Like Tree2Likes
Old 01-23-2009, 10:08 PM   #10291
cheehtae's Avatar
Trader Rating: 15 (100%+)
if your receiver is small enough, put it in the gap between your motor and ESC, if not then on top of your servo wold be fine.
cheehtae is offline   Reply With Quote
Old 01-24-2009, 07:39 AM   #10292
TwoTone's Avatar
Originally Posted by dragnse7en View Post
Mount it on top of the servo, otherwise the receiver will be too close to the motor and will cause interference. The general rule of thumb is to keep a receiver about 2 inches away from a drive motor or glow engine.
My receiver is right there between the motor and servo on both my TA05s and no problem.
TwoTone is offline   Reply With Quote
Old 01-24-2009, 10:54 AM   #10293
Post a closeup picture please
also... how does one shorten servo wires?
seems like there is 12inches of wire!!
macscac is offline   Reply With Quote
Old 01-24-2009, 11:46 AM   #10294
joe of loath's Avatar
haha, I need some of your servo wire on my ESC. The cable is so short it won't fit behind the motor. thankfully it's a small ESC, so it fits between the servo and motor snugly... the receiver is on top of the servo.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 01-24-2009, 12:37 PM   #10295
TwoTone's Avatar
page 4 post # 115
http://www.rctech.net/forum/electric...on-pics-4.html
Old 01-24-2009, 01:08 PM   #10296
thanks twotone!
it is tough on these cars... there just isnt any room for anything!
Old 01-24-2009, 03:09 PM   #10297
TwoTone's Avatar
thanks twotone!
Also looking at earlier pictures of your chassis, you might be able to fit it in front of the battery without interfering with steering.
Balances out weight a little, not sure how hard it'd be to wire that way.
Old 01-24-2009, 06:58 PM   #10298
nice thought.
ill take a peek when i get home from work
Old 01-26-2009, 03:58 PM   #10299
reenmachine's Avatar
Trader Rating: 26 (100%+)
FWIW, I just spent a bunch of time costing out converting a regular TA05 to IFS-R specs. This is with price shopping and ordering almost everything from Hong Kong. It was just about $250 before shipping.
...think I'll just buy another entire IFS-R for $250 when the time comes...
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 01-26-2009, 04:13 PM   #10300
Suspended
I guess you'd have to consider yourself lucky then. I'll choose to play it safe and keep mine on top of the servo, even though I could fit two of em where you have them.
dragnse7en is offline   Reply With Quote
Old 01-26-2009, 04:23 PM   #10301
Suspended
remove the 3 pins from the connector, using a flat blade jewelers' screwdriver. They are typically held in place by a tab that is also part of the pin. After they're out, open up the crimped tabs at the bottom of the wire, taking care not to damage the pin. Then the rest is easy; cut your servo chord to your desired length, strip about 3/8" off each wire, and slide them up into the pins and re-crimp. Gently pull the locking tabs back up, and insert them back into the connector. Be sure that part of wire insulation goes up past the crimp, so if you pull hard on the wire, your work will not get pulled out and ruined.
Lemme know if this helps otherwise mail me your servo w/ the length you want and I'll do it for you if you're not up to it.
Tamiya Frog from 1985 - Kyosho Outlaw Ultima ST - AE RC10T (cow hide LOL) - Tamiya M03-L Mini Cooper - Tamiya 1/24 Tamtech Posche 962C - Tamiya 1/24 Tamtech Ferrari Testarossa - Tamiya TA05-R - AE TC5FT
Old 01-26-2009, 04:25 PM   #10302
TwoTone's Avatar
Helps if you start with TA05R
Old 01-26-2009, 04:33 PM   #10303
Yes it would, very much. The IFS part of it is relatively small. The biggies are the TRF shocks, short reversible lightweight suspension, aluminum suspension mounts, and the swing shafts. That's about $175 right there.
Pete Waydo
Old 01-26-2009, 07:15 PM   #10304
padailey's Avatar
I have a TA05R and was thinking about getting the Short arm set, but am getting some conflicting information.
Can I use the swing shafts in the car or do I need shorter ones?
Is there a noticeable performance advantage to the new arms? or only under certain conditions?
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 01-26-2009, 11:50 PM   #10305
Hey guys,
I'm running a 05 that was origionally a IFS but I removed the IFS and added another shock tower at the front. Luckily the kit came with everything needed to swap out that IFS crap!
This has dramatically improved the performance of the car, now she handles like a dream, and managed to race ok a few days ago.
ok well anyways i'm running 70/35 gearing but I really need to lower my FDR to about 3 to 3.5 So I will need to run a 45T pinion gear (for 3.5 FDR).
My question is, will a pinion this size fit? I dont have any to test out so was wondering if any of you guys have run anything similar?
Savage Flux, Xray T2R, SC10, Slash 4X4, F104 Pro, GV Gladiator, Hotbodies D4 WCE, Hornet, E10, Losi 8IGHT-E
Mash13 is offline   Reply With Quote
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
New Tamiya TA05 R touring car/motor/esc! Frost99999 R/C Items: For Sale/Trade 3 08-07-2007 12:24 PM
FWD touring car/sedan hellbilly R/C Items: Wanted to Buy 6 01-12-2007 06:22 PM
Tamiya TA05 full race sedan, Tons of Hop Ups lbckevin R/C Items: For Sale/Trade 13 08-29-2006 03:05 PM
want to buy a touring/sedan car traxxasracer Minnesota and North/South Dakota Racing 7 09-21-2004 06:36 AM
