Like Tree2Likes
Old 05-09-2009, 04:56 AM   #10426
loriding69's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to loriding69
Angry swing shaft piece
i'm having problems with the lil cylinder piece falling out the swing shaft, any help would be greatly appreciated on how to prevent this. i have tried loc tight and it still falls out.
Anyone got a swing shaft for very cheap. Ordered some but need 1 for next weekend. Thanks for the help.
Double E
If your not here to have fun, then stay at home!!!
Breast Cancer Awareness is my race for the cure!
loriding69 is offline   Reply With Quote
Old 05-09-2009, 10:15 AM   #10427
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
make a "V" shaped notch in the middle of the pin that goes through the cross joint..
when you assemble it, use threadlock on the grub screw and make sure the notch aligns with the grub screw and tighten it into the notch..
even if the grub screw comes a little loose, the notch will prevent the pin from coming out
nb. i used a small triangle shaped file on the pins but you could also use a dremel with the right tip..
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 05-09-2009, 03:49 PM   #10428
loriding69's Avatar
-Mark
Thanks Mark, i will try this.
I also found out if you drive a 1/10 Kyosho that the cylinder is a tad bit smaller but fits. not a permanent fix but something to get you thru a race.
Double E
Double E
Old 05-10-2009, 04:00 AM   #10429
how much droop are you using f/r on asphalt?
Hatebreed is offline   Reply With Quote
Old 05-10-2009, 06:52 PM   #10430
Rear Admiral's Avatar
4mm front, 5mm rear on bumpy, high traction bitumen.
TA05
"This is going to be bigger than the biggest thing you can think of"
Rear Admiral is offline   Reply With Quote
Old 05-11-2009, 03:24 AM   #10431
Cool, thanks for that info regarding the centre one way kit guys.
I'll have to test it and feel the difference for myself. Will post back.
Have my ESC and batteries in the mail so should be able to have a nice test run this weekend coming.
Somehow I ended up with two brand new TA05s and also a one way centre pulley, just trying to work out if it's better to have that on the drifter car, or on the racer.
rnd_tang is offline   Reply With Quote
Old 05-18-2009, 03:53 PM   #10432
loriding69's Avatar
Ok, I have a few question:
1. The carbon chassis, is it better than the tub chassis that comes with the kit and if so why?
2. The front and rear carbon shock towers on the tube chassis, will it make a difference having them or no?
3. Should i spend the money getting all the upgrades or should i just go and get a 416?
Thanks for the help
Double E
Old 05-18-2009, 06:17 PM   #10433
57
57's Avatar
Default parts advice
Building up my first TA05... and have questions for hop-up parts:
1. Universals F/R. In the manual I see both 46 and 48mm (TAM 53836 and TAM 53847). Which ones do I want for the front & rear? Or buy the ones by Integy?
2. Pinion gears. Are they 48 pitch? Metric? Should I get the Robinson Racing ones?
3. Are the Stabilizer Set F/R worth the $16?
4. Any other changes I should make right off the bat...
THANKS!
57 is offline   Reply With Quote
Old 05-18-2009, 06:55 PM   #10434
loriding69's Avatar
THANKS!
Pinion Gears are 48P but you can change them out to go to 64P.
The stabilizer bars are needed.
Double E
Old 05-18-2009, 09:11 PM   #10435
sim600's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to sim600
The kit spurs and pinions are 0.6 module, which Robinson Racing calls "metric 48 pitch", so ya they should fit. I think the Tamiya ones do their job and are usually dirt cheap though.
sim600 is offline   Reply With Quote
Old 05-18-2009, 09:29 PM   #10436
loriding69's Avatar
This will give you more tuning options. It will allow you to either gear up or gear down depending on the track size and track layout. You can use the spur that is with the kit but you will need almost a complete set of pinions so that you can test and tune with. just my .02
Double E
Old 05-19-2009, 03:31 AM   #10437
48 pitch and 0.6 module are close to the naked eye, but not the same - if you mix them they'll be noisy and wear fast. The kit spur is 0.6 module, so you either need to stick with 0.6 mod pinions, or do what I did and swap the spur for a 48P Kimbrough (I did this so I could use my huge collection of 48P pinions from offroad buggies).
TA05
Old 05-20-2009, 05:46 PM   #10438
Trader Rating: 70 (100%+)
Hey guys, looking for a carbon fiber chassis for my ta-05. Other than 3racing, what else is out there?
lnc0321 is offline   Reply With Quote
Old 05-21-2009, 12:52 AM   #10439
r_s
kawada
r_s is offline   Reply With Quote
Old 05-21-2009, 01:54 PM   #10440
loriding69's Avatar
Thanks for the help
Any help??????????
Double E
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
