore75's Avatar
Trader Rating: 26 (100%+)
Default CVD/Spool Vibration
Hi,
Sorry if this has been covered before, but the search function doesn't seem to be working...
I'm running a spool up front in my TA05R and noticed today that when at low to mid-speed and turning the wheels, that the front end has a considerable amount of vibration/chatter, so much that it sounds like gears are grinding. However, when at full throttle and turning the wheels, there's no chatter present (or at least not noticeable). I first noticed this today while doing a test run on my street, then figured out the behavior on my work bench, with the car up on a stand for wrenching and just testing the running of the car with the wheels in the air.
Is this just something that's a characteristic of running a spool or should I be looking for another problem in the car? I'm a bit new to on-road and have never run a spool before on any of my off-road 4wd cars (can't see why I would want to in that application ), so I don't have much experience with this problem. I do realize that just about all CVDs have some amount of chatter...I've just never seen it at this amount. It just sounds painful! Unfortunately, the track I run at isn't conducive to me going full-throttle in the turns, so that's not a feasible solution.
BTW, I got this car used and granted, the outdrives of the spool could probably use replacement. Does Tamiya have replacement outdrives for the spool as a standalone part, or am I stuck having to shell out for a whole new spool assembly?
TIA for your help.
encore75 is offline
Old 07-25-2009, 04:16 PM
  #10528
Skitee's Avatar
The chatter is caused by running the spool, if you bought the car 2nd hand then it wouldn't hurt checking the spool cups for wear and while you're at it check the universal joints and wheel axles for wear too, the spool does cause more wear on those parts too.
The part number for the TA-05 steel spool drive cups is 9485079
Skitee is offline
Old 07-25-2009, 04:18 PM
  #10529
94eg!'s Avatar
From everything I've heard, this is just a characteristic of a spool. This same question came up in the 416 forum a few days ago. Under full power it seems smooth, but makes a bit of a chatter with light throttle...
94eg! is offline
Old 07-25-2009, 07:36 PM
  #10530
What is the biggest spur (64p) that can fit in the TA05? Thanks.
hermanchauw is offline
