Like Tree2Likes
Old 08-22-2005, 07:34 PM   #1021
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by Besercoe
The only manufacturer that i know of that makes the top deck is Tech Racing, they make nice quality stuff, i have got the top deck and the Batt brace so far.
ok thanks guys another one how much are those stuff batt brace and top deck
buboy28 is offline   Reply With Quote
Old 08-23-2005, 12:21 PM   #1022
Ghostfit's Avatar
Originally Posted by Jam-ehz
How close do you mesh your 64p gears?
I can get it sometimes to the point where I can "feel" the spur 'tick' when I nudge it back and forth with my finger, but can't actually see it because it's so close... it's still free when I rotate the spur and all, but is there any benefit of having it that close rather than being able to see the space?
Thats how I mesh mine too ! then I pop the car on the track and listen carefully to the sound to see if it's too tight !
Originally Posted by ttso
There will be problem if you running spur very small. With 64p 90T spur (Kawada), you need to use at least 36T to get a close enough gear gap, means highest ratio will be 5.4675. Anything smaller than 36T will causing problem. So unless your motor is something super torque, don't use spur which is smaller tha 94T.
Huh ? ..I dun wan a smaller spur ! .....I wanna bigger one i.e: 128T Spur ! ....then I can fit in a 5T cobalt motor !
Ghostfit is offline   Reply With Quote
Old 08-23-2005, 07:59 PM   #1023
ttso's Avatar
You running a torque 23T and using a gear ratio around 5.3 right? I guess that's the reason because you using a larger pinon.
If you doing 5.7~6.0 (for rpm 23T), ex: 90/34x2.25=5.95, the pinon just not close enough to spur. Rather than 90spur, I would suggest go for 94 (ex: 94/36*2.25=5.87) which is much safer for gear.
ttso is offline   Reply With Quote
Old 08-23-2005, 08:28 PM   #1024
Ghostfit's Avatar
I think you got me confused with someone else ! ....Never had a 23T in my TA05, it was 7T, 8T and 9T in this car from the very beginning ....I need ratio in the range from 8.5 to 10. Currently settled with 8.83 on a 8T.
Maybe I'll put in a 23T at our local TAC 2006 next year, but for now this car is running with the big boys !
Old 08-24-2005, 04:43 AM   #1025
ttso's Avatar
Ha.. I did... must because work...
Any problem you found with mod motor? I found with 23T motor the car is not as impressive as while I running Novak SS5800 (close to 19T). It feel a little bit.. too stable with 23T motor, maybe it's because motor doesn't have enough power to drive the rhino...
Old 08-24-2005, 05:31 AM   #1026
Trader Rating: 112 (100%+)
Thumbs up
Hello,
I am setting up my 05 right now.
I have a question on measuring the droop with this chassis?
I am new to the 04 and 05 chassis.
Thank you for the help!!!
Dave
Sponsors: YuK-Foo Tire Prep
dragracer72nova is offline   Reply With Quote
Old 08-24-2005, 07:15 AM   #1027
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I generally push the car down once to settle the springs, measure that height from the ground, then with my baby finger pull the end up just to the point where I can feel it getting heavier to lift, when the tires want to lift up. Measure that height, and then subtract the difference in height. To make it even more noticeable, you can weigh the tires down a bit, but not too much to deform the tire.
Make sure the droop screws are even before doing this, so you get an accurate measurement across the chassis.
I have a small metal ruler I line up against the bottom of the chassis, which also gets the ride height, but I guess as long as you find a common spot to measure from it's all good. This method works for all tires, regardless of size. Are there any other methods?
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-24-2005, 01:20 PM   #1028
Skitee's Avatar
Hi Guys,
Just want to thank you all for posting comments in this forum which have been very useful during the build of my TA-05.
I need to ask if anyone has successfully mounted a receiver next to the motor without getting major interference, if you have which side ? closest to the rear wheels or between the servo and the motor. I have had to go with mounting the receiver on top of the servo, unfortunately this means I can't use the blue bling aluminum transponder stay. Would be nice to get all the weight as low as possible in the chassis.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-24-2005, 05:03 PM   #1029
blue hornet.'s Avatar
hey skitee, i mounted my reciever between the servo and the motor, have only had one minor interference issue and that was at a track known for it!!! and that was with using AM too!
AE RC8 B3.1
AE B64D
AE SC10
blue hornet. is offline   Reply With Quote
Old 08-24-2005, 06:28 PM   #1030
Ghostfit's Avatar
AHhh ! ....my young grasshopper, learn you must, moderation in everything.
especially in work !
The one thing that comes to mind is that this car requires much stiffer springs than normal. ....Are you kidding me ? ....some of the tweaked 23T here can pace with a 10T easily ! time to rebuild your 23T
Old 08-24-2005, 10:11 PM   #1031
black-knight's Avatar
R/C Tech Charter Subscriber
Some pics of my TA05, so far with one meeting under its belt(s) the TA05 appears to be very smooth and balanced.
waiting on Tamiya to release more goodies lol
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 08-25-2005, 02:30 AM   #1032
Man,
If you need a fan over the ESC ... then maybe is time to buy a better ESC !
e_lm_70
P.S: Your TA05 ... doesn't look TCS friendly
e_lm_70 is offline   Reply With Quote
Old 08-25-2005, 04:14 AM   #1033
ttso's Avatar
Common, SS5800 is faster and more powerful than any 23T, it's normal to feel 23T slow/underpower when you play too much brushless (or 8T )
Stiffer spring? I run softer .... maybe it's 2F deck make the different?
Old 08-25-2005, 05:59 AM   #1034
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Talking
and time to rebuild the 10t too!!!
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 08-25-2005, 11:33 AM   #1035
Ghostfit's Avatar
LOL ! ......had to rebuild everything on the TA05 after that last race ! ...some criminal send my car into the walls prior to the start remember ?
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
