Tamiya TA05 Touring Sedan >
Like Tree2Likes
Old 01-13-2009, 11:23 PM
  #10276
mok
mok's Avatar
Originally Posted by macscac View Post
forewarning.... the following pics are bad.
anyhow.... so here is my question.
using the 3racing conversion chassis. i ordered front and rear stiffeners on ebay but i dont think i need them.
is that correct?
ive included pics of where i think they'd go but i dont think they are necessary.
or am i missing something?
thanks
pretty sure that the ones that you have pictured are not required on the 3R TA05 conversion..
they would normally be used on a TA05R (they replace the front and rear plastic stiffeners that the stock TA05 comes with)
mok is offline
Old 01-13-2009, 11:28 PM
  #10277
thats what i figured.
thanks!
guess its time to start thinking about electronics
macscac is offline
Old 01-14-2009, 10:13 AM
  #10278
what bodies do you typically use with your ta05?
it seems that the IFS conversion is a really good idea.
i just cut the body post holes and wheels out of a dodge stratus and a mohawk body.
both of them, the hood sits on the suspension frame.
what works best for you??
macscac is offline
Old 01-14-2009, 10:27 AM
  #10279
TeamGoodwrench's Avatar
HPI '68 Camaro -- fits nice on a TA05-R chassis
TeamGoodwrench is offline
Old 01-14-2009, 11:28 AM
  #10280
joe of loath's Avatar
I have a tamiya mercedes C class (and it looks amazing) and an HPI Mustang GT-R, but the mustang needs 26mm wheels, otherwise the arches swamp the wheels.
joe of loath is offline
Old 01-17-2009, 10:13 PM
  #10281
will this battery strap work for the 3racing conversion chassis?
http://www.3racing.hk/products.php?products_key=10
macscac is offline
Old 01-18-2009, 11:27 PM
  #10282
I currently run a ProForm Mazda Speed 6 190mm body on my TA05. When I lower the body all the way down the mounting posts until it hits the shock towers the tires rub on the hood AND I would have to trim all of the front spoiler off the body so it wouldn't hit the track.
Question: How low are guys running this body, front and back? (In number of holes from the bottom of the mounting post.)
rknott is offline
Old 01-19-2009, 07:07 AM
  #10283
Suspended
I ran mine in my parking lot last week for the 1st time, and w/ the factory droop settings the body sits about 1/2 inch off the ground. I can hear the bottom edges of the body bottom out, so I might monkey with the droop a bit.
dragnse7en is offline
Old 01-19-2009, 07:31 AM
  #10284
I have the front spoiler intact. Front/rear 5th/4th hole form bottom.
stocker is offline
Old 01-19-2009, 08:27 AM
  #10285
tc3team's Avatar
that looks exactly what came with my V1 3Racing graphite chassis, so i'd be very inclined to say yes
tc3team is offline
Old 01-19-2009, 07:06 PM
  #10286
macnkitty2002's Avatar
Hey all,
I'm selling my TA-05R. Fully RTR, lots of upgrade parts included. 4 motors, Novak XBR, Airtronics MX3S, Orion Platinum 4800 Lipo, and much more! Check it out.
http://www.rctech.net/forum/r-c-item...ml#post5315770
macnkitty2002 is offline
Old 01-20-2009, 04:42 PM
  #10287
sometimes you finish your painting and are just very unsatisfied.
i could have done so much more.
macscac is offline
Old 01-23-2009, 07:25 PM
  #10288
my naked chassis looks wistfully at the newly arrived goodies that showed up at my doorstep today
macscac is offline
Old 01-23-2009, 08:48 PM
  #10289
so where do i put the receiver?
seems to be tight on space w/ the 3racing chassis
is there a receiver small enough to fit in that gap between servo and motor?
or do i park it on top of the servo?
macscac is offline
Old 01-23-2009, 09:07 PM
  #10290
Suspended
Mount it on top of the servo, otherwise the receiver will be too close to the motor and will cause interference. The general rule of thumb is to keep a receiver about 2 inches away from a drive motor or glow engine.
